Ripper
Everything posted by Ripper
  1. did not want to flame the fire but i do agree with you. Not all rich folks are corrupt and there are plenty people who have enough money to afford cars better than a db9. just that not all are interested in dumping that sorta money on an automobile.
  2. Ripper replied to tesla's topic in TOYOTA
    you can get a matching ECU from a breaker joint for about 8-12k. I had a similar problem sometime back...agents said to replaced the ECU. which i did but still the car wouldn't perform properly. Then they traced the problem to a faulty delco in addition to the faulty ECU. I had the engine RPM dropping issue until one fine day the car refused to start. My guess is that the faulty delco ignition coil somehow chewed up the ecu. Replaced both and the car was fine... However it's best that you check the entire efi system before replacing parts. It can be a much more simpler thing like a faulty sensor somewhere.
  3. those are generally called "trailer bikes" or trail bikes in SL I have two myself both street trails though...honda mtx200 and honda xr250 If you're looking for a motocross bike... a CR, CRF or similar from another brand is the way to go. And some folks in SL call them "thoroughbreds" since its more competition oriented. as for hunting one... newspaper classifieds might be your first starting point. there are few classified sites that have loads of bike listings...might wanna check that too
  4. the delco unit can control ignition timing to a certain degree and you can either advance it or retard it when needed. sometimes certain people tend to advance the ignition timing to makeup for some other problem of the car. Especially if the engine is not running well at. low idle or have other idle control issue connected to AC system etc...your average maka-baas would advance the ignition to mask the problem rather than fix the core issue. I would take it to a good garage and see the real problem before replacing the delco straight off. A jap used delco from a breaker joint should be around 8~12k. I replaced one sometime back for 10k cos the ignition coil inside the delco was "leaking"
  5. bi xenon means that both high and lows are hid. low beams are generally for fog lights whilst high beam only version has a regular halogen as a low beam. HID's dont have filaments so bi-xenon feature is usually achieved by moving the bulb unit up and down using electro magnets. another alternative is to upgrade to a good set of 55/60w bulbs. genuine PIAA bulbs put out a lot more light than your average bulbs even with the same wattage
  6. you can jump start it easily. drop into neutral....push it fast a bit and quickly jump in and shift to second... that's what i do when the battery goes south
  7. Ripper replied to The Stig's topic in General
    TUAN MOTORS. 12 Jesmine Park, Narahenpita Road, Nawala
  8. a friend who owns a black mark X has been quite content with KleenPark detailing...
  9. rainX can be bought from motorcade. also there are alternative products that does the same job. There is another one called RainKick. works pretty well. armorall winshield washer fluid was available at arpico super centre in wattala. That's where i bought it from. Gnerally in my experience, arpico has far more automotive stuff than any other supermarket chain
  10. i've been using armorall windshield washer fluid for a while. pretty cheap and does a darn good job. Rainy season, i use rainX as an addition. On heavy downpours it really helps.
  11. Ripper replied to KFL's topic in TOYOTA
    1+ startup white smoke.....not present while running... usually sounds like a valve seal issue. Not a biggie to sort out cos it's only a top end job. Does the car smoke significantly more of you start it after resting it for a few days? Does the smoke disappear completely after the engine runs for a while? If this is the case...get the top end valve seal attended to first and see how it goes... even for a ring set replacement...the engine has to come out. Significantly more complex job than just sorting out the valve seals...
  12. Ripper replied to The Stig's topic in General
    i'm assuming the head needs to come off for a bearing job.... have done this on my bikes but not on a VT. but i suppose it's more or less the same generally, you'd have to get the cables, switches etc off the handle as the handle needs to come off. depending on design...lights, meters, fairings too might have to come off. you'd have to remove the front wheel since triple clamp needs to come off Once you get the triple clamp cleared of any obstructions...you can remove the main nut holding the steering head. you might have to remove the front shocks before removing this main nut so those wont meddle with you as you try to get the steering head out. Then it's matter of loosening the nut holding the steering stem and pulling it out....usually from the bottom. If the bearings are shot...you'd idealy need a bearing puller to take it out. Some people use old screwdrivers to beat it out but i would not recommend doing that. I'm sure you might be able to find a youtube vid on how to remove this on another bike. It's DIY for an advanced DIYer...if you haven't done much DIY stuff i would leave this sorta thing to a pro. Might wanna check with MD for a paint chap as i to am not sure of a good guy. Need to put some color on my XR too but haven't found a decent joint yet. As for the mechanical part....most bike garages should be able to sort this out without a huge fuss. I would usually only check up with bike garages who extensively work on large displacement jap bikes easy to spot cos these guys always have some good bikes getting attended. If you can't find a joint...i would recommend tuan ossens's garage in nawala.
  13. sounds good cyclist. the oil filter meant for an indian bikes...i would never take a chance with an oil filter mate. always use a quality one and at that price....one would assume it isn't of good quality.
  14. afaik....at the moment....you cant register atv's or quads as road legal. no license category or even a registration category for them. many people use them in private properties though. as for bikes...there are plenty large displacement bikes running about with falsified docs. most are registered as 250's. So i don't think you can legally ride anything over 250 on public roads.
  15. yeah machang. we went off after the first runs of the two GTR's. saw your first run too. coppers bogged the show for us after forcing us to get into the park...
  16. was there at the drags from 9.45 am with my junior. couldn't carry the camera cos i was with my two and a half year old son. great to see some great cars running there and shockingly the legendary GTR getting its arse kicked. I left after the white and darin's gtr ran their first races. White GTR lost pretty badly to what looked like an evo 3. to the organizers if you're reading this... this is purely constructive criticism Crowd handling wasn't done properly and people were getting chased by the cops from one spot to the other. Our troupe was asked to leave from where were close to summer garden even when were behind the steel railing. We had to cross the road and move into the park and stay in the hot sun with our kids. Briefly after we were asked to leave from our earlier spot which had access to food and drinks stalls including beer from summer garden, people who came later to the same spot were allowed to stay by our super intelligent coppers. The PA system that was announcing events cant be heard for the entirety of the track. If you're close to the start line you're fine but even towards the middle, you can't here anything Races did not start on time and the time between individual events was far too long. Basically lots of time wasted without seeing any action on the track I'm purely marking these observations when comparing to other racing events that happen around the country. I'm sure since this is the first time this sorta event was held...there will always be issues to be ironed out So hopefully, next year...things will be a lot better. Great job by all those behind this effort to finally bring drag racing to a more safe arena.
  17. i doubt it machang...almost everyone i know who has any interest in cars are planning on coming for this event... so chances are....it will be super jam packed
  18. Andrew Any idea on the setup for spectators, snappers and the like? Tickets? passes? I'm assuming the place will be jam packed and it will be mighty tough to control the crowds... Last time redbull brought down those stunt riders, it was a bloody nightmare to even use approach roads let alone entering the grounds... having the drags in daytime is a great chance for snappers If one can find a decent perch that is
  19. actually global oil prices went down a bit and not up!
  20. Ripper replied to Zambo's topic in General Automotive
    dude...no offence but with posts like these...you just make an A$$ out of yourself. you dont even have a car yet by your own admission...that's the starting point in anything. Wouldn't it be smarter to first start with a car, get an idea for a timeline and a budget and take things from there? most audio shops can do up a good sound system. and good ones do cost a lot of money to be done right. performance mods are another ball game. can't even comment without a car being named bodykits, plenty joints light and rice stuff....easy to find plenty workshops/suppliers ps. "mega bass speakers" are those super sci fi things called subwoofers.
  21. must be a vacuum line mate
  22. Ripper replied to Nisala's topic in TOYOTA
    try panchikawatta....esepecially the watta area...
  23. congrats machang! if you attend to those issues and look after it.... it should server you well I would not attempt to repair the rear shock here mate, you should be able to pick up a decent used one from a breaker joint. My rear shock too is kaput and i suffered big time on a round the island trip. having a your shocks in good order is a must imho. good luck
  24. well those are the two famous joints and didn't know that mazna was expensive. Do you have a particular case where the prices were unreasonable?
  25. absolutely agree. i sometimes wonder when people post certain replies with certain claims whether they have ever owned the vehicle in question in the first place we have far too many posers on AL these days During my young and dumb days...used to race with a few RZ's and TZR's. There was this blue RZ125 i used to meet almost everyday on my way to work and we used to ride pretty fast together. never knew who the chap was...hitting 120 consistently was no biggie... I was riding an MTX200R.... light, nimble and fast... it's a miracle i manage to survive those years :) I've even lost control and gone into a canal completely dunking the bike....except for a badly bruised ego...nothing much happened to the bike. Took it home...drained all fluids, cleaned up all the water and it started the first kick... If not for the irritating sound and oil splatters on clothing...i would still love to be riding a 2 stroker
