What Is This Screw Driver
rameez
11 answers to this question
wait didn't you just blow a head gasket trying to DYI a radiator fix? Now you want to work on the carb?
no the head gasket was not blown of because of me :lol::rolleyes: , it was because of the leak in the radiator hose,this is in my distributor,was wondering why the nut looked like it.My mechanic was easily adjusting the advance and retard positions but i could not see how it was been done,since he is away and will not be back till the weekend i was just looking how he did it...do you know what it is.
Looks like a slotted tamper proof screw.
This does seem to be a tamper proof screw.I doubt there is a tool available that can remove it. Because of the shape, you can only turn it clock-wise (tighten) turning it the other way would make the screw-driver slip.
The only way I see is to cut a groove across using a hacksaw blade and use a regular flat screw-driver.
stumbled on the answer by accident - it's a one way screw. As Anjo says, you can tighten it (even with a flat screwdriver) but you can't remove it
A "funny" scredriver called a "Un-Do-It" does the trick. See
http://www.tamperproof.com/categories/one-way-slotted.html
Doubt if you'd want to buy one for the toolbox but the pic give an idea of how to grind down a couple of pegs on the blade of an old driver if one was really desperate with a stuck one in an inaccessible spot. If you do get the screw out of the distributor fixing at some time, an allen head replacement could be the way to go.
