Davy
Top Contributors
  1. Have ordered from both websites without any issues.
  2. Holy thread resurrection batman! Guys please be mindful when responding to old threads. This one is 10 years old. If you are responding to ask a question in an old thread, that is fine. But please check the date before commenting.
  3. Ah the good old days with pumping the brake pedal. I learnt to drive the same way too. When I first got to drive a car with servo assisted brakes, I applied the same force on the brake pedal and thought the brakes were binding because all four wheels would lock up. I assume you wouldn't be driving the car on a daily basis nor will you be doing frequent long trips, so as long as you are vigilant and have experience driving with this sort of brakes, you should be alright.
  4. If the shifter mechanism has a plastic frame with nylon bushes in them, then black dust is pretty common as the nylon bushes wear out.
  5. Your front wheels are probably out of balance. Get them balanced and get the wheel alignment checked. This is the first thing you should do before proceeding with anything else. Wheels are balanced by pasting small weights on the inner side of the rim. Sometimes these weights fall off and cause wheels to go off balance. As for experiencing the issue after switching to alloys, this raises a few questions. 1. Are the alloys reconditioned or brand new? 2. What's the brand? Inferior alloy wheels can cause all sorts of suspension and alignment issues. 3. How many kilometres do you have on your current set of tyres? If you used the same tyres from the original rims on the alloys, that too can be an issue depending on how old the tyres are and if the alloys rims are of a different width from the stock ones.
  6. Hi Fazal, Glad to see a car being owned by one family for 40 years. May I ask what's wrong with the body parts you've listed? If the bumpers have just a few dents and dings on them, I suggest keep them. You are unlikely to find bumpers in better condition IMO given the age of the car. Same goes for body panels. Unless they are too far gone, your best bet is to try and restore them. There are places that do electroplating. So you can straighten the bumpers out and have them chrome plated and they'll look brand new. Have you tried searching for parts in salvage yards in Panchikawatte? Not even sure they exist anymore, but many years ago there were so many late 70s and 80s cars there brought to be stripped for parts. Also Kurunegala area. The road that goes from Ambepussa to Alawwa has a couple of salvage yards and I remember some of them having parts for cars such as yours. In any case, you will have to do some searching. Good luck!
  7. Does the fan work at max speed when the engine is cold (i.e in the morning) and AC switched off? The cooling fan works at max speed when AC is switched on irrespective of the engine temperature. The fan works in harmony with the AC compressor, turning on and off alternatively. If that's the behaviour you're experiencing, then it's normal. As for the noise, have you checked if one or more of the plastic fan blades have a crack or chip on them? Fans can make excessively loud noises when they're out of balance. The other thing might be a missing engine cover or bonnet insulation. On a new car, I hardly think any of this could be the issue. So as others have said, compare it against a similar car.
  8. Topics merged. Thanks @kusumsiri.
  9. The answer to this question is that it depends from vehicle to vehicle. The best thing to do is to read your owner's manual and check the service schedule set by the manufacturer. The schedule specifies everything such as how often you should replace fluids, filters, belts and attend to tyre rotation, valve clearance adjustment and so on. If you don't have the owner's manual (which is typical for most cars in Sri Lanka because people put it in their bedroom cupboards like gold jewellery without having it in the glove box of the car and passing on to the subsequent owners, or because it's a JDM vehicle), try finding one online.
  10. Washing the engine bay is asking for trouble, especially on a car with an EFI engine with a lot of sensors around. Using a pressure washer on the engine bay is a big no no. If the engine bay is dusty, just vacuum it or use high pressure air to get rid of the dust. Wipe down with a rag and use a good engine dressing to detail it if required. If there are oil leaks, washing it off is not the solution. You can use an aerosol degreaser on a rag and wipe oil and grease stains off. So before the service, ask them not to wash or spray anything on the engine bay and to just use high pressure air to clean off dust. As for your concern about the high pressure air being too intense, the engine is a very harsh environment and components in there can withstand some high pressure air. As for the steam you saw, all of these cleaning liquids have some portion of water in them. When that comes into contact with the warm engine, steam is produced. So you can't really conclude that they used plain water just because there was steam. I personally don't allow service centres to clean any interior component (dashboards, console, door cards and trims etc.) with any chemical. What might be okay for one car might be too harsh for another and I have experiences with dashboards and rexin cracking and discolouring. Also, you don't know what service centres are using. It might be some cheap chemical whereas if you clean it yourself, you can get a good one and be more careful in doing it.
  11. The simple answer to your original question is, yes you can and yes it will fit. There are many Evos with this AEM fuel pump and the fuel pump housing and petrol tank are the same, so it will fit. But should you put it in a stock CS1 with the intention of gaining more power? No. It's like emptying a jug of milk down your throat in 30 seconds (refer to the FRIENDS episode where Joey did this ), your throat will regulate the amount of milk that can be sent down and overflow the rest (or you will choke). Similarly the fuel pressure regulator in your car's engine will try its best to control the pressure to match the stock fuel pressure. Even if fuel with higher pressure makes it through the fuel pressure regulator (say due to the fuel pressure regulator being faulty), the ECU will see the rich condition of the mixture and shorten the injector pulse width (the duration the injectors are open) to stop the mixture from being rich. So no, you won't see a noticeable improvement in performance, nor significantly higher fuel consumption. If you want more power, you can do more sensible modifications like go for a high flow air filter for starters. If you insist on going for the fuel pump, then you'd want to upgrade other fuel system components like injectors and get a tune done.
  12. He meant the AIR filter. Replacing the air filter is part of basic maintenance, and I hope you have done them because obviously you cannot expect the engine to work properly otherwise. Ignition timing is basically the spark plug receives a spark towards the last bit of the compression stroke of a piston. It's important to ignite the air/fuel mixture at the correct time in order to achieve a complete "burn" and for the engine to work optimally. In EFI engines, ignition timing is handled by the ECU by aid of the signal from the crank position sensor. But in carburettor engines, it needs to be done manually, by setting the distributor in the correct angle. A good carburettor mechanic would know how to. Not really familiar with Nuwara Eliya or mechanics in the area, sorry. Maybe someone in Kandy or close by can suggest a place.
  13. Hi and welcome to the forum, High HC can be due to many reasons, but the most common is the air to fuel mixture being too lean. The next would be improper ignition timing. From memory, the A15S engine has a carburettor, so get a proper tune done by a carburettor expert. Also get your ignition timing and distributor checked out as well.
  14. We're lucky labour in Sri Lanka is cheap. The labour cost to carry out that "conversion" in some countries would be more than the cost of an actual 150 series Land Cruiser.
  15. I am with iRage on this one. There are a couple of questions you need to ask yourself when in doubt about something on a car you are interested in. The first is to find out if the component in question has any inherent issues. Does the TIPTRONIC transmission on the Lancer have any issues? Not that I am aware of. So why worry? I guess the point I am trying to make is to make an informed decision. Look around, ask owners, read forums etc. Other than that, you shouldn't be overly anticipating something that is unlikely to happen. CVTs have been in production long enough for manufacturers to iron out any reliability issues. In fact, most CVTs require less maintenance than conventional automatic transmissions. They're also slightly more economical to run compared to conventional auto.
  16. He is a bit of a controversial guy. There are so many reddit threads that discuss about his credibility. There is no doubt that he has 50 years worth of experience, but that's where it ends IMO. Take this video for example, he rants about how Toyota is reliable because it's made in Japan and the Japanese culture is what's behind it. By that logic, all Japanese makes should be as reliable as Toyota. He worships the Celica of his and goes on about how it's the best car on the planet. ? These are just to name a couple.
  17. Thoughts on reliable cars by an unreliable "mechanic".
  18. The fan clutch is mounted onto the water pump pulley by four bolts. So you can just take the fan clutch out without having to worry about the water pump pulley, belt or anything. Apart from the things mentioned above, you will need to make sure that the direction of airflow is the same in the electric fan that you ware using. Also make sure that your fan is wired to run when the AC compressor is engaged. If your car is just a regular road car, I'd simply try and get hold of a good viscous fan clutch (DAYCO is a good brand) and install that in an effort to not mess with the car's electrics and to keep things original. But that's just me.
  19. The key fob should have a small notch into which you can insert a small screwdriver. Insert and pry it out. Inside, you will see the battery and a number engraved on it like CR2032 which is the battery model number. Buy the same model battery from Cargills or Arpico or somewhere.
  20. The letter "L" refers to the side of the negative terminal of the battery when viewed from the front. Your negative terminal is on the left. There's a 55D23R which is the same battery but terminals switched. The CS also comes with the same battery and I was able to find batteries without any issue. The Panasonic battery that was on the car when I got it was made in Japan and it lasted a long time. When it was time for me to change it, I didn't have trouble finding replacement batteries. I think I went with GLOBAL or GS or something. My father's Demio has an Amaron on it at the moment and I don't think he has had any issues for the past couple of years.
  21. I'm not sure to be honest. According to my knowledge, polished concrete floor and titanium cement floors are two different things. Polished concrete is basically regular concrete polished with a diamond bit grinder to achieve the shiny look. Titanium cement is a layer of cement on top of the concrete and based on the compound used, different colours can be achieved. I'm positive that polished concrete floors can withstand impacts and will not chip or anything when a jack or jack stands are used. But titanium cement might be a different story because it's a different paste applied on top of the concrete.
  22. Terracotta is a big no no as it's fragile as already mentioned as well as absorbs oils and stuff quite easily. Cut and polished (also known as Titanium cement) cement flooring is hard wearing and is pretty easy to maintain as well. Cleans off oils and mud etc well because it's not porus. A couple of relatives have it and I think it looks great in a neutral (or raw cement) colour. Epoxy coating like Devinda_Z said is great too. Not really sure if we have proper companies in Sri Lanka that does it. If done properly, it'll last a lifetime.
  23. Yes there is. You can add tags when you create a topic to make searching easier. Unfortunately, only a small percentage of members even type in tags. I try my best to edit and add new tags to topics that don't have them. Moderators are able to do this.
  24. Well... Like @Hyaenidae, I too am biased towards the Lancer purely because owning one for five years gives you a good impression about how reliable and great cars they are. I only have good things to say about the CS3 I had, and I only sold the car because I'm not in the country anymore and my father who was using the car wanted an automatic hatch for ease of driving daily to work. The only car that's comparable with the Lancer's handling in that list is the Axela IMO. The Yaris and the Vitz is the same thing underneath and the rear torsion bar compared to the Lancer's multi link suspension dwarfs in comparison. The question is, can you get a 2011+ CS3 for your budget of 2.8M. From what I can see, they go for a little over 3M?
  25. Not really. There have been at least three recalls on vehicles equipped with the Honda DCT around 2014. So the reliability issues are not purely due to the driving style. True, driving in Sri Lanka's stop and go traffic puts a unnecessary strain on the transmission so people have suggested driving on the first or second gear instead of D to prevent the transmission from shifting back and forth all the time. This apparently is a workaround.
