October 27, 201115 yr Hi all, I have a 1994 Nissan Sunny (Doctor sunny ) with GA14DS engine. 1. Does it use a Timing belt or a Timing chain ?, I'm asking because I recently bought the car. 2. The key is worn-out, having a hard-time putting it in and I guess the key hole is worn-out too , Do I have to replace the entire unit ? What would be the cost ? 3. Power shutters make a noise with the rubber beading, what is the easiest way to get rid of this ? Thanks in advance Edited October 27, 201115 yr by NRX
October 27, 201115 yr 1 timing chain 2 sorry i'm not a expert on this afaik you have to replace the entire unit with new key barrel 3 that sound you are hearing is because rubber beading is worn out or shutter not properly aligned with it's rubber beading.
