Everything posted by jdnet
- Allion
Best Place To Buy Car Maintance Equipments
The Karcher is the small one without wheels and no soap bottle right? I would vote against it. When I cbheck it out, it looked like a real PITA having to carry a sewperate bottle to feed it with soap and all. From what I heard Einhell is a good brand. Should be in that price range. Also when buying do check the pressure it operates at. too low= won't even wash the bird crap off the windshield. Can't clean wheel wells all that well. too high= will damage your paint.
Diy Ford/mazda Diagnotics- No Scanner Needed.
mazda tribute.
What Is This Gadget?
On a serious note, just unplug it and toss it in the trash. You might be able to sell it off to another joker. Just tell him it's a mysterious device that talks in japanese and all the cool people have it.
you don't know what the gadget is and want to change the language to english? I suggest you call Pet#o La#ka and explain to them that you want this to be converted to english regardless of what it does.
Door Sound
I don't know man there seem to be a lot of places selling quality rubber these days. Health Guard, harcourts, and those pharmacies inside food city. Just buy the imported stuff. The local ones are not that great and may cause leaks.
Almost forgot, for those of you who don't know what the codes mean, do a google search on the codes that pop up or post em here and I'm sure someone on the forum can find the problem and solution for you.
Ok Guys, After fiddling around with my instrument cluster I found something that's pretty cool. Basically on ford cars 2000+ and mazdas which use ford components (not sure about other mazdas though). The cool thing is you can check the real time battery load and and things like the headlight to see how it affects the load on the alternator. Everything else is covered including airbags, abs, burnts instrument cluster bulbs etc. Here's how it goes. 1. Insert you key into the cylinder- but don't move it. 2. Hold down the trip computer reset button and keep holding it, then start the car. You should see the word "test" pop up. Let go of the button. After it completes a test cycle, you can start hitting the button to scroll through all the codes. At one point you will see the voltage of your car, e.g 13.9. the number will constanly change based on how hard your car is working. You can on things like your headlights to check the load. Not sure on how to erase any codes saved, but I'll figure it out and let you all know. Anyways give it a shot and if you find wsomething interesting please do post it on this thread. Thanks.
Cr51 4Wd Remove
agreed. If you want to see how bad it is you would need to take a cr-41 with a 2c mated to an auto tranny. Overtaking is a nightmare.
Chipped Windshield
well if OP is going the 50 year route, he should take some KY.
Aventador
Lol. It's Giri/Min = RPM "Giri in English turn, spin; gyrate, rotate, revolve; whirl, wind, swirl, swing; reel; go round, round, wander; stir; endorse, indorse turn, turning, spin; round, trip, tour, walk, stroll, ride, drive; gyre, coil; circuit, revolution"
Radiator Problem And Overheating
did it work?
Auto Gearbox Issue
I'm going to take a wild guess that the tranny was machine flushed. Hence the reason the seal started leaking. First of all, do not take the advice of a service station. All they would care about is selling their products. I doubt that leaving the O/D off could cause any problems. First make sure you put the right fluid in. I believe it's Dexron III for your vehicle ( I may be wrong). The brand matters less than the actual specs of the fluid. There are a lot of manufacturers out there who make the fluid to dexron III specs and they include shell and mobil. Try changing out the tranmission filter and if the wrong fluid was put in, have it flushed manually.
Cr51 4Wd Remove
No kidding. I placed an ad for the tribute when I was planning on selling it. The title started with Mazda tribute 3.0L v6 and people actually asked me what the 3.0L v6 part of the ad means. Oh yeah an the first question a few other people had was if it had reverse sensors and cameras. I seriously think a lot of these people might actually be better off with beltas, axios and allions.
Cr51 4Wd Remove
but then he won't be a stereotypical Sri Lankan car buyer. See what's important in the car is the TV/DVD/Nav system (even though the navigation does not work. Everything else should be figured out after the vehicle is purchased.
- Badge Engineering
- Aventador
caps should not be expensive at all. Not sure about how much they cost. Before you by one try to take a cap off another car and check if it helps.
1. I use a haier wet/dry vacuum from abans. Costs about 12k IIRC. You can find cheaper priced chinese shop vacs @ panchi. 2. Staple street Food city had em last time I checked. Although these pumps are relatively worthless as they take quite a while to pump and you need to give the pump time to cool off after every tire. You are better off going to the shed, unless you have an air compressor at home. 3. You can find chinese ones in panchi for about 10-15k depending on the rated pressure. Get them from a bigger shop there which is willing to back up the product. I got one and I can safely say that this chinese crap has taken a lot of abuse without failing as yet.
Badge Engineering
someone just found wikipedia
check the cap, thermostat and fans. Start by checking the cap.
What Is The Best Toyota Car 2010???????
...and our new resident retard is back
Waiting Time For Brand New Vehicles
how about the fact that the vehicle is not identical to the JDM version? and yes the warranty does factor into the price. Unlike a car sale, toyota lanka has to have the ability to fix the car due to recalls, any defects etc. The "free service" is not something the manufacturer requires them to perform so they can charge anything they want. I think they do require the car to be under the care of toyota lanka during the course of the warranty period though...
Allion
ahhhh it's back to the good old days
Spark Plug
make sure you have the right plugs and they are a good brand. NGK/Champion/Bosch.
