Everything posted by maithri
Xenon Headlights
Hid lights are mostly fitted to the dipped beams as these are the most used. Main beams light up plenty when needed. When I learnt to drive in SL I was thaught to dip(not dim) the head lights whenever there was an oncoming vehicle. Additionally I was told Main beam was used to drive on un lit roads when there was no on coming traffic. So unless I know otherwise it appears we have completely ignored the simple road rules and manners. I am not surprised as my last few visits made me aware that driving in SL was a sure way to put your self at serious risk. We even seem to ignore stop signs at junctions and Zebra(pedestrian)crossing are overtaking zones for the thugs who drive 3 wheelers and buses. At a roundabout just go and hope the others stop! Please guys try and promote a little road courtsey and safety even in a small way in this forum as better manners on the road gets all of us there faster as well as safer. To me HID lights in colombo=waste of money For driving in the outstations , well adjusted HID lights with clean light lenses=Brilliant
Xenon Headlights
Hi Guys, I see a few cars fitted as standard with HID lights. They should be fitted with some form of head light wash system at least to keep the lenses clean as this light deflects very easily leading to poor visibility for you and dazzle for any on coming driver-both very dangerous. The road is not just you! Many others on it. I have seen the conversion kit for standard lights-complete with the transformers that you need to get these lights started. If fitted to a dipped beam lamp on a twin head light arrangement they work well. The light output is good and set up correctly will not dazzle other and give you good visibility. Make sure the transformer is fitted in a place that can cool it and not in contact with anything damaged by its heat. On another note hope none of you or your families had any injuries or harm from the incidents in Colombo today. My sympathies to anyone who sufferd as a result. Maithri.
Which Engine Oil To Ne Used?
I agree with mean green, the 'W' rating is for the viscocity in Winter-not really any point in a tropical country. I have looked in a few car handbooks and seen a table showing the viscocity indexes according to the temperature expected. The higher number 30, 40 etc is more important in SL. If your car is relatively good enginewise a 10w-40 grade should be fine. But look also for the API Index most hand books will also give the minimum requirement for this-it indicates the all important additive package in the oil which is what seperates the high quality oils from the cheap products. Most oil companies will say theirs is the best product without stating under what circumstances. In a hot climate on a car used mostly in traffic jammed colombo the demands on the engine oil will be totally different to the requirements of a car driven at normal speeds during a freezing winter day. So what is good for the same car in North America is not really suitable for use in the same car in SL. Also just because it's expensive it's not always the best! Maithri.
Scorpio Security Alarms
Scorpio or Scorpion?
Drove 2 Work On Ebrakes Only
Ripper, Most recomendations are just that-a recomended minimum standard mostly-when it comes to brake fluid here in the UK we seem to have nothing but Dot 4 offered these days. How ever most mid to early 90's cars will have Dot 3 as the recomended fluid as this was the best and mostly widely available then. The higher spec fluids are almost always compatible with the lower spec ones unless they say so on the tin. The exception are the silicone Dot 5 and 5.1 fluids that seems to require the old fluid to be completely drained before filling the system. There is the rare exception of using the green coloured fluid (Citroen LHM). Never mix these two as they were never compatible and all the rubber seals and hoses were different too! So there is a minefield but I would think in SL normal Dot 4 Fluid changed around once every 2 years would be more than sufficient. If Dot 3 is the widely available fluid the same applies, change it every 2 years or even 18 months if possible in the case of Dot 3. It's the time that matters more not the distance travelled, as absorption of moisture happens weather you use the car or not. Maithri
B4 Tt
Hi Guys, I repaired an oil leak on a 1995 Jap import Subaru 2.0 turbo last week. The car belongs to a former neighbour and a friend as I normally leave this work to my Friends at Zen Performance a few doors from me. After the repair I had a little drive in it in the process of delivering it back-I had a late teens driver trying to glue himself to my rear bumper( he dosn't know I know him but he is also a customer) so I had a bit of fun and put my foot down suddenly-poor chap I lost him even before I changed to the next gear, what fun! to me it put a huge grin on my face just to feel that lovely power surge. I must get one for myself soon they only sell for around £3500 at that age and good jap imports are plentiful and I think it would be a nice improvement on my 1996 VW golf GTI. Maithri
Hi all, On the issue of brake fluid one of my mechanics likes old cars-classics-he currently owns a 1970 Morris Oxford as well as Wolsely 16/60 and he uses dot 5 fluid after a complete overhaul of the system. He says as these cars are not driven often dot absorbs less moisture and so has less chance of corrosion to the rare brake components! These cars were before dot numbering was probably started and they work well on this very high quality brake fluid. So I would be surprised at any damage to the rubber seals as a result of a higher quality fluid. A poor quality or worn and contaminated seals are probably a bigger culprit. Maithri
Hi all, Yes I am afraid I live in the UK and the garage is mine-I am a mechanic and I have my own garage, that said the equipment required can be made by someone with a bit of ability. There are two types of brake bleeders-vaccum one like the one I prefer or the pressure type. The pressure one is simpler to make yourself- get a spare cap that fits securely and airtight to your brake reservior, drill a hole and fit an old brake hose or any other hose capable of holding a pressure of around 30psi. Get a strong plastic bottle and fix the hose to one end of it-all joints must be fluid tight and secure. Attach an air hose to the other end securely. Now fix the cap to the brake fluid reservior fill your plastic bottle with fresh brake fluid and attach the air hose at the opposite end of the air hose to a the tyre valve of a spare tyre using a tyre connector. The pressure in the tyre will force the fluid to the brake master and simply go around the car and open the bleed screws one by one till around half a liter of fluid has come out from the four bleed nipples. Make sure the fresh supply of fluid never run too low during this process. I bought and used a similar device back in the 80's when I used to visit my customers and did not have a ready supply of compressed air. Dot 4 brake fluid has a higher boiling point and is superior to dot 3. I am surprised that some feel it damages seals in cylinders-I have never experienced this and as far as I know they are completely compatible.
Hi All, Brake fluid is hygroscopic (absorbs moisture). As a result once open to air brake fluid starts deteriorating-hydraulic fluid cannot be compressed but the moisture absorbed is water vapour and will compress as well as boil at a much lower boiling point than brake fluid. This can cause dangerous brake failure if the brakes get very hot as in decending steep hills etc with a lot of brake use. The other factor is the corrosion and pitting caused by the moisture inside expensive brake cylinders. The best way to avoid is to replace once every two years with fresh brake fluid from a sealed container. I would not suggest doing it yourself as the pitfalls are many and safety implications immense. In my garage we use a vaccum suction system to suck out the old brake fluid through the bleed nipples as well as the reservior on top of the master cylinder. We then slowly fill the system with fresh fluid with all the bleed nipples open and then vaccum bleed each corner to purge all the air that is in the system. In all this process we avoid any contact with the brake pedal as pumping the brake pedal on an empty system can damage the seals(washers in SL) in the cylinders due to the lack of lubrication. Once done there is no need bed them in as only the fluid is renewed and non of the friction components-the brakes should work as before at least if not better and certainly safer.
Hi, Most cars since the 80's have dual circuit brakes to give you a little more safety to prevent total brake failure as soon as a leak happens-that's how you first stopped! Your car will have disc brakes at the front which are operated by a hydraulic caliper. This gets the brake fluid(OIL as you call it) under extreme pressure through the brake hose and the metal pipes from the brake master cylinder which is connected to the brake pedal through the brake servo( a round biscuit tin like cylinder). It appears you have a leak at the caliper end of the brake hose or at the caliper itself. If it is the hose replace it and check all the other hoses in the brake system of the car- do this by looking for cracks in the rubber outer as well as for bulges or bumps which will show up easier if you start the engine and get someone else to press the brake pedal hard. If you see a bulge stop the pressure and replace the hose immidiatly as it's about to burst. Brake fluid spillage will cause paint to loosen and peel off causing corrosion. If possible wash with plenty of water as soon as possible this is the most effective way to neutralise brake fluid-I do it almost every time me or any of my staff work on brake or clutch hydraulics. It's far better than any chemical and cleaner!
Bmw E36 & Audi A4
Buy The Audi! It is a truly well engineered car with a superb interior and build quality. The 3 series BMW is the bargain basement-a car for those who aspire to the badge unlike the 5 series and above. 3 series suffer from all sorts of niggles and hardly offer satisfactory levels of performance. A 318 is underpowered whilst an A4 1.8 is adequate. 1.8 Turbo A4's are great and more fun than the 2.0 versions even. The Bmw suspension is no match for the one in the AUDI and the quality of the Audi inside and out is far superior to the BMW. I must add this only applies to the 3 series. The only saving grace for the BMW is it's rear wheel drive set up which makes it slightly better balanced.
Need Subaru Guru's Advice
Guys, I would bring a different point to you all if I may. I presume all of you guys have a car because you need it as well as enjoy the freedom and the thrill of driving. A Honda as driven by a large contingent of the pensioners in the UK creating a complete nusense on Sundays by driving 20 mph below the speed limit in their vtecs are non exiting but practical and reliable cars to drive! A Subaru? well fist it is a fairly roomy saloon car with traditional styling with a fantastic powertrain under the skin in the 2.0l turbo versions or higher. It will take your grandma safely to the temple/church/kovila as well as give your girl a pair of wet pants driven hard. These 4WD's are reliable and have no hidden tricks, just plain good mechanicals that needs proper maintainance. Try abusing any car and the results will be pretty much the same. So the decision is not how fast you can travel on the crowded Galle road, the fastest are the intercity buses! Probably followed by the 3 wheelers for whom there seems to be no road rules at all! No the decision should be made by driving both cars on a suitable road-where in SL I do not know-I think the road past the Randenigala Ranthembe etc tanks to Kandy felt good-so try. Buy the car for what you want it to do-and also it's soul! Then you get the car version of Nirvana!
Engine Repair Of Galant Sigma
A second hand engine is just that-used-probably abused?-who knows? In my days in SL we had some superb Mechanics in our country like I have very rarely seen in England- They would build your engine to a better standard than a production line engine of nowadays-so a completely overhauled engine was as good as new sometimes better! So the the results depend on the quality of the machine work and the care and skills of the man doing the building. Of course the quality of the parts fitted is also of paramount importance. I seem to remember these cars for their super reliability and economy! Mitsubishi always used to have good engines-so a completely re-built unit will be a great asset if done by the right person using good quality parts and processes. At the end don't forget to run the new engine in gently-Very important for a reliable and long lasting engine. Maithri
Need A Replacement Beelte Engine
Hi All Do we not have anyone now who can re build a beetle engine in SL? In the 80's we could find someone in almost every garage who knew how to do up one of these excellent little engines. Here in the uk we replace engines due to the high labour cost involved in re-building an engine-but in SL? The parts are freely available in the UK and enthusiast will build these at home to a high standard. I am sure the machine shops(Augustine motors and Lal and Nihal etc) still exist in SL and the parts must be available in Panchikawatte freely in the right places. That way you keep your original crank case(Block) and can build a high standard engine using the best quality parts. Or, am I living in nostalgia? We no longer have the skills or talent in Sri Lanka to build one of these simple engines! I hope not. Maithri
Omg: Subaru Impreza... Atv??
My garage is a few yards a way from a top tuner of Subaru's in the uk. Zen Performance-I have seen so many wonderful cars here including the award winning car belonging to Paul Who is the Subaru Guru and the owner of this establishment. Check out their web site www.zenperformance.co.uk They are great fun and a seriously good cars to own. MG
All Car Experts, Need Your Help !
Sell her off-Keep the car!
Vehicle Emissions Testing In Sl
I am a MOT tester in the UK. We are required to test the emmisions of all vehicles we test. The thresholds of the test differs according to how old the car is. If the car is from the early 70's or before the test foe petrol engines are visual to a late (3 year old car) tested to a much stringent standard. This is regardless of the owners status in life-I have tested a member of the house of Lords car- no he didn't try to influence the result-Just read his financial Times newspaper in the office whilst I tested his car. Here we take a pragmatic view- if it was not made to meet todays standard we do not apply today's standard to it. Simple to set it up. Simple to enforce and adhere to. The main thing is we naturally comply with the law-not circumvent or subvert it. This is the basis of a civilised developed country not a failed state riddled with corrupt practices and corrupt people in high places. We need to be proud of our achievements in doing things right not getting things done through the back door. Maithri.
Remember Not To Use 95 Octane Petrol + Full Synthetic Engine Oil Same Time
Hi Guys, I live and work in the uk-so the weather and conditions are extremely different,but I see a lot of engines as I am a motor engineer(mechanic)(technician) garage owner. We have several car manufacturers selling their cars on the basis of very long service intervals I.E. VW AUDI 30k Miles on diesels 20k on petrols using synthetic long life oils with 0w/30 grade oils. Sludge is a common problem on low milage cars used for short journeys as the engine does not get to the correct operating temp before it is stopped. The high milage cars used mostly on Motorway style journeys rarely get sludged as they run in almost perfect conditions. I have a customer with a diesel which I service(the UK version not the SL version service) every 10,000 miles. I use 10w/40 semi synthetic. I started servicing the car at 80,000 miles and now it's on 280,000 Yes the lady drives around 500 miles daily 5 days a week. The engine runs like new and has never been dismantled-it's had 3 cam belts,1 water pump-not due to wear but driven by cam belt so good practice at 200000miles approx. 1 clutch and 1 radiator(which was a puzzle as it blocked up suddenly causing over heating). It is 4 years old now. Note NO SYNTHETIC OIL NORMAL DIESEL REGULAR SERVICING this may be one extreme example but prove there is no real need for very short 3000km oil changes or for oil filters to be changed so often. Dont let service stations and oil companies fleece you, It's very important to change the air filter often due to the dusty conditions in Colombo. Even change the diesel or petrol filter at half the manufacturers interval to protect from poor quality or contaminated fuel, but if you are using such good quality oils like Castrol amd Mobil dont waste money on Oil Filters more often than you need to and I am sure the oil will last longer than 3000 km's more like 10000 to 15 000 km's on a car driven normally. Maithri
On-board Dignostic Port (obdii)
Hi Guys, Watch out as an apperantly OBD socket is not always programmed to give out obd diagnostic codes. Here in the UK we find Jap Korean etc cars built before 2001 will hardly ever allow access to an OBD scanner. On some models we can get Flash codes by bridging wires on this port! Here in europe OBD codes and accesebility to them is required by law in cars made after 2001. I am not aware if the Japanese complied with this standard when making cars for the domestic Japanese market. Maithri
Us Octane Vs Other Countries Octane Ratings
Most european cars including Jap derived ones happily run on 95 octane(RON) and says so in a sticker inside the fuel flap-I.E.Mercedes etc. High octane here in the uk is 98 (RON)-called Super un leaded works well with some of the sportier engines by providing smoother and higher ouput power. How ever these will still run very well on 95(RON) on normal use. UK speed limits on Dual Carriageways and motorways are 70MPH (approx 110Kph) Town limits are 30MPH (around50Kmph). As you know the Sri Lankan traffic moves much slower than this so any gain in power is not going to be obvious and may not warrent the extra cost. The high octane Fuel should not be confused with high quality-That is a whole new ball game with additive packages to help with low emmisions etc. Modern engine management systems have all sorts of devices Knock sensors, Air mass Meters, etc.etc. to get the best power output possible in all conditions and will automatically adjust to the needs-so unless you are doing track days high octane fuels will only hurt you in the pocket.
Fuel Pump Failure?
No Surprise, even dealers(agents) in SL talk rubbish. Lead was actually a lubricant used to improve the octane level of petrol. So for some early cars of the un leaded era the major problem was lack of this lubricant property causing engine valves to burn out. In our new greener world we use Benzine to improve the octane rating of petrol-according to a very highly qualified chemical scientist freind of mine this is a far worse poison causing cancer etc.! However we the gullible public feel better for using the "Greener" un leaded fuel spending a fortune on Catalytic converters for our cars-which incidentally is worth almost the same money as a poisoned one here in the uk. The world gone mad! But fuel pumps just wear out or the electrics just fail-Very rarely anything to do with the fuel you use. Unless you put some rubbish from your re cycle bin in your tank!
Fuel Pump Failure?
Hi, All fuel injected cars have fuel pumps. Many are now mounted inside the fuel tank and a pipe from the pump feeds the fuel rail at the inlet manifold. There is a pressure regulator on the rail and a return pipe carries un used fuel back to the tank. If the pump fails the car will not start as the engine will not get any fuel. This is fairly easy to check there is a pressure check point in most fuel rails covered by a cap very similar to a tyre valve cap. Unscrew the cap and underneath you will find a valve very similar to a tyre valve. With a cold engine to prevent any risk of fire press the centre pin in-just like letting air out of a tyre-fuel should spray out-not dribble out-if safe to doso have the ignition on when trying this. If no fuel comes out check pipes filter etc as well as the fuse and the relay that controls the pump before assuming the pump has failed. The pumps fail but not as often as pipes,fuses,relay,and wiring which are far more common. The last 2 pump failures I had were from a Honda and a ford which when checking was found to have a japanese style pump as fitted to Many Subaru's. I actually used a pump from a Subaru as this was freely available to me from a Subaru High performance tuning Garage who is a neighbour as well as a friend of mine. And before you ask no it does not improve the power output on its own.
What Does 16v , 8v, 4v Means?
Hi, Valves are like doors operated mechanically to allow the fuel air mix to enter the combustion chambers at the top of the cylinders and for the burnt gases(exhaust) to exit from the cylinders. Older engines had one inlet valve and one exhaust valve per cylinder. Most modern engines have more-two inlet and two exhaust valves per cylinder normally to make the entry and exhaust gases more efficient giving more power as well as more economy by burning almost all the fuel air mixture admitted to the cylinder. So 16v means 16 valves in the engine-4 per cylinder times 4 cylinders. 12v is normally on 3 cylinder engines,20v on 5 cylinder engines and 24v on six cylinder engines. There were a few models with 3 valves per cylinder 2 inlet and one exhaust to confuse the issue a bit. Hope I havent baffeled you with science. Mike.
Land Rover
Hi Guys, I think the British Car industry died a very long time ago when the govt. nationalised the lot and BMC I think was born. Since then a succession of poorly thought out cars-Morris 1100,s Allegro's-Marina's Ambassadors-Princesse's just carried it to the grave. Land Rover was very much the exception. It remained the standard to which all the Up start Jap models stived to be. Off road at least in the uk Land Rovers out perform any other competitor from anywhere else in the world.(not Range Rover The Chelsea Tractor-) This is a true work horse of the British Farm Industry which is not known for extravagant spending! How ever for driving(Crawling) around Colombo traffic I think not! It would be horrendously un comfortable and hard to drive. Buy a Pajero, Prado,etc. etc. for that. Horses for courses as we say! A Freelander with a k series rover engine combines the worst of all the possibilities! I am a mechanic and run a garage in a rural town in England-So I happen to know a bit about off roaders(4x4). Mike
