Need Advice On Importing Baby Monitoring System Through Ebay, Do We Need To Get Any Approval?
Aravinda_2011
Hi All,
I am just about to pay through ebay to import baby monitoring system with below spec but not sure will I face problems or extra amounts to be paid to customs seperatly? Anyone have any experience before on the procedure? Please share .
General Specifications *
Transmission Frequency: 2400 ~ 2480 MHz
Transmission Power: 17 dBm
Operating Frequency: 2450 MHz
Un obstruction Effective Range: 250m (820 feet)
Modulation Mode: FHSS
Operation Temperature: 0 ~ 60 °C (32 ~ 140 °F)
Storage Temperature: 25 °C (77 °F)
Operating Humidity: 20 ~ 80 % R.H.
*Camera*
Imaging Sensor Type: 1/3 CMOS
Picture Total Pixels: 628 x 582 (PAL) / 510 x 492 (NTSC)
Horizontal Resolution: 360 Lines
Frame: 25 fps (frame per second)
Horizontal Rotating Angle: 360°
Vertical Rotating Angle: 210°
View Angle: 60°
Minimum Illumination: 1.5 Lux
Band Width: 4 MHz
Night Vision Range: 3 ~ 5 m (9.84 ~ 16.4 feet)
Battery Working Time: 8 hours
Motion Detection Distance: > 5 m
Sound Control Sensitivity: > 60 dBA
Consumption Current: 150 mA + 15 mA
Power Supply: 5 V DC by AC Adapter (100 ~ 240 V for EU / UK / AU / US)
Battery Supply: 3 x 1.5 V AAA Alkaline Batteries (not included)
Dimension (Camera): approx. 100 (L) x 86 (W) x 86 (W) mm (3.94 x 3.39 x
3.39 inch)
Weight (Camera) : approx. 141 g (4.97 oz)
*Receiver*
LCD Screen: 7 inch (17.8 cm) TFT LCD
Effective Pixels: 320 x 240
Receiving Sensitivity: -85 dBm
Video System: PAL / NTSC (Switchable in Setup Menu)
Color Configuration: R.G.B.
Power Supply: 12 V DC by AC Adapter (100 ~ 240 V for EU / UK / AU / US)
4 answers to this question
If you are lucky it will be delivered to your door step and no questions asked. But the official position of both Customs and TRCSL is that you need an approval from the regulator for a frequency transmitting device. Refer to http://spectrum.trc.gov.lk/Low%20Power/spectrum%20allocantion1.pdf for details of what you will have to go through if Customs decides to refer the matter to TRCSL. If the unit is available locally then someone must have got it approved and you would not have much of a problem clearing it unless the Customs make a fuss.
