Everything posted by maliths
I Need To Be A Automobile Engineer
Hi, What sort of degree have you got now? Im guessing its a software related one? To me an Automotive Engineer would be someone who designs/manufactures automotive systems. The German Tech course look as if they are mainly aimed at the Auto/Mech Technician type courses. If you want to be an Engineer I'd recommend a proper Mechanical or Automotive Engineering degree from a place like the Open University. This will really give you a good understanding of the fundementals of Engineering. What sort of job would you like to do in the Auto industry? MalithS
- Post Whoring - Part 2
Quick Trivia Part 2
Is that Brum?? http://en.wikipedia.org/wiki/Brum_(TV_series)
Happy Birthday Mivec Turbo!
Happy BDay Dinesh
Ac Usage
Hi, If you have climate control why are you switching the AC on and off?? If you set the desired temperature the AC will engage and disengage when its needed to maintain a constant temperature. When it disengages it stops the compressor and only the blower is on and even then the blower will speed up/slow down to maintain the temperature. to answer your questions: 1. If you have climate control what you are doing is unnecessary I think. I dont see that it will damage the AC. Maybe only wear out the on/off switch 2. Every time the AC is off it will increase fuel economy. Generally I think its atleast 10% (depends on hot hot cos the AC will work more). But again if you have climate control the AC will do this for you automatically to maintain the temperature so there is no need for you to do it manually.
The Green"econo" Led On -ek3
Bloody hell that would mean its doing about 85MPG You'd be lucky to get about 60MPG (22 km/l) with even a modern diesel
Happy Birthday Masterdon!
Happy Belated Birthday Don... Hope you had a great B'day and hope you have a great year
Oxygen Cylinder (where To Get)
Well putting in a little pure oxygen would provide a small increase in power as an engine doesnt normally get enough oxygen to burn everything anyway (In theory), I dont think it would make it run leaner as long as you dont increase the total volume of air taken in but to get a significant increase you would have to add more fuel to take advantage of the increased percentage of oxygen in the cylinder to get a full burn (to get a proper air-fuel ratio). O2 would have a similar effect to Nos but to a lesser extent, Nos system also introduce extra fuel as Nos is injected to make a proper Air-Fuel ratio. But keep in mind that putting pure o2 into the engine could cause severe damage as the o2 would cause the air-fuel mixture in the engine to ignite earlier (before the spark) as 02 is quite volatile as high temperatures and could cause a uncontrolled burn or explosion whereas the Nos only breaks down and realeases the oxygen molecules after the spark has ignited the air-fuel mixture. There will also be problems with the extra heat as the Nitrogen (70% in air) normally helps absorb some of the heat from the combustion process and also helps to push the cylinder as it expands due to the heat. This is probably why we dont see O2 injection on engines.
More Oxygen into the cylinder = better burning of fuel = increase in power
Dkw
Gorgeous...... Excellent piece of work
Changing Shocks
True when these are re-conditioned they dont really perform the same way they did when new as these wear and re-conditioning doesnt really take it back to its original state. The ones that Mini tried were probably overfilled of maybe the density of the hydraulic fluid was higher than the original giving the firmer ride. Best thing to do is get new ones.
- Quick Trivia Part 2
Quick Trivia Part 2
Maruti Wagon R ??
Chevy Camaro Spotted @ Vauxhall Street
Thats from the other thread about this car
Tuning And Timing?
Hi, If you are referring to ignition timing then you do not need to check this as the ECU data wouldn’t really change. Most cars have the engine maps stored in the ECU and they do not change (some even cannot be changed). There are newer cars where you get programmable ECU and you can modify the maps for performance etc. Also on some new models there is a thing called a learning ECU where the ECU has a set of base maps stored but it then 'learns' and tweaks these setting to achieve the best performance depending on your driving style. So a car that is regularly floored and one that is driven very smoothly will have slightly different setting because the ECU changes the settings accordingly. By the way I don't know what sort of ECU comes on a FB15. Im guessing it could be a non programmable one. Just a guess. MalithS
Tuning And Timing?
This wont be a comprehensive list but I guess a tune up would include the following: Checking and changing spark plugs Checking and cleaning the sensors Cleaning of throttle body etc Checking and clearing errors on the ecu Filters Its basically doing a check of everything and giving it a good clean. Tuning and Timing are two things. With timing you get the ignition timing and the valve timing (controlled by the timing belt or chain) Valve timing controls the timing of the valve. when they open with the movement of the pistons to let air in and exhaust out. This doesnt not need to be adjusted.Some engines have Variable Valve Timing. In such an engine, the ECU controls the time in the engine cycle at which the valves open. The valves are usually opened sooner at higher speed than at lower speed. This can optimize the flow of air into the cylinder, increasing power and economy Ignition Timing is what controls when the spark happens in the engine relative to the piston position. This is usually adjusted throughout the engine RPM range by the ECU to maximise efficiency and power. The ECU data controls when this happens and is stored in a timing map which is a table with engine speed on one axis and engine load on the other axis. So depending on what load and speed the engine is doing the reading is taken off this table. Hope this helps
- Happy Birthday Madz
### Happy New Year - 2010 ###
Wishing everyone a Happy New Year
Happy Birthday Devinda_z!!!
Wishing you a very hapy birthday man Hope you have a great day and wish you all the best for 2010
Topgear - Season 14
http://uk.tv.yahoo.com/blog/article/386537/
Happy Birthday Mani!!!
Belated birthday wishes . Hope you had a good B'Day
Has Any One Fixed Mechanical Temp Guage ?
Good mechanical guages are calibrated so they are pretty accurate and they do respond fairly quickly. Dodgy cheap guages probably will not have a great accuracy. Some electric meters can be quite slow to respond as well I think thats more the damping thats built into it to stop the meter waving about due to small fluctuations.
Sumith, I dont understand why you want to fit both electrical and mechanical guages? The electric one is much easier to install and only requires one wire whereas the mechanical is more difficult because you have to run the small tube all the way back to the guage and its usually about 3-4mm dia tube. I remember seeing those mechanical guages in panchikawatte but this was quite some time ago (8-9 years).
Hi When you say mechanical temp guage do you mean one with the small tube containing mercury or alchohol? What sort of guage is it and where do you want to install it? If its the one I am thinking of these usually are installed into the side of the radiator or screwed into the engine block. http://cgi.ebay.co.uk/DURITE-WATER-TEMP-GA...=item483782d8c3
