Twin Turbo
    51
  1. Welcome! You're better off driving a Toyota . At this stage your still thinking like an accountant.get a rav4. Cheers! TT. P,s i'm sure some will wake up to a fit reading this.
  2. The key to long life with these 'snail shell' horns is keeping them away from water ingress. fit them high so they face down, water from flooded roads and service stations will kill them. parts shops at Dar== road will fit these in mins. there's a model whichplays sirens too.
  3. Fuel pump output pressure low?
  4. Msg'd you the address. .hope they'll be open Good luck!
  5. Just remove the valve cover. it's healed in place by two bolts in the 3K engine if I remember correctly.
  6. BEFORE you awaken more horrific memories from the past, adding to Davy when if ever did you at least last change the air filter? and does the enginereely rev parked in N ? if not, the fuel delivary, exhaust must be looked at.
  7. This would come under extreme driving conditions. switch to L or 2 on the auto selactor next time. Do an ATF change for safety if you haven't done so , before the thing gives you headaches.
  8. chk msgs
  9. Did you do a speed test just on your wsay home from the reparer?? did you seaon the engine? what oil is in the engine now? Your list of parts dosn't include a timing chain - just an observation,, not related to your oil burning.
  10. Perhaps, AL as a community should forward these issues to the authorities in-charge of fuel stations in our country.
  11. You can do a compression test without dismantling the engine.
  12. How have you come to the conclusion that your car engine needs an overhaul?
  13. That's why I keep a mini air compressor in my boot.
  14. Good thing you noticed the slight over heating The T.valve may have been removed to 'fix' an over heating issue by a previous owner. try checking the car with the engine nd a/c on to see weather the cooling fan properly works? and clean the coolingg fan fins from any dust/debree blockingg it. (air goingthrough the rad ) 0
  15. Will the engine rev above that without a load? parked in neutral. The previous owner may have ha a good reason to go to smaller injectors, maybe wanted to save fuel? any idea of your current fuel consumption?
  16. get your battery checked and posts cleaned.
  17. Going back to the contaminated fuel issues and my concerns with the accuracy of the pumps. Not to mention the fact that the cheapest fues is imported here suppliers . it's a good thing that at least the car runs!
  18. Ye olde American saying, goes 'be American, buy American!'
  19. Any chop shop from Delkanda to Panchi, will take have 2c engines, just a matter of finding a seller willing ti dismantle and sell you parts.
  20. Prob done in a bid to save fuel.Why re-invent the wheel? Enjoy motoring,./ TT. p.s .Take it to the agents and get them have a look at it. maybe your car IS fwd?
  21. TRY Semini motors panchikawatte. Agents for seiken jap
