Turbosmart E-boost Electronic Boost Management System
sanjeewatr
The e-Boost electronic boost management system is the culmination of many years of research, development and innovation, with countless hours spent testing on the dyno, the race track and the drag strip. The e-Boost is the worlds first re-programmable boost controller utilising FLASH memory technology, making it compatible with future software upgrades, meaning your e-Boost will never be out-dated. The e-Boost is more than just the best performing electronic boost controller, it is a complete boost management system, making Turbosmart a world leader in boost control systems. This revolutionary product is loaded with features, squeezed into a package small enough to fit in the palm of your hand. cool
**Moderator removing advertising**
This Single Stage Boost Control Valve allows quick, simple and accurate adjustment of boost pressure. The desired boost pressure can be set to any level your engine can handle. Your turbo will reach the set boost pressure at lower RPM
Dial in any boost pressure
Large Boost Dial for ease of adjustment - no spanners required
The Detent System for precise adjustment
The Gated System to bring boost on faster at lower RPM
Supplied with mounting bracket
Edited by Pericles
I've used the E-Boost on one of our turbo TransAm's and it's a pretty nifty unit. There is soo much that can be done with it, it's just rediculous! You can program it to even make your own boost curves (come up gradually, spike up and then come down to the desired, come straight up, etc.), adjust the sensitivities to boost, and some other crazy stuff (which I didn't go into detail and use) ... definitely a superior system, a bit pricey though (compared to other units).
