2006 M5 Sedan
dillongt
B) 2006 M5 Sedan <_<
MSRP: $ 115,500
Horsepower: 500 hp
Drivetrain: Rear-wheel Drive
0-100 km/h: 4,7 s
7 speed
Technology
10 individual electronically controlled throttle butterflies
7-speed Sequential M Gearbox with Drivelogic
Comfort start
Cross flow cooling system
Cylinder-specific ion flow knock control
Dual-mass flywheel
Electronic brake force distribution (EBD)
Electronic Damper Control (EDC)
Front and rear anti-roll (stabilizer) bars
Fully electronic "drive-by-wire" throttle system
Hydraulic valve play compensation
Inner vented and cross-drilled disc brakes, front & rear
Light-alloy cylinder head
Light-alloy special reinforced crankcase
M high-pressure Double VANOS "steplessly" variable valve timing
M Mobility System
M Power switch for 100hp and more progressive throttle response
M Servotronic vehicle-speed sensing power steering
M5 specific sport suspension calibration
Master brake cylinder
Oil quality sensor
Oil supply with lateral force control
Self-adjusting clutch (SAC)
Start/Stop button
V-10 M engine, 40 valves, 5.0 L, 500hp
Variable M differential lock
Exterior
Auto dimming exterior mirrors, power folding
Body coloured bumpers and door handles
Dual exhaust tailpipes, each with twin chrome exhaust tips
Front chrome grille with chrome-plated kidney bars
Lightweight aluminium / steel body
Low-weight aluminium front end
M exterior mirrors in body colour with Shadowline effect, blue tinted
M front spoiler and gills in front fenders
M rear apron/air diffuser and trunk lid spoiler lip
M side sills
Metallic or non-metallic paint
Side window frame trim, high-gloss Shadowline
White turn signal indicator lenses
Interior
12 V socket in luggage compartment
Alcantara anthracite roof liner
Armrest, centre front with storage and climate controlled
Armrest, centre rear with storage
Automatic air conditioning with micro filter & solarsensor
Automatic air recirculation function
BMW Ambiance lighting
Central lock switch
Cruise control
Cup holder, integrated in front facia and rear armrest
Door entry sills with "M" designation in high-gloss chrome
Electrically adjustable seats with driver memory
Floor mats
Front seatback storage nets
Fully finished trunk with drop-down tool kit
Glass sunroof, electrically adjustable
Heated front seats, 3 stage
Integrated universal garage door opener
Interior electric trunk release
Locking illuminated glovebox with take-out flashlight
Lumbar support, driver and front passenger
M auto dimming interior mirror
M multi-function leather steering wheel, 3-spoke incl. MDrive button
M shifter, illuminated
M sport seats, 12-way power adjustable inc. seat width
Multi-purpose centre console storage
Residual/rest heat and max A/C functions
Separate left/right temperature controls
Sun visors with vanity mirrors, incl. slide cover
Through load with ski bag, 1/3 to 2/3 split
Tilt/telescopic steering column, power with auto tilt-up
Upholstery: Merion Leather, extended
Window lifts electric, anti-trap and comfort open/close
Dimensions (mm)
Fuel capacity (L) 70 -
Headroom, front/rear 993/967 -
Interior width, front/rear 1456/1452 -
Length/Width/Height 4863/1846/1469 -
Luggage capacity (L) 500 -
Track, front/rear 1580/1566 -
Turning circle (m) 12.4 -
Wheelbase 2889 -
Weight (kg)
Curb weight 1820 -
Max. axle load, front/rear 1090/1270 -
Max. gross weight 2300 -
Max. payload 480 -
Max. roof load 100 -
Weight distribution, front, (%) 52.2 -
Weight distribution, rear, (%) 47.8 -
Engine
Bore and stroke (mm) 92.0 x 75.2 -
Compression ratio 12.0 -
Displacement (cm3) 4999 -
Engine management system BMW MS S65 -
Fuel grade Premium unleaded -
Power (SAE hp @ rpm) 500 @ 7750 -
Torque (ft/lb @ rpm) 383 @ 6100 -
Type DOHC V10 40V -
Drivetrain
Gear ratios, (:1)
1st 3.985 -
3rd 1.806 -
5th 1.159 -
7th 0.833 -
Body / Suspension
Braking system 4 channel ABS -
Drag coefficient 0.31 -
Front brake type / diameter (mm)Ventilated disc / 374 -
Rear brake type / diameter (mm)Ventilated disc / 370 -
Steering Type / Ratio Rack & Pinion / 12.4 -
Suspension, front Double pivot strut type -
Suspension, rear Integral 4-link -
Tire size, front 255/40 ZR 19 -
Tire size, rear 285/35 ZR 19 -
Wheel size, front 8.5J x 19 -
Wheel size, rear 9.5J x 19 -
Performance
Acceleration 0-100 km/h, (sec.) 4.7 -
Top speed, electronically limited (km/h) 250 -
Fuel Consumption
City, SMG (L/100km) 18.1 -
Highway, SMG (L/100km) 11.0 -
Active Safety
Adaptive brake lights
Adaptive headlights
Anti-Lock Braking System (ABS)
Automatic Headlamps
Car/Key Memory with follow-me-home function
Dynamic Brake Control (DBC), included in DSC
Dynamic Stability Control (DSC) with M Dynamic Mode
Headlight high-pressure washer system
Heated exterior mirrors, electrically adjustable
Heated windshield washer jets
Tire Pressure Warning (TPW)
Windshield wipers, speed sensitive with rain sensor
Xenon headlights, low and high-beam with luminous rings
Passive Safety
Advanced Head Protection System (AHPS II), front and rear
Battery Safety Terminal (BST)
Collapsible tube crash technology
Crash sensor (incl. fuel cut-off, lights on, door unlock)
Crumple zones front & rear
Front airbags for driver and passenger, incl/ occupant detector
Fully integrated road safety technology (FIRST)
Intelligent Safety and Information System (ISIS)
Interlocking door anchoring system
Rear headrests, three with outer positions adjustable
Rear three-point centre safety belt
Safety belt force limiters
Safety belt pyrotechnical tensioning system front
Side impact protection door reinforcements
Side thorax airbags for front and rear passengers
SMART airbag deployment system
Third brake light integrated into rear window
Audio
4-channel FM diversity antenna system
6 disc CD-changer
Anti-theft AM/FM stereo audio system with RDS
CD Player, In-dash with MP3 capability
H/K LOGIC7 13-speaker sound system, incl. 2 subwoofers
Pre-wire for Satellite Radio
