Kavvz
Everything posted by Kavvz
  1. Kavvz replied to MADZ's topic in The Lounge
    You want to date a fat bald guy?
  2. What are you getting ? As in what engine and trim spec?
  3. Kavvz replied to MADZ's topic in The Lounge
    Really? Bad scene. There's really nothing they could have done different to prevent that accident...lucky for them that the CCTV recorded what happened, else they'd probably be taken to task over what happened as well!
  4. Kavvz replied to MADZ's topic in The Lounge
    What I meant was rather than get beat up by the thugs in the Prado, he should have pushed the jeep put of the way and driven off (to the nearest police station) asap for protection. Perhaps that's too aggressive but its what I would have done, and really if someone's looking to assault me, personally speaking damaging private or public property in my attempt to protect myself is in my mind- justifiable... I'm not condoning street racing or highway code violations to pick up passengers but I don't believe that individuals ever have the right to take the law into their hands. As Pericles points out; the system may be broken or corrupt, "but the attempt should be the fix the system, not go outside the system" else things get worse.
  5. Kavvz replied to Le Sabre's topic in NISSAN
    Err...Is this is a reoccurring thing that you have going on? Any other dreams or fantasies you want to share with us? No worries, I'm sure Pericles can take care of himself; but I'm sure it'd make for a hilarious outing. One minute you'll be driving along clam as can be; and in the same breath you'll go tearing off behind some car because: "It was a Presea and a girl was driving it" / a girl was in the passenger seat of it!!
  6. Kavvz replied to Le Sabre's topic in NISSAN
    Yeap the dude's quite loony. Good luck to Pericles on the upcoming photo shoot / trip...Hopefully he comes back safe!!
  7. No this isn't for the fog lights its for the main headlight / high beam and low beam (and indicator bulbs); and this is the case in most of the newer Nissan sedans with the wrap around style boomerang headlights. You could go underneath the car; but that means taking off the wheel liners and reaching underneath through the wheel wells. The repair / maintenance manual lists taking off the bumper as the standard procedure; but on user forums members have listed work more practical work around methods for the passenger side, like removing the wiper fluid reservoir to gain access etc. but for the driver's-side changing the bulbs necessitates removing the bumper or taking off the wheel-well liners for access. Either way its dumb but then again we had the same shit set-up on the VW we used to have (where you had to take off the bumper for access to the headlights). But at least on the newer VW's they've got a removable flap in the wheel-well liner for easier access; a practical idea that I hope Nissan ends up following...
  8. Because car manufacturers are stupid. And because they vary in levels of stupid they use different types of bulbs based on the degree of the design engineering team's overall stupidity. Eg. I have H9's for high beam and H11 for low beams. Why? Why give me a low powered bulb for my low beams and a high powered one for my secondary high beams (which I use less often)? Because the high powered bulbs burn out faster and because you need to take the entire front bumper off to replace the bulbs. Since its a drag to keep taking the bumper off, and swapping out high performance bulbs when they burn out; I guess they thought the solution was to have low powered bulbs as the primary source of light. Great, so here I am stuck with shitty lighting or with the option of pissing off everyone on the road by using the high-beams. Why did they design a car like this, where you have to take the bumper off to get at the light bulbs in the first place? 'Cos they are stupid.
  9. Yeah, I agree with NRX, it sounds like road noise due to tyre wear / uneven tyre wear etc. Its probably not your shocks or anything else if the noise changes based on the road condition, (noise from the bearings / razors is distinctly metallic and increases and decreases as you speed up or slow down. Noise from the control arms etc, is more of a knock as you go over bumps / take corners so I don't think its any of those either) By the sounds of it, no pun intended, perhaps its time to get some new tyres? Usually tires with small tread gaps are usually quieter on road. If you want to source a good quality quiet tire, reading reviews online (try tirerack.com) is a good starting point as usually online tyre sites rate tyres on how quiet they are on the road vs grip in wet / dry conditions etc, plus they have user reviews which is always helpful. Continental ContiProContact are a good option (Continental sells tires under different brand names too at different price points so google around a bit once you find a tyre you like you might be able to find a similar version under a different brand name for cheaper). Michelin HydroEdge used to be a good option for quiet good overall tyres too, but I haven't been able to find then lately, not sure if they are out of production...
  10. Kavvz replied to MADZ's topic in The Lounge
    I couldn't disagree more. If everyone jumped out of their cars and beat up other drivers for violating road rules it'd be anarchy, As annoying as bus drivers and tuk-tuks are I don't think anyone has the right to beat them up...nor should we promote such idiotic behaviour. Its a shame the other bus drivers or people who saw the incident didn't stop to help out / fend off the thugs in the Prado.
  11. Kavvz replied to MADZ's topic in The Lounge
    Doesn't give the thugs in the Prado any right to attack the driver or the bus conductor. Pity the bus driver didn't simply push the Prado out of his way and drive off, he does have steel bumpers on the bus after all...
  12. Kavvz replied to MADZ's topic in The Lounge
    we know of this group? First I'm hearing of it...: Link please?
  13. Kavvz replied to MADZ's topic in The Lounge
    lol ! Got a link to that fb group? I've got some fuel economy pictures of my own I'd like to share with them
  14. Kavvz replied to MADZ's topic in The Lounge
    Its not often that I'm impressed by a van, but wow! Totally bad ass!
  15. Kavvz replied to MADZ's topic in The Lounge
    Yes, you goda sudda. You're the only one. ( Next thing we know, you'll be wanting to reinstate the Queen of England as our head of state...) There's no Ceylon, there is no Ceilao, there is no Taprobaba, there is no Lanka, there is no Sihaladeepa, there is no Ilankai, and there is no Serendib. The name of our country is Sri Lanka and everyone who lives there on a permanent basis is a Sri Lankan. The end.
  16. I guess you don't drive up in the hills much? Just like having someone who doesn't ask any questions but shows up with thick slabs of butter cake and steaming mugs of tea when you get in at 10pm; heated seats are not essential but are nice to have up in the hills when the temperature drops ( Jokes aside for people with back problems heated seats are a life saver, yes even in Sunny SL )
  17. Kavvz replied to sira's topic in TOYOTA
    lol ! I guess THIS is why everyone is so afraid of white vans? I don't blame them !!
  18. Kavvz replied to sira's topic in TOYOTA
    Yeah man, and all the better if you have a white van: The public loves white vans, they are a very popular form of transport. People love it when you pull up and offer them a 'free ride'. For maximum effect rope in a couple of heavy set friends when going out and offering these rides...
  19. Kavvz replied to MADZ's topic in The Lounge
    lol! Funniest thing I've seen in a while!!
  20. Nopes, just stick it in with your laptop. Its rare that they ever ask me to open my bags, and even on the odd occasion that they do, they just glance over at the laptop bag and I assume they just think everything else in there is some sort of computer peripheral as they never check any further. Or stick it in with your camera lenses, they never look through that either...
  21. Ah I see. I would say that variety (in thought and opinion) is what keeps our threads interesting; but I guess that's one way to look at it as well
  22. Kavvz replied to MADZ's topic in The Lounge
    Lenny B. Robinson, the “Lamborghini Batman” who dressed as the Dark Knight and visited children in hospitals with his black Gallardo, was killed in a car crash along I-70 in Maryland last night, according to news reports. He was 51.
  23. Thank you. I'm glad you understand. Now I don't understand. So you mean to say the Vezel is good? (Its common as in everyone likes it, therefore they buy it, therefore its good.) Again another ambiguous statement that I disagree with: An Internet forum is defined as a space / site 'where people can hold conversations in the form of posted messages'. And I don't know about you, but where I come from, its normal to have different opinions / point of views during a conversation. Its completely okay to have contradictory view points as not everyone thinks alike and not everyone has the same skill or knowledge level. Engaging in informed conversation is a way to share that knowledge. Contradictory to your thought that anyone with a differing opinion should not post / should not be on this site, my thought is that if everyone had the same opinion then its not really a beneficial conversation / discussion thread as it just becomes a mutual backslapping / admiration session and very little knowledge is gained or shared in that type of conversation. Your thoughts?
  24. Ah? What?! This thread is AWESOME, and I take offence at your defamatory statement and I object to such unsubstantiated claims. You might as well get up on an election stage and sling some mud around! Tell me my friend: Are you're saying that the Vezel is shit? Or that the Vezel is NOT shit? And Why exactly is this thread a waste of time? Aquaman and the other Autolanka members who have posted here have put a lot of effort into making this thread as informative as possible (while respectively expressing their opinions in a free and generally fair manner). Do you not appreciate their input?
