varotone
Everything posted by varotone
  1. Chill man! They are rattly smokey rust buckets because of years of abuse, neglect and blotchy repairs. Most countries have annual vehicle inspection to make sure they are roadworthy vehicles. That keeps rust buckets out of the road. Car enthusiasts keep their old cars in pristine condition and keep running them regardless of old they are. Or scrap the old cars are buy new ones. But in SL, decent new cars are prohibitively expensive. On top of that non-existent vehicle inspection and corrupt bureaucracy can keep rust buckets running and treated for artificial inflated prices. There are a few who take exceptional good care of their old cars. But they are not the ones who are looking for a "market price" I reserve my comments on Scotty for another time ?. A quick glance at €L@K!R! shows many threads on 90s vehicles in sinhala. Please make use of your knowledge and wisdom there to enlighten the masses in sinhala about the glory of the 90s cars. While you are at it, please make the maxxa boyzz stop making Frankensteins out of fibre. Peace✌️
  2. Goodness gracious! 90s cars are cool. But attempting to increase the market value of numerous rattly smokey rust buckets in the country to save forex ?‍♂️♂️ you are on a whole other level!
  3. varotone replied to varotone's topic in MITSUBISHI
    Thank you for your advice. (For a moment I forgot how common this engine is and worried about finding the exact part?) So here's what I did today. Parts list. All OEM. Price in LKR. 1. Timingbelt tensioner razor 2500 2. Timing belt 1800 3. Alternator belt 600 4. Ac belt 550 5. Oil filter 760 6. Havoline 15w-40 4L 4000 I swapped the belts, tensioner, oil filter and filled her up. Fired up the engine ?. It ran smooth for a couple of minutes and then this happened☹️ (Sorry for not keeping the thread updated. Engine was rebuilt and broken into in my absence. Belts and tensioner were not replaced after the rebuild.) There is a loud high pitched noise depending on the rpm. It only exists within a narrow range of rpm. When I started the car today morning I heard the same noise for a short time. I tried to replicate the noise without success. So I gave up the idea of investigating it and went ahead with the belt swap hoping the noise is a squeaky belt. Now the noise is heard persistently throughout a range of rpm. Here's a video clip including the noise. https://imgur.com/a/c0sCr81 Any suggestions on troubleshooting?
  4. varotone replied to varotone's topic in MITSUBISHI
    I want to replace the timing belt tensioner pulley because it is noisy. I'm trying to replace only the bearing because the pulley itself looks good. But because of the way it's attached to the mounting bracket it seems impossible to push out the bearing with a hydraulic press. Any suggestions on how to proceed? Or should I replace the whole pulley mechanism?
  5. 1. Yes. Got it straight from the horse's mouth. A scratch is a damage in my book. Should it be replaced? If there are no other damages, no need to replace. Give a good visual inspection from above, below and around. 2. Low probability of damage from the missed timing alone. Since you are quite worried, why not give it a thorough overall? Check for cracks, warps, end float, then remove and check for run-out. May be a magnaflux also. 3. Very likely. Con rods, gudgeon pins, cam lobes Did you get a chance to start the new engine before transplanting? In other words, are you certain that this noise occured after the wrong timing? It may have been there. "Small noises" can be due to worn bearings and timing belt tensioner pulley. May be even vacuum leaks. PS. I know you spent money on two engines and frustrated because you still couldn't fix the car. Don't loose you cool. Every member commented tried to help you or point you to the right direction. Don't loose faith in mechanics or even the makabass because he messed up the engine from a simple mistake. It happens to the best of us. The last person we need here is the astrologer who can read your post and tell what components need replacement and also give you the auspicious time to repair the car.
  6. After damaging the valves from wrong timing, you replaced only the block and head. Along with the head did you replace only the broken valve or all valves, rocker arm shafts and the cam shaft? It's very likely that more than one valve was damaged from wrong timing. Valves will be the first to damage, but crank shaft and con rods also may be damaged. So check all the connecting rods, gudgeon pins, crank shaft and pistons while you are at it. You'll have to take the crank shaft to a machine shop to check it. It's worth the pain because if it's bent it will cause serious damage to the bore. Because the metal piece was floating around inside the ignition chamber, it may have damaged valve seats as well. Check that as well. BTW, why did you swap the engine when you could have rebuilt it?
  7. From YouTube channel Restoration of everything. Apparently Sri Lankan!
  8. Yes it seems. It's scary to understand that the virus can survive in the air for 3 hours!
  9. UV light kills viruses. I saw reports of china using UV light to disinfect busses and trains during this COVID-19 outbreak. Drawbacks are risk of sunburn, skin cancer on direct exposure and difficulty in calculating the required power and time to properly disinfect. This is OT, but some important information that came out yesterday.
  10. I ordered a couple of uv lights to use it for disinfection. Sadly, I'm yet to receive it. Plan was to keep the uv lights lit up after getting home. Now I'm just using hand rub on the steering wheel and gear knob.
  11. A Mitsubishi Galant (ten light) popped up on classifieds sometimes back for 600k. 1600 with 5FW would pack a punch. Rathnapura has a good collection of 'box model' Lancers in top shape. Apparently some are still agent maintained and with the first owner! 5FW, red beading, gsr shell is the Holy Grail it seems. Fiat Uno is also fun to drive. Bare minimalist and seems like brand new spare parts are still coming in. @matroska I'm salivating over that Datto
  12. Yah. It will fill. Even some cataloy paste putty would do. Will it hold up is the question. If that starts expanding when the engine is running, it will crack the head or warp it. The three brands you mentioned are OEM manufactures making good products. But the problem is the market is flooded with counterfeit OEM parts. What you buy thinking as OEM NPR can be a fake Chinese one.
  13. This should be adopted as the standard for traffic lights. Fun part is when all bad tempered drivers start meeting out punishment to the other bad tempered ones. Picture this. A bus driver with a short fuse honks the horn and counter resets! Every other driver drags the offender out of the vehicle and serves him right.
  14. Deepest sympathy for your loss. Why do you want to sell the Noah in the first place? If you don't have time to spend in the garage, then forget about selling and buying a vehicle. Selling and buying will consume far more time than you expect. (Unless you sell it to a car sale and buy brand new). Also mess with you work/study schedule, negotiating a sale is nerve-wracking, still have to go to a garage, expenses for travel, every "buyer" trying to test your patience... All that hassle. My two cents is unless you want to sell it and buy a cheaper vehicle thereby making some profit from the transaction, keep what you have.
  15. There are cheap no-brand-name blue clay bars on AliExpress. I bought a couple of them. It gets the job done. I used it to remove overspray and it is quite effective. Used during washing, soon after rinsing the soap. Used some car was liquid in a spray bottle for lubrication. It didn't seem to scratch things up.
  16. Running on nitrogen? You mean the fuel is liquid nitrogen or the tyres are inflated with (80%?) nitrogen?
  17. You are so brave to attempt a whole paint job by yourself! And that too with a home made compressor! I'm lost for words? Please elaborate on your compressor contraption. If it's good enough for spray painting a car, that's definitely good enough to get some compressed air for cleaning stuff.
  18. Many say that when you repair a puncture by plugging, there is more damage done than the puncture itself. When using the rasp to smooth out, it makes the hole bigger, damages the steel belts and finally when it is plugged it distorts the structure of the tire. Maybe the old method of removing the tire from the rim and fixing from the inside is better. But the new method is very easy, quick and maintains the tire pressure. Anyway, tires being consumables, why worry too much about how the puncture is repaired if it gets the job done?
  19. Buy a tubeless tyre puncture repair kit. Available at Sri Lankan online retailers and some supermarkets for about Rs. 500. Look at a YouTube video on how to use it. Try it on an old tyre. Keep the repair kit and a pair of pliers in the car. It is a very reliable fix. Usually, you don't have to remove the tyre. Jack up and rotate the tyre to see the puncture. Fix it and pump air. Quicker than fixing the spare wheel. Cheaper than the repair cartridge that you have to pump in and drive a certain distance at a certain speed!
  20. If your wife is driving, better avoid the nano. Panda with power steering would be better. Nano being discontinued is one more reason to avoid it. https://www.bloomberg.com/opinion/articles/2018-07-11/rip-nano-india-s-car-market-is-no-place-for-cheap-thrills For a 'car' that's almost a failure with a short production run and now discontinued, availability of parts is questionable. Also keep in mind that ladies can drive stick. I know one who learnt to drive auto was given a chance to drive a j70 Prado. She loved it. But didn't love it enough to go through the hassles of updating her driving license.
  21. Why have you narrowed it down to panda and nano? And why automatic? If you are happy with an older one, there are plenty of options that will easily beat your choice in terms of parts availability (except body panels and the like) and rider comfort. Look for a well maintained one and will give the panda a run for it's money. Only downside is when you are selling it. But given that the car is already depreciated when you buy it, you want loose much. Consumables for common old vehicles are very easy to find and cheap. Most engines are pretty darn reliable. But my understanding is that older auto gearboxes are not very reliable.
  22. Hello gentlemen, I'm looking for some small piece of rubber that looks like a o-ring with a groove inside. (Not an automotive part) The cross section looks like a c. Here's a drawing of the product.where can I find some thing similar? Because this one was damaged, I want to buy a few of these. About 10 pieces. Thanks in advance Varotone
  23. I couldn't remember if signing in the presence of a company representative is necessary. The registered owner can sign the power of attorney even when abroad. (I'm not sure if a document signed in one one jurisdiction is valid in another. But once such a power of attorney was accepted for a property matter) Also, the leasing company has a signed MTA form which they will return when the lease is settled.
  24. Lease companies do give the CR to the bearer of a letter signed by the registered owner. One leasing company had a letter template requesting that CR and the letter to DMT to erase absolute ownership to be collected by a specified third party. (Such as the new owner of the vehicle) Better ask from the company itself. Remember the registered owner has to sign the letter. If the company is willing to accept such a letter, ask the seller to get a letter signed and posted to him.
  25. varotone replied to varotone's topic in MITSUBISHI
    I'm stuck at connecting the fuel lines. On either sides there are two small tank thingies - fuel vapor separators. Each has 3 connections. But in the right hand side, the rubber grommet has holes for only 2 fuel lines. Confused how to connect these fuel lines. I've made marks with tipp-ex on the fuel lines before I remove them. Now that all the marks are sanded and painted over?. There's a diagram in the workshop manual but it confused me more. Anyone can remember how to connect them?
