H.C Posted October 27, 2012 Share Posted October 27, 2012 As title says ,suprisingly samsung has failed to include car dock audio out and charging functions with jelly bean update.Im using a OEM car dock for infuse 4G which is a perfect match for s3 and all the functions worked fine on ICS . Initially thought that this was somthing relating to my phone and googled it and found out that car docks are no longer supported in jelly bean. Hope this info would help someone planing for an update!. Is there a way to go back to ICS?. Quote Link to comment Share on other sites More sharing options...
The Don Posted October 29, 2012 Share Posted October 29, 2012 I found this on xda developers Hi, did you go to settings> accessory> and tick audio output mode?, if not go back and tick that then put your phone in the dock. http://forum.xda-developers.com/showthread.php?t=1879633&page=2 Quote Link to comment Share on other sites More sharing options...
H.C Posted October 29, 2012 Author Share Posted October 29, 2012 (edited) On 10/29/2012 at 2:09 PM, The Don said: I found this on xda developers Hi, did you go to settings> accessory> and tick audio output mode?, if not go back and tick that then put your phone in the dock. http://forum.xda-dev...=1879633&page=2 Tried every trick including a factory reset. Thank you very much for the link. I went through xda forum and only solution is to run on a custom ROM and Im reluctant to go in that way. They have released us update (sprint) after correcting it. Pathetic part is that,there is no way to contact samsung as our country is not included in their web site. Edited October 29, 2012 by H.C Quote Link to comment Share on other sites More sharing options...
NPP Posted October 30, 2012 Share Posted October 30, 2012 On 10/29/2012 at 5:31 PM, H.C said: Tried every trick including a factory reset. Thank you very much for the link. I went through xda forum and only solution is to run on a custom ROM and Im reluctant to go in that way. They have released us update (sprint) after correcting it. Pathetic part is that,there is no way to contact samsung as our country is not included in their web site. Is this an issue with only Samsung or with Jelly Bean? Quote Link to comment Share on other sites More sharing options...
H.C Posted October 30, 2012 Author Share Posted October 30, 2012 On 10/30/2012 at 1:27 AM, NPP said: Is this an issue with only Samsung or with Jelly Bean? Afik,Its with S3 . Quote Link to comment Share on other sites More sharing options...
