Hello,
Does toyota Sprinter CE110 1997 has OBD2 port?
Where is it located in car?
what are the information I can get from this car model using OBD2 port?
thanks
Hello,
thanks
i dont know about Sprinter CE110 diesel car but my old toyota g touring 1996 wagon doesn't have one may be Sprinter to doesn't have one :)
if it available you can get abs airbags diagnostic
Edited by nexus
Hello,
thanks
No. You have an OBDI port. Not sure of the location of it because there wasn't a standard in conectors or the location of a connector with OBDI. Check the bottom end of the dash under the steering wheel and the passenger side too. Also check in the engine bay if it's there you will see a small black box which says diagnostics on it. The connector is inside it.
