ash Posted April 25, 2007 Posted April 25, 2007 Parts shown below should be replaced depending on odometer (milage) or months, whichever comes first under normal conditions. Extracted from Nissan Periodic Maintenance Program. Hope this would help in keeping your ride healthy...... -----------------------------------------------------------20K----------40K---------60K-------80K-------100K--------120K ----------------------------------------------------------(12M)-------(24M)-------(36M)----(48M)-----(60M)-------(72M) ENGINE Tune-up engine------------------------------------------------------●---------------●----------------●------------●-------------●---------------● Replace spark plugs (Conventional type)-----------------------●---------------●----------------●------------●-------------●---------------● Replace spark plugs (Platinum tipped type)---------------------------------------------------------------------------------●--------------- Replace fuel filter (Except in-tank type)-------------------------●---------------●----------------●------------●-------------●---------------● Replace fuel filter (In-tank type)--------------------------------------------------●------------------------------●-----------------------------● Replace air cleaner filter-------------------------------------------●---------------●-----------------●------------●-------------●---------------● Replace radiator coolant-----------------------------------------------------------------------------●---------------------------●-------------- TRANSMISSION Replace N-CVT fluid-------------------------------------------------●---------------●----------------●-------------●-------------●---------------● Replace ATF----------------------------------------------------------●---------------------------------●---------------------------● Replace LSD gear oil------------------------------------------------●---------------●----------------●------------●-------------●---------------● Replace Hyper CVT fluid-----------------------------------------------------------------------------●--------------------------------------------● Replace manual transmission gear oil-------------------------------------------●-----------------------------●------------------------------● BRAKES Replace brake fluid-------------------------------------------------●---------------●----------------●------------●-------------●---------------● A/C SYSTEM Service A/C system------------------------------------------------●---------------●----------------●-------------●-------------●---------------● Replace ventilation air filter--------------------------------------●---------------●----------------●-------------●-------------●---------------● WHEELS Check/adjust wheel alignment & camber-----------------------●---------------●----------------●------------●-------------●---------------● GENERAL PERIODIC INSPECTION General mechanical, electronic & electrical---------------------●---------------●----------------●------------●-------------●---------------● Quote
