In my car, one of the rear brake cylinders is leaking a little bit of oil.
No noticeable drop in level of oil in brake oil reservoir.
(rear - drum. front - disk)
Bass said brake washer needs to be replaced. Am yet to take it for repair.
1). If replacing brake washers, have all brake washers (i.e. rear both sides + front both sides + master cylinder) got to be replaced or only washers in leaking cylinder need be replaced ?
2). Has the brake system got to be bled after replacing washers ?
3). In slow breaking (for e.g. applying brake very lightly to gradually slow down for a traffic light some distance away, in a clear road), occasionally, I feel that the brake pedal goes in a little bit.
Let me try to clearly explain it a bit more:
I press the brake pedal lightly, then I feel some resistance / pressure from the pedal. I am not pressing any more because there is no need to slow down the car more.
The resistance / pressure felt from the pedal is the same. Then suddenly I feel the resistance from the pedal drop a little and since I was pressing the pedal, the pedal goes in just a little bit. Then I push down my foot a little bit and I feel the same resistance / pressure from the pedal again.
This happens quickly and as an automatic reaction of the foot and I don't feel as if the car looses any breaking power or the slowing down rate changes at that moment. Of course when there is a car in front it is a teeny weeny bit hair tingling
The actual down movement felt is very little. I did not find it convenient to observe it. Also this issue happens only occasionally. I cannot create the problem at will.
Another thing, in hard breaking (well not necessarily breaking hard to tilt the car forward , but pressing the break more than I described above) did not notice above behaviour yet.
Can this be due to the leaking break cylinder or something else?
Surrounded by various different nice car models in Germany but still fascinated by the Presea, Bluebird U13 and the Mark II.. The first cut is the deepest.. Baby I know, the first cut is the D he he he
What is the deal with the car market these days!!
I went to check on a Jimny, 2016 2nd owner and he's hellbent on 6.8mil for the thing,
approx 50000km+ mileage
Needs tyres, rear shock absorbers leaking and there has been an aircon repair as well.
(Approx 400k LKR in pending repairs making the total 7.2mil)
Whereas a brand new one can be imported between 8.2-9.5 given the grade and winning bid.
I ponder what the mentality is of the people of this country...🤣
eyepea
Thanks!
7 answers to this question
