Everything posted by Sifaan
Ice (Italian Car Enthusiasts) Club Show 2011
Do we need tickets or we can just come in to see the event?
Question About Well Water
If you already have an electric pump and a generator, and you only need to take it to the site, then go for it. If by tank you mean a big arpico / slon water tank, the only thing would be to install it at least a few feet off the ground so you can have a tap on the outlet that you can use to fill buckets, etc. But some kind of tank that's open at the top would be faster (just dunk the bucket!) BTW is there going to be a ceremonial start to the construction ?
Ban Hybrid Owners From Autolanka?
yes; the "green verdict" depends on whether we're talking about operating emissions, life-cycle emissions (i.e. emissions during construction and for raw material), or overall environmental impact (more than just emissions) at least for modern common-rail diesels with particulate filters and so on; I think for older (15+ years??) cars petrol was cleaner. or just that diesels are less tolerant of poor maintenance?
it is greener than building oil powered plants, which is what the country has been doing while dilly-dallying over the coal plant. (we've already built hydropower plants just about every where it's viable to build them)
Loose Connection On Battery
couldn't deal with this for last few days as my brother-in-law had borrowed the car. called Pala Auto (Baseline road) this morning and described the problem, and they said they could change the terminal for Rs. 300... I thought this meant the terminal on the battery (was surprised to hear that that could be changed) but discovered when I went there that they were referring to the part that clamps on to the battery post, which I didn't want to change. I then described the lead cap that Harshan suggested and they checked around and were saying they had it but don't have it anymore; however I think what they meant was something different than what I wanted - because they were describing having to bore a hole in the clamp and so on. anyway, in the end they made a cylinder from copper plate (curved it and soldered it) and inserted that on the battery post. And now the clamp fits nice and tight. when this was being discussed I asked if it would be made from copper or lead and they said copper is better as lead would wear out faster. Took almost 1 hour time wasting on looking for whatever lead thing they had in mind, a little over 1 hour to actually make and fix the cap, and Rs. 250 in total.
2010 Toyota Prius Fuel Range In Sri Lanka
IMHO it is more dependent on the kind of conditions you have to drive in. e.g. rover says he got 21+ km/l driving carefully to Kandy in low traffic. That's hardly worth the bother of having a hybrid. Even if a regular car did 12 km/l, the cost savings is 22*(125*110/12-125*110/21) = 10800/month (that's assuming this drive is happening 22 days/month). That can be a significant saving, but not if you have to spend a few lacks to replace the battery in couple of years. On the other hand someone driving in the morning rush hour coming in to Colombo on the Negombo road should get better figures (better usage of hybrid tech) whereas a regular car would fare much worse. On a somewhat different note; I live in a rented property in Colombo 1.5 km from office rather than travel from Wattala which is 10km from office (mostly for the time/hassle saving rather than fuel saving). Recently drove in to Colombo from Katu in the morning and realized what a joy it is to not suffer that kind of traffic anymore... if I had to commute 100km/day I would certainly move houses rather than buy a hybrid But of course other people may be more attached to their homes than me
A6 Road To Trinco
to be honest I wasn't really paying that much attention to speed/time - it was a hired van plus we were all rather distracted by other events. We left Dambulla after late lunch (around 3.30pm... maybe 4) and reached Nilaweli around 7.00pm, with ~20mins break en-route. the driver never went over 60 km/h :S
A6 Road To Trinco
went to trinco just after avurudu... upto Kantale the road is excellent. Between Kantale and Trinco there are some bad patches, so you need to take it a bit slow. And if you are driving on the Nilaweli road at night watch out for the morphing traffic signs (from a distance it looks like pedestrian crossing, but when you get closer it turns into a cow, etc). I think they painted over and reused some old signs and at certain angles the old sign shows through
Warning About A Car Sale
(apologies if this is a naive question) can you pls explain the benefit of this?
Hp 1700+
never mind Wikipedia, even Australia skilled migration program makes a distinction between "Professionals" (Accountant, Architect, Engineer, etc" and "Tradespersons" (Carpenter, General plumber)! http://www.immi.gov.au/skilled/general-skilled-migration/skilled-occupations/occupations-in-demand.htm
do you mean it's the same connector used on the 406 D9? Or D9 means something else? If a replacement connector would be a different type, I would prefer to not change it if there are other sustainable options any idea how come the max. tightening of the lever is not enough to ensure a solid fit? Might it be possible to "calibrate" the connector? otherwise the stud option seems the best alternative. thanks
A Message To "some" Hybrid Drivers
Did you see the news about the Diesel Hybrid version of the Pug 3008 ? And the 508 has PSA's Stop-Start technology (hopefully the models coming to Sri Lanka will come with it)
Well, this is what it looks like: http://sifaan.almostunreal.org/battery.jpg
Hi all Thanks for the suggestions As far as I know it is a problem with the clamp; the battery is about a year old (about 6 months when the problem first occured). I was not aware that it was possible to just buy a clamp and replace it (citroen sells the clamp and wiring to the car body at some fantastic price!) so will check that out as the preferred option...
Hi all; Some months ago there was a loose connection on the battery negative (car was at the agents for some other work) and the "fix" was to insert some lead pieces to create a tight connection. This has now come undone somehow (either by itself, or during the recent service - maybe they fiddled with it when checking water levels), and twice in the past week I had to fiddle with the connector to get power from the battery. Other than perhaps replacing the connector, what other options are available? Is the lead inserts a sustainable solution (and had just come loose during the service) or not? I saw something in a post about soldering the connector but I would prefer to avoid that because it makes it harder to disconnect the battery if the need arises. Thanks
Importing A Very Old Car
you can't define "classic cars" by YOM, but there is a cutoff to determine if the car needs a green test or not (can't recall if it is based on YOM or Reg.)
And if you a know a little more science, you will understand that the scenario is much more complicated than this, and that's why there are benefits in hybrid systems that outweigh the conversion losses. Mostly it is to do with the fact that electrical energy can be stored conveniently, but the torque characteristics of electric motors (compared to engines) also play an important role.
Correct Tire Pressure
that may have been the recommended pressure on your previous car, but that does not mean it is the "normal" pressure for that size tyre. The recommended pressure will depend on the weight of the car and the level of loading as well. And it could be different for front/rear as well.
Cops On The Streets!
have you even been through the process of paying a fine?
- Hybrid Cars
hybrid technology is not just for econoboxes... even Porsche has hybrid vehicles! BTW First Full Hybrid diesel sold out in just 9 days (but it was a limited production run) - doesn't seem to be a boring car at all!- Tinted Glass
can you convince the cops that they are for the rear seats ?- Tinted Glass
So there was a recent change? well, as the practice seems to be "come and show us the car without the tint to get your license back", I guess it would just be a case of unsticking it and putting it back up later (reminds me of motorcycle helmet rentals in vietnam!)- Tinted Glass
no, it was allowed upto a certain percentage of visible light transmission, but there wasn't clarity on how the cops were supposed to measure if a tint fell within the limits or not and of course it's allowed if you are a V*P, a V*P escort, or at least have a car that looks like it might belong to a V*P - Hybrid Cars
