mazdaspeed
Everything posted by mazdaspeed
  1. This was the same case for Nissan N 16. Failed it several times and did all sorts to get it fixed. The bloody car does not have an oxygen sensor - thus the fuel mixing is done though a manual unit which does not change as per the ones which has an oxygen sensor. So once I left the engine running for a short while, it passed. This was explained to me by a mechanic who worked for AM@. Mind you when I took the vehicle to AM@ with the issue, their reply was that the car was manufactured in 2007 hence emissions can fail.
  2. @tbird Congrats on your purchase- She looks nice. Do update the fuel figures also- that way users may be convinced to look at Ford as an option as well.
  3. A hard task- Drop me a PM with your number and I shall send some persons
  4. I too suspect a faulty Ignition coil - the issue is that when you run the scan, the coils might be working fine, but when running it suddenly decides to give up Has the petrol filter and pump been checked. ? Replacing them at 100K is recommended.
  5. A known person is looking at bringing down an Audi A 1 but the issue is in servicing. Any one know how well the Place in Borelasgamuwa is equipped to handle the A1 and the like ? Any alternatives? I thought there was a new dealer for Audi ? if they is wonder if it’s the same stance
  6. Mazda does not use the piston version of compressors and the noise is a common problem. Like Twin Turbo said try oiling the compressor at a AC service center. Timely servicing of compressor and system is very important for Mazda
  7. Hi Members, Seeking your help with regards to some one who knows his stuff who can repair a Denon Home theater system – Model number is AVR-2105. It does not power on and was working fine till one day it just didn’t power up. The unit is an old model but sounds and stuff are excellent. Please PM me with any reliable source ideally guys who deal with sound systems . Thanks
  8. Need some advice guys, a long story short – I’m using a N16 and it failed the test (First time ever that a car of mine has failed) I’ve taken it to A*W and they have scanned and said the MAF is OK, replaced plugs & air filter with genuine Nissan parts, cleaned throttle body & Injectors as well. However I did not do a very aggressive run like some have said, will that help ? The mileage is 180K + and I’ve never replaced the MAF, or throttle sensor. A*W said all was fine after I gave it to them and it failed again ( Yesterday) so called and blasted them, wanted me to come again – but loaded with work and it’s a challenge. Any specific place or direction I can take .
  9. also Ichiro Motors highlevel road , they had a few in stock.
  10. Hi, Did u try pleasure racing services - it's in front of Arpico at Nawinna. They stock and bring down Subaru parts Good luck
  11. Logged in after ages, and What a site ! Absolutely Fab. Good luck with the rest.
  12. ya can't agree with you more - Looks like his leaning of driving "L" is going through a whole new shift s in the English alphabet also..... Ironically it's got a CP plate ......
  13. You have difficulty in parking a Maruti with no power steering ????? Geez
  14. Absolute BS ...... Colonial can do all related repairs and they are the agents too NOW. Besides there are several other places who can do it. PM me if you want some contacts both with the agent or outside
  15. dropped you a pm with my contacts
  16. Hi NRX Took the Nissan today to Pitstop- it’s not my first time there as I use to take my mothers wingroad there. But it’s been ages since then. Changed all oils engine, gear & break oil. Did a T.Body clean up and plugs were OK. The axel boots were gone so need to replace them along with brake pads. Surprisingly P.Stop did not have the boots, the brake pads and also the injector cleaning fluid. So injectors were not cleaned – However I was billed for the same. When I inquired they said it was a part of the engine tune-up which I requested. When I explained to them that my injectors were not removed or any liquid out in through it – they checked with mechanic and reduced the amount. Will do those through a genral mechanic and also need to get my fuel filter replaced – They too advised it. Thanks a once again for the help – Got several doubts cleared through them.
  17. NO- That I could have understood. This version does not eve have the option of moving the mirror /adgesting it . Planing to get power mirrors instaled with switch later .
  18. Yes planned to do it over the weekend- noticed the axcel boots were damaged and skreeching sound (not often) from the front breaks - looks like a disk faceoff & new B.pads needed THANKS once again
  19. Hi NRX, Thanks for the post, and info really helpful. My one is a 1300 Manual version and I think it's the N17 face lift or what ever they call it. Agreed the interior sucks .... I live in Dehiwal so the Kalaniya option would be good for serious repirs - for small jobs need to get hold of a local place. Rsg
  20. Ahhhh Thanks a million – Finally some solid info. Replaced the air / AC filter – full of muck. The fuel is not that great so would need to go for a tune up as u recommended. Can pitstop do the throttle body cleanup and tune up ? Anyway will try Dhamika or Mario for the first time. Yes it’s a 1300 cc – and Yes a big mistake as the car is large. I still do not understand why a simple feature like power mirrors is not an option in a 2007 YOM car. On the question as to why I bought it – Well as I’ve said a load of complications
  21. Sluggish , uncomfortable, lousy handling + many more
  22. Dear members, Need a bit of help from you all. A long story short – Due to various issues and complications I’m now confined to a Nissan N 16 1300 cc ( Sunny) - Hating every bit of it . (Now lots not get in to any bashing so sorry if I offended any Nissan Fans) Could any of you please share some info on : A good place who knows his stuff around Nissan The plugs required for a 1300 CC Common issues and what to look in to Good place for general servicing A location to download a manual – Searched but difficult to get info on N16 , they show up other names Thanks in advance
  23. Try Kids Unlimited - Dutugamunu street - Kohuwala had some good collections yesterday when I went
  24. Nice write up Davy, Thanks for sharing
