From last Saturday when I start the car (Wingroad Y11) in the morning it drags and starts. It start the way like the battery is dead. Drag start will not happen when you drive some distance and try to start it again. This happens only in the morning or when you stops the car for a long period of time for instance 7, 8 hours. Though it drags and start for the first time it doesn't drag and start if I start it in the second or third time but if you leave the car without driving and try to start the car after 10 or 15 mints time the drag start will occur again. I service the starter motor. Check the battery as well and check for the any shots using the wire mechanism. It seems like no problem on above mention devices.
Any idea what will be the problem for drag start in the mornings.
sampa
Hi All,
Thank you in advance for your thoughts.
Sampa
34 answers to this question
