terrabytetango
  1. That's a drain for your transmission. It's supposed to be there. What you found was most probably water mixed with oil. Check your transmission fluid level, if there's on drop then forget it.
  2. Did the WD40 thing, tried wooden block and hammer as well. Didn't attempt it again. My next option is to take it to my mechanic.
  3. The topic is about a Vios, who cares about a Belta?
  4. IAC, had this issue in the ShitBox. It would just die when I let off the throttle and push in the clutch as I was slowing down. Sometimes happened mid-turn, the steering goes heavy very suddenly, but usually started again by popping the clutch immediately. In my case, this behaviour only starts an hour or so after the car had properly warmed up, and time of day made no difference (some people attributed heat soak while stuck in traffic at mid day).
  5. but you didn't, since you said CVT.
  6. Tried removing the cowl once to clean the leaves inside, bloody wiper arms wouldn't come off no matter how i tried and I was afraid of breaking something so I gave up. Any tips on how to get the arms off? It looks like they've bonded to the splines.
  7. So whenever it rains AND whenever I park at my parents' place, the climate control in the Shitbox goes out for a day or two. I figured it to be water ingress from the very beginning, but since the problem goes away, I never really bothered to check. This time the problem lasted for more than two days, so I decided to dive into it. The glove box comes out, as does the metal bar on which it is mounted. The climate control module is inside a plastic case, but is not sealed *at all*. I gave the module a thorough cleaning, and then lightly covered the thing in dielectric grease before replacing it back inside the case. I couldn't be arsed to figure out where exactly the water was coming in from, as it only ever happens when the car is parked on an upward facing angle, when it's raining *hard*, so I've chalked it up to some kind of design flaw (of which the Starlet as many).
  8. This happened to me twice. Check the DIY section, I'm posting my experiences and the fix for it.
  9. So here's some documentation of a bit of DIY I did some months ago. The driver's side window motor fried itself, along with the automatic mechanism and a hardwired fuse on the PCB. It didn't occur to me to properly document this at the time, because I was pressed for time, so the photos were taken mainly for my reference. Cleaning the power window contacts is something everyone should do on a 20 year or older vehicle. The amount of carbon build up on the contacts is insane. I ended up disabling the automatic mechanism because I believe the thermal cutout it uses to no longer be reliable. The post is short, so feel free to ask for specifics since there are many.
  10. The 2006 Vios has a regular automatic, not a CVT.
  11. Former Vios owner, ran one for 4 years. Mine never did over 10kms/l in Colombo, and 8-9 was common. I was happy when ever I got over 300kms from a full tank (at the time of the low fuel indicator coming on). The Vios is an excellent car, and I wouldn't go to tinker too much with the fuel efficiency by taking it to various garages and asking the maka baases to do their voodoo magic on it. Take it to Toyota Lanka, ask them for a tune up, and maybe an engine diagnosis, it could be that you need a sensor replacement somewhere. Do not use 95 octane, I have never seen any benefits, and my car actually did slightly worse on fuel on 95.
  12. terrabytetango replied to sosh's topic in TOYOTA
    Look for an Axio with manual transmission, those are bargains these days.
  13. it's still the shit box Broke a window rail mount 2 months ago, replacements arrived last week, going to have a blast of a time (not) removing the broken mount from the glass. I need to do some mild tuning mods for more mid range torque. Edit: Also found that mine is the X-Limited, which I think is the highest grade one get, apart from the Gi, which is the Turbo look without the turbo bits and available only with the 2 door versions.
  14. Ah no, mine doesn't have that nor automatic climate control. I was just looking at pics to identify if mine is an X or Soleil.
  15. To answer both questions, the pictures are of a 1991 EP82 4 door. it's got all the bells and whistles, including automatic climate control, which I have only see on Starlet GTs prior to this. And thank you iRage, your knowledge of obscure JDM oddities is much valued!
  16. Does anyone know what the gauge on the right is for? It shows the angle of the front wheels... but for what purpose?
  17. Ripped the door open last weekend, door panel connector's power pin had fused and melted the assembly, required significant force to take apart. Driver's window is on a separate circuit, an old school metal wire fuse had melted, plus heat damaged PCB with a scorch mark on the reverse side where the fuse is. Soldered a 16awg wire to jump the connection, and the motor receives power, but does not turn, plus continuity is there as well. I suspect there's a short in the winding, going to replace the motor with one from the rear door, and then buy a replacement/rewind the motor later. Thanks for the help!
  18. Another revision of an already shitty car.
  19. My wife has one. Around Colombo, we're currently maintaining 15.3kmpl. It's a slow car, the reason why people report only 11-12 kmpl is because they try to overtake everyone on the road and expect it to keep up with other cars on the road while accelerating i.e. right foot on the floor most of the time. If you want any semblance of fuel economy, you have to drive slow, and you have to plan ahead because of the laggy CVT gearbox. Apart from that, it's a pretty good car, 3.5 or 4 star safety rating in Japan, and comfortable enough on most B type roads. If you're always in a hurry, this isn't the car for you.
  20. The EP91 Starlet, especially the later models are solid performers, and are right around your budget for a very good example.
  21. My dad had taken the shitbox out a few days and remarked the central locking wasn't working. When I checked, the entire door switch panel was dead, so I set about undoing the lower dash panel to get at the circuit breaker. Once reset, everything worked, except the driver's side window; there's no sound nor any indication that the motor is straining on anything, not even the slight dimming of the headlights. Have I missed in checking anything else, or should I straight away get to tearing off the door panel and inspecting the motor, switch and wiring? P.S. Shitbox = 1993 Toyota Starlet
  22. My nearly two year old Axio has these exact same features. It's called Safety Sense C, and there's Safety Sense P which also watches out for pedestrians in addition to cars.
  23. Greetings everyone, and a happy new year! It has now been over 14 months since I've acquired this car, and during the xmas weekend I achieved two milestones. The car achieved 600kms on one tank of fuel, with at least another 80 kms remaining, and secondly I managed to get the battery to charge all the way to the top, during several downhill stints. The journey was from Colombo, to Belihuloya, and then to Ampara (Buddhangala Monastary). 3 passengers, plus enough luggage to make the car scrape on a pebble. Total mileage is only 15K kms, but suffice to say the car is still daily driven for over two hours, albeit short distances in traffic, thus the battery does get a workout. Another surprising find is that the LDA feature works *really REALLY* well on A roads where markings are clear, even on the twisty bits. It identifies broken lines, continuous lines, and the parallel continuous lines with no issue at all. Not really sure why I'm surprised, but considering this is Sri Lanka, the fact that anything works is really quite miraculous.
  24. The engine will be under strain in D (or any lower gear) and R, so there might be increased vibration and a lowering of the engine note. It was quite discernible in my Vios, however excessive vibration is an issue.
  25. Considering how reluctant current owners are to let go of their Solunas, I do believe it's a solid car. And don't let the fact that it's made in Thailand put you off, my Vios was as solid and reliable as they came.
