Davy
Top Contributors
  1. Holy smokes! Congratulations dude! This is epic! So happy to see this car go to a forum member! Have fun and welcome to the Lancer brotherhood! Yeah I know @E L N I N O personally. We used to work together and he used to have a CS1 when I had my CS3. I know he wouldn't have simply let go of that car to some random guy. Probably why the car was on the classifieds for that long. Can't say I have seen many EXs in Sri Lanka with OEM RalliArt/Galant Fortis rims. Also sits beautifully on those coilovers. ?
  2. From personal experience a few years ago, LG (Abans) and Panasonic (SoftLogic) were the best. Have dealt with both and their after sales service is pretty good. SoftLogic was slightly better than Abans when it comes to carrying out services and maintenance. As for brands, there's no best brand per say, I'd recommend LG, Panasonic or Mitsubishi. With both above points, it was a few years ago and I'm not sure of the present situation. Dual inverter is an LG specific feature at the moment from my understanding and it means that there are two inverters in series instead of one. They're supposed to be more efficient than single inverter ACs.
  3. If OP has 14 children and 2 dogs, you guys are way off. So maybe wait for him to confirm.
  4. Why not get a diagnostic scan done (preferably at the agent)? That way you know what the actual error codes are.
  5. Do you see smoke from the exhaust when when the engine is raced? The best thing to do is to get a compression test done. That will tell you if the cylinders are working properly, and if not, how severe it is. Depending on how bad it is, you might be able to just get away with a piston ring replacement or a full engine overhaul. But first - compression test.
  6. If it's a plastic centre cap, why not fabricate a couple of metal clips and rivet to the centre cap itself? This way you don't need to drill the rim. If you do it properly, you can even sink the rivet into the plastic of the centre cap and then put some filler on top of it and paint the centre cap so that the rivet is hidden. The metal clips be easy to make out of thin sheet metal and bent to catch the back of the rim like the plastic clips do. I'd just steer clear of drilling the rim. It's probably not going to cause any balancing issues because you're drilling close to the axle, so the radius is too low for the rivet or screw to cause a lot of linear force. However, the integrity of the rim might be compromised the moment you drill it.
  7. Davy replied to varotone's topic in MITSUBISHI
    In Sri Lanka the 1400cc 4G12 (Orion engine. Referred to by some mechanics as "Orient engine") and the 4G33 (Saturn engine) were the most popular. I believe I have seen a couple of early model A72 Lancers with 1200cc 4G36 engines, but are rare. Then we've got the very rare GSR that came with a 1600cc 4G32 engine. The GSR is the first gen Lancer responsible for many world rally victories, putting the "Mitsubishi" name in the map of world rallying. There are a couple of 2 door Lancer GSRs in the country. That is correct. Your engine is the most common one that came on these cars. If the book has been updated, I don't think you can. There might be a digit in the chassis number that corresponds to the engine model that was installed on the car. You'll have to find a chassis number decoder and see if that'll work, but I doubt these old chassis numbers work with them. This is the manual for 4G3 carb series. The 4G1 series carb manual is abit hard to find. So maybe you can use this for now as they are very similar. http://mitsubishi-motors.kiev.ua/Manuals/Engine/pwee9049/11A.pdf
  8. @Malithm Can you please stop opening a thread for each question and car that pops up into your mind? This is out of control! Stick to one thread and please stop cluttering the forum. Threads merged.
  9. Already discussed in great detail. Please search the forum.
  10. Davy replied to Le Sabre's topic in NISSAN
    I'm going to quote this, just in case I want to use it against you in the future. Can't say I have seen many black Preseas around. It suits the car well and the paint job seems to have been done perfectly. On the other hand, welcome to a world of washing the car more frequently and being baked alive upon entering the car after being parked in the sun. Anyway, what are your plans next?
  11. Davy replied to Le Sabre's topic in NISSAN
    Looking good mate. Well done! You changed the colour! And all this time you were against it.
  12. Davy replied to balapas's topic in General
    Well the additional clearance you're going to get is 6mm as I've mentioned above. Fuel saving, no. The replacement tyre is 10mm wider than stock, which will contribute to the tyre footprint being larger on all corners and thereby cause a bit more drag than stock while improving handling (and looks) of the car.
  13. Did your 2001 CS1 have an EFI engine? Most CS1 Lancers of that time came with a carburettor 4G13 engine. So no injectors, no ECU.
  14. Davy replied to balapas's topic in General
    The new tyre will give the overall wheel a larger diameter than stock, which will: - Slightly increase ride height (by about 6mm) - Cause the speedometer to indicate slightly lower than the correct speed (by a negligible amount) The best alternative would be 195/65/15 or 185/60/15 which might be hard to find. Go to the below website, type in the two tyre sizes and check for yourself: https://tiresize.com/comparison/ Why do you want to upsize anyway?
  15. Davy replied to ChanDK's topic in MAZDA
    Mazna didn't have just the spoiler when I checked with them a couple of years ago. Many shops in Delkanda had them though.
  16. That's right. Visa 189 (Points-tested stream). They've improved the website significantly and it's very easy to find what you want. Spend some time familiarising yourself with the process. Good luck!
  17. https://www.mara.gov.au/search-the-register-of-migration-agents/ You can type "Sri Lanka" into the "Business Location" and do a search.
  18. Taking Australia as an example: First of all, the company or individual needs to be a "Registered Migration Agent" in order to be able to legally qualified to act on behalf of an applicant. The Australian government has a web page with all registered migration agents, so before you consult one, make sure they are a legit company. Most popular companies in Sri Lanka are registered. How they work: You make an appointment and go there with your spouse or family (with whom you plan on migrating) for a preliminary interview, after which they will assess your situation and let you know what your options are. This step is usually free. If you decide to go ahead with it, they will provide you with a quote of their charges and let you know when payments are to be made. It's not a once-off payment usually. You pay an upfront amount and then pay in different stages, based on what the agent does on behalf of you. It's all highly subjective and so is the cost. Then you work together with the agent and get the paperwork done. For Australia, everything happens online through their visa application Portal (immi account). The agent is registered there and lodges an application on behalf of you. If you are migrating on skilled migration, you need the agent will lodge the skills assessment on behalf of you and all you really need to do is sit for IELTS. Each of these steps the agent does for you comes with a fee. After the application is lodged, you wait until the visa is granted. The agent sometimes charges you a final payment if the application is successful and you've been granted visa. How much they charge: About 5 years ago, a reputed migration agent wanted to charge me 700,000 (for my wife and I) for Skilled Migration to Australia. I ran away and did it on my own. My cousin works for a migration consultant in Melbourne and I just enquired and she confirmed that for a couple it would cost 1,000,000 for the entire thing, assuming it's Skilled Migration. My opinion: Do it on your own. Don't waste one million (that's nearly twice as much as what you would spend as opposed top applying on your own) on a migration agent. The application process (at least for Australia), although comprehensive, is very well explained on their Immigration website. All you need to do is make sure you are eligible (the website has an eligibility calculator). If you are, you can lodge an EOI (expression of interest) and that does not require you to make a payment. Before the EOI, you need to have done IELTS and met other criteria for which you might have to pay for (for Skilled migration, you need to have been assessed by the relevant assessing authority and given an "Eligible" status).
  19. Try H0bbyMart LK in Nugegoda. They have a good stock of spares.
  20. Last time I checked, you can't import Left Hand Driven vehicles to Sri Lanka. Search the forum, this was discussed a couple of times before.
  21. Hi Ridmal, welcome to the forum. When you start the car in the morning (when engine is cold), does the engine rev upto about 1500 - 2000 and slowly reach normal RPM (650 - 800) as the engine reaches operating temperature? Also, does the RPM fluctuate when the car is idling?
  22. Great! Good to hear that the agent is doing it the proper way.
  23. The original horn's negative line is the mounting screw itself. The wire that goes into the horn is the positive line. Your new snail type horn's negative terminal can be connected to the chassis of the car by a short piece of wire. The best place to connect it to would be one of the screws in the horn mounting bracket itself. The positive line can be directly connected to the wire that's already on the car. If the new horn draws more current than the fuse connected to the horn circuit, it makes sense to wire the new horn through a relay to protect the circuit.
