Davy
Top Contributors
  1. Welcome to to the forum. The market value of a car depends on a lot more things than the year of manufacture. Mileage, trim level, number of previous owners, condition of the car, whether sold privately or through a car sale, just to name a few. So visit the classifieds and browse through the ads to get an idea. http://www.autolanka.com/search/cars/?condition=&mk=1236&md=&district=&additional_info=PRIUS
  2. Stop responding to 7 year old threads.
  3. I drove a Magna in Australia (in 2014) for a while which is the same thing as the Verada. It's a pretty common car in Australia, and despite old cars being wrecked after a certain age, you can still see quite a few Magnas on the road. So in my (very short) experience: a. Fuel consumption was around 8 km/L on average. You'd be lucky to get that in Sri Lanka though. I used 95 octane. b. It has the same 6G74 engine that some of the Monteros in Sri Lanka have. Pretty reliable IMO. If the car is an automatic, you'd better look into the transmission to see if there are issues with shifting. I am aware that early Magnas of this series in Australia developed an issue where the gear falls into neutral on load. The one I drove had 320,000 km on the clock and was still going strong despite years of abuse. c. Pretty good drive. Very comfortable and handles well for a full sized sedan. The Galant of this era comes quite close to how the Verada handles, but the higher power of that 3.5L V6 engine on the Verada is quite distinctive. From the photos you've shared, it looks like it's a limited edition GTV which has some of the suspension and drivetrain components of the Magna VR-X - the "fully loaded" version here in Australia and is only second to the sportier Magna RalliArt which features a bodykit, bigger wheels and a tuned engine with bigger cams and so on. d. It's a rare car in Sri Lanka, so you'd have trouble fining body panels, exterior and interior trim bits and so on (explains the broken AC vents and dashboard components in the last photo). As for mechanicals, some components are compatible with other Mitsubishis (The Montero as mentioned above), so you should be able to source them with less effort. You should be able to find parts on eBay Australia as well. e. It's a great car and I loved while I used it. However, in Sri Lanka where the car is a lot less common, you'd have to invest a bit of your time and effort (not to mention money) to keep the car running smooth. Also, if you're worried about fuel efficiency, I'm afraid the car will disappoint you because it's never going to give you Maruti-like fuel economy. Hope this helps. Members who have experience with the car in a local context might be able to shed some light on how these cars are doing in Sri Lanka.
  4. This is a simple fix. All you need is a MAKA-BAA5 resistor. Let us know if you require more info.
  5. Davy replied to Le Sabre's topic in General
    Tunnel. They've proposed an extension of Marine Drive from Kollupitiya to Port City where the road will go underground (both land and sea apparently) and resurface at Port City to be linked to the Port Access Elevated Highway. This has not been confirmed yet though, but we will know for sure soon. http://www.dailymirror.lk/article/Underground-sea-road-Study-to-be-completed-by-March--142997.html
  6. 406
    Davy replied to Yasas Randeepa's topic in Mechanical problems
    Have you checked the condition of the spark plugs and ignition coil? I believe you're taking about a 406 D8 or D9, and from memory, these engines have a single coil pack that sits on all four spark plugs. With age, ignition coils tend to give trouble when the engine is warm and this maybe what you're experiencing. So since you have already replaced the IACV (stepper motor) and cleaned the throttle body, I'd suggest looking at the possibility of of a failing coil pack.
  7. Hi Prabath, Welcome to the forum! Unfortunately, there is no way of knowing the actual mileage of the car once it's tampered with. This is why most who tamper with them still get away with it. Your best bet is to look into the vehicle's service history and the emissions test certificates. These should have a mileage and you can compare this to verify if the mileage has increased in such a way that it aligns with the mileage shown on the car's ODO. Since it's a must to obtain an emissions test certificate each year, you should be able to track it down quite easily. If something doesn't add up, walk away.
  8. What is a holiday without some DIY? I managed to get hold of a used spoiler from Australia and bring it home with me (yes, I actually carried a spoiler into the airport and checked it in ). Got it for dirt cheap at about 4000 and I removed it from a wrecked car myself. No painting required as it's the same colour as mine. I expected the spoiler to be mounted by 4 screws, because that's how I've seen it being installed in one of the YouTube videos I saw. But the spoiler I picked up was actually mounted to the car by 2 screws in the middle and 4 clips. I reckon the spoiler in the YouTube video is an aftermarket replica of the original. This made it a bit more difficult to install because even the diameter of the hole drilled need to match the size of the clip. Bigger hole means the clip will pop out and a smaller hole means the clip will never go in. Here's the spoiler: The two screws in the middle are quite long, so the spoiler could not be laid on the car to get measurements of where the holes should be drilled. So I decided to make a mould of the spoiler - out of paper. I wet the underside of the spoiler with water and laid pieces of newspaper in an overlapping fashion. On top of that base layer, I glued several layers of newspaper (again in an overlapping fashion). Let it dry out in the sun and voila... we have a rigid mould like it was made out of cardboard! A technique learnt in primary school finally pays off - some of you guys might remember this. I marked the edges of the spoiler using a marker and cut the excess paper out. Then separated the mould from the spoiler (since the first layer of paper was laid out using water, it doesn't stick to the spoiler and is easily separated). Placed the mould on the car, aligned it and secured it using masking tape. Now we know exactly where to drill. After spending hours drilling, painting the drilled holes (to avoid corrosion), using gasket maker around all holes (to avoid water seeping in), the spoiler was installed. The two screws fastened and the clips snapped perfectly into place. Job done. I've got more updates about the car and I will share them when time permits. Was excited after installing the spoiler, I had to post this.
  9. You won't find any "kits" out there, so looking for one is pointless. The only thing close to a kit you will find is an Evo III that has been "cut" and imported as parts. If you're unable to find one (which I think will be the case), you will have to import. The process is quite labour intensive and involves stripping down your Lancer CB3 and installing parts from the donor Evo III into your car (in some cases, the other way around). Whichever way you do it, it's an involved process and it's vital do do a proper job so that the integrity of the chassis isn't compromised, and the final vehicle is safe as well as trouble free. So your ordinary garage is not the place to do the job.
  10. Given the choice, I'd always pick EFI over carburettor. Here's why: 1. Hard to find skilled mechanics It's becoming increasingly difficult to find mechanics who can repair, rebuild and tune a carburettor engine properly. Back in the day when EFI was not an option, every motor mechanic was required to have the skill to tune a carb engine. It's a totally different story now with EFI engines being dominant. This is not saying that you will not be able to get your carburettor engine tuned at all, but just pointing out one thing that may get even more difficult in the future. 2. Fuel Efficiency and emissions EFI engines are far more efficient and economical to run than carb engines. A single carb engine like the one on the Maruti cannot balance the air/fuel ratio that flows into each cylinder individually. Therefore they do not work as efficiently as their EFI counterpart where the ECU adjusts the air/fuel mixture to obtain a much cleaner burn in each cylinder, resulting in lower emissions. 3. Lower long term cost of maintenance Carburettor engines need a bit more TLC to keep running smooth. EFI engines need little to no maintenance, but given the local dusty conditions and poor fuel quality, even EFI engines need that periodic "tune" which is basically a clean-up of the gunk stuck within the throttle body and injectors. As with carburettors, every time you take it out of the car for a clean up, (for a proper job) it needs to be completely dismantled, rebuilt with a kit, reinstalled and tuned - time, effort, money. 4. Easier diagnosis With EFI, you can simply get the car to "tell" you when something is wrong. The check engine light illuminates and lets you scan the car for trouble codes. The ECU is able to detect even the slightest abnormality, even before symptoms are obvious to the driver. This makes things much easier to troubleshoot. With carburettor, it's a case of diving in and figuring out what the hell is wrong. 4. Higher demand I believe the local car market favours EFI over carb - if the same make/model offers both variants. So you're looking at being able to sell your car with ease when it is time. All this is not saying that carburettor engines are useless. Modern EFI systems can get really complicated and only trained people are suited to work on them. And although electronics in EFI systems are pretty reliable, they too can rarely fail resulting in expensive repairs (example: ECU failure). My 2 cents. Hope this helps.
  11. The agent should be able to let you know the recommended oil.
  12. The first thing you can do is check for maintenance records to make sure transmission oil has been changed on time, with the proper type of oil. Issues with the transmission might not be that obvious during a test drive unless you push the car a bit. The things to look for (other than the ones stated above) are rattles and jerks during acceleration and slowing down. It's quite normal in some CVTs for there to be a faint rattle, but excessive rattle and vibration isn't normal.
  13. 4WD
    Davy replied to noddy's topic in General Automotive
    @noddy, and you had to open an entire thread to share this? Please don't clutter the forum with unnecessary garbage. If you want to share random stuff like this, use the Post Whoring thread.
  14. Davy replied to Le Sabre's topic in General
    So I was surprised by some of the things I saw in the image below. Although I was aware of all the extensions that were happening to the southern, outer circular and central expressways, I was unaware that there was a project going on to link Port City to Rajagiriya and then Athurugiriya (E08). According to RDA, the project is called "Port Access Elevated Highway" and is due to complete in 2020
  15. Congratulations and kudos for doing your homework and making an informed decision.
  16. Already discussed. Please search the forum. tl;dr: They're pre registration garage plates. I believe C denotes Colombo and 16 denotes 2016.
  17. It's just a regular car, so you should check the regular things you would check when buying any other used car. Read the thread below:
  18. A 1998 CK2 with tiptronic? That's got to be a rare car. Based on the year of your car, I assume it's an INVECS II system which should be run with Mitsubishi SP III ATF. Best wait for another member to confirm this. Or you can ring Unit3d Mot0rs and ask.
  19. Recommended Engine oil is SAE40. So you can use an oil that has a grade that ends with 40 (0W40, 5W40, 10W40 etc.) the value before the "W" is the winter grade, which isn't applicable to Sri Lanka. As for gearbox oil, you haven't mentioned if it's an automatic or a manual. For manual, you can use an SAE90 gear oil. For automatic use any oil that conforms to DEXRON III.
  20. If you're going to for a Lancer EX, may I suggest looking for a GLS which is the fully loaded version with projector headlamps, fog lights and all bells and whistles. The lower trim is GLX. More info on the Lancer EX here:
  21. No, there shouldn't be any issues. Especially if you're thinking of simply dropping in a pair of Demio HID headlamps. Even if you install an aftermarket kit, you should be fine if it's done properly. Xenon lamps consume less power and emits less heat compared to halogen.
  22. This is going to be a bit difficult to source due to the fact that only the fully loaded ones came with HID. Try your luck at Delkanda and other recon parts shops such as EuroNipp0n and US C@r P@rts.
  23. Change your mechanic. Go to a garage that can perform an emissions test and diagnosis to identify what is causing the issue. High CO in exhaust gas attributes to a rich air-fuel mixture and could be caused from a clogged air filter to a faulty Oxygen sensor. A diagnostic scan will reveal what is causing this. Also, TPS is Throttle Position Sensor. Change your mechanic.
  24. There was no CEDIA in 1987. I think you mean TREDIA. The CEDIA was the JDM version of the 7th gen Lancer. TREDIA was the JDM counterpart for the first gen Mirage.
  25. Yes, the positive line for high power amplifiers connects to the battery directly. This is normal. Just make sure that the line is protected (with an inline fuse) and the fuse is located as close to the battery as possible. This will protect the car in case a short circuit happens. As for your question about potential issues to your car, it all depends on the current the amplifier draws versus the current the alternator produces to keep the battery charged. Now that the amplifier is already installed, you can get your charging system checked out at full load (headlights on, AC on, stereo on high volume) to determine if the alternator is keeping up with the power draw requirement.
