Davy
Top Contributors
  1. 1000, 1500 and 2000 gritt sandpaper is wet sandpaper, so you should use plain water. I'm not sure why you would use Brasso with sandpaper. Brasso is an abrasive liquid on its own, so there is no point in using Brasso with wet sandpaper. 3M rubbing compound. Should be available at some Arpico outlets. Wurth also has good rubbing compound. Before applying any paint, the surface should be clean and dry. The headlights are no exception. So yes, dry them under the sun or use some rubbing alcohol to quickly get the water to evaporate. TOA is fine. It's mostly how you apply it that makes all the difference. If you go too light, it will leave a grainy texture. Too thick and the paint will drip. All this can be fixed by cutting the clear again lightly using rubbing compound. This will give a smooth surface.
  2. Davy replied to Thxrindu's topic in General
    This is completely wrong. A facelift is usually minor changes to the external appearance of the car, mainly to the front and rear of the car. There are usually no changes to engine, transmission or other drivetrain components. Example (Mazda 323/Familia BJ series): Pre-facelift: Facelift: Note the subtle differences (ex: headlamps and bumper)
  3. Model Year (MY) and Year of Manufacture (YOM) are two different things. MY is the revision/version of the model and doesn't necessarily have to be the same as YOM. This is because production for a MY 2018 car for example can begin during the last months of 2017. The chassis number refers to MY. And the VIN usually has only one digit that represents the MY (depends on region I think, so UK might be different). It can be any number, but the manufacturer increments it after every revision. A 2017 car can have "8" as the MY digit while a 2018 car can have "9". This is my understanding. I believe your legal documents should contain YOM - the actual year the car was manufactured.
  4. It's basically using two separate buckets - one for your soapy water (car wash diluted in water), the other for your clean (rinsing) water. A grit guard is a mesh that is placed at the bottom of the buckets so that when you dip the wash cloth in, it doesn't sink all the way to the bottom and capture all the dirt that has sunk to the bottom of the water. See image below: I personally think the two bucket method is okay if you don't have access to a garden hose. On the other hand, you save a lot of water when using the two bucket method as opposed to using a hose. The important thing is to keep the wash towels free of dirt every time it touches the surface of the car. As for your question about letting the car dry on it's own, you might end up with water spots all over the car - especially on the windows. In a country like Sri Lanka where it's hot, humid and a bit dusty, you're better off using a clean microfibre towel to wipe the car dry. Water spots - see image below:
  5. Couldn't agree more with this. There are so many such incidents I have experienced as well - some even leading to a fire due to negligence of mechanics. My father was a total grease monkey back in the day. He did most of the repairs on his cars at home because he thought he could do a better job than the garages and because he didn't trust any garage to leave his car there even for a couple of hours. Back when cars were simple machines, this totally made sense. This is not to say that he hasn't messed up. He has. But for the most part, his work was pretty solid. I was highly influenced by this. So I think an oil change is one of the simplest things you can DIY. It might seem a bit daunting at first, but it becomes easier each time you do it. The only concern I have with doing fluid changes at home is proper disposal of the used fluid. In Sri Lanka, I had a few contacts through which I could dispose oil at a service station (god knows what happens to the oil after that though), but here in Australia, I actually have to pay to dispose oil safely. By "safely" I mean without harming the environment.
  6. First of all, which problem are you trying to solve? There is no problem here. You can drain most if not all oil from the transmission if you follow the advice given above by @Rumesh88. Would you rather go through the hassle of performing most of the steps multiple times (4 times instead of just once according to your example) instead of just doing it right in one go? As for "what will happen?" Probably nothing. The car will probably run fine if you're mixing the same grade/type of oil. However, when you drain all the oil, there is a higher chance of most of the small metal shavings inside the transmission to be drained out with the oil. Plus, once you've drained the oil out, you have the chance to take out the sump and clean the valve body and magnets which will in turn give you a cleaner gearbox. Draining a small amount of oil and topping up doesn't let you do that.
  7. http://www.motortraffic.wp.gov.lk/index.php?option=com_content&view=article&id=146&Itemid=77&lang=en See point #3
  8. A good way to speed up fluid draining out is to remove the filler bolt or dipstick (whichever exists) before taking out the drain plug. This increases the flow of oil from the drain outlet depending on the design of the transmission.
  9. Could be due to something as simple as a lose connection to a faulty ECU. Did Micro reveal findings of a diagnostic scan they did? Anyway, I hope you get the connections also checked out before opening up the ECU. Faulty connections in the main ECU harness or gauge cluster or charging system harnesses can result in symptoms you have described.
  10. What is the actual issue @Dilhush? And where is the car being repaired? If it's not at the agent, then you should probably get a second opinion before replacing the ECU IMO. Some local mechanics suggest ECU replacements before even checking the simplest things.
  11. Hi Gaz, Welcome to the forum! This topic has been discussed so many times. Before opening new topics, please search the forum. Just a few.
  12. This has been discussed several times on the forum. Please search.
  13. Very common issue on the CS. Had it on mine as well. I ended up polishing the weather strips and applying tyre shine to them. This lasts a while. I think it's useless buying new ones because the new ones will also develop the issue after a while. I think it's due to the compound used to manufacture the whether strips together with the local humidity. I checked the prices at Un!ted Mot0rs when I had my car (back in 2010 or so) and they quoted about 12,000 for one of the front ones. Rears were 8000 each I think. Too expensive, so I gave up on it. I doubt you'll find them elsewhere.
  14. Hi AkilaM, Welcome to the forum and congratulations on your purchase! CS Lancer spoilers and bodykits has been discussed before. You should be able to search and find more information and contacts from where you can buy one. Refer the following thread.
  15. Hi Dineth, Welcome to the forum! All cars that are listed for sale can be found in the AutoLanka classifieds. Advertising is not allowed on the forum, so asking here is not the best way to go.
  16. Hi, welcome to the forum. This topic has already been discussed. Please search the forum before opening new topics. Thanks!
  17. After buying the Traxxas Defender, I'm in love with the brand! I haven't made much progress on the F-150 unfortunately. Personal commitments. But fear not! It shall be on its wheels again!
  18. That's correct. If it's plain water, it's likely that it's from the AC drain line.
  19. Yes you should absolutely get it checked out. If the coolant level keeps dropping constantly, there might be a leak somewhere. The first thing to do is carefully examine around the engine for traces of coolant leaks. Due to the bright green colour of the liquid, you should be able to easily spot leaks if there are any. You can also keep an eye under the car after you've driven it, to see if you can see drops of coolant on the floor. Remember that there is a coolant line that goes into the cabin of the car for the heater matrix, and if there is a leak there, you might not even see leaks in the engine bay or on the floor. If you're lucky, you might see small traces of green in the water that is drained from the AC. You can also check for the possibility of a gasket leak by carefully opening the radiator cap, starting up the car and checking for tiny air bubbles in the coolant through the filler neck. Do you have white smoke coming out of the exhaust? Did you do a repair recently that required the drainage/disconnecting of the cooling system? If yes, it might be that there are air pockets trapped in the system that's using up the coolant in the reservoir to fill the voids.
  20. Spot on! The RalliArt does have different dampers and they're more or less the same height as the ones you get in the base Lancer (Lancer Ex in Sri Lanka), but with stiffer springs. In fact, the entire suspension system is far more superior on the Evo with alloy control arms opposed to the RalliArt that has steel ones.
  21. "Free upgrades" lol. All of these are recalls and they're meant to do these for free anyway. Like I saw recently on Facebook, "marketing nam ithin Lankaawa thamai".
  22. Hi Dileepa, Welcome to the forum! The Viva Elite had a few known issues and one of them was an issue with caliper pins. The pins wore out fast causing noise when going on rough terrain and over bumps. All this can be found in the Viva Elite thread here. By "pin joint" if you are referring to the caliper pins, it is possible that the pins was not properly greased before being installed (the right side less than the left). This can seize up the caliper, causing the brake pads to be pressed against the rotor and wear prematurely. It could also be because the pads themselves are not properly positioned within the caliper. In any case, the brake pads need to be taken out, caliper properly serviced and reinstalled. If the pads are too far gone, install a new set. From where did you get the repair done by the way?
  23. Check if your fog lamps work only when the ignition is on. If yes, bypass the fog light switch and hook up the day time running lights to the same line that the fog light switch is connected to (i.e the receiving line to the fog light switch). This will ensure that the fog lights and daytime running lights are in the same circuit. Alternatively, you can hook it up to a fuse in the engine bay fuse box. Use a test light to find out which fuses get power only when the ignition is on. Use a non critical fuse though (windshield wipers and power shutters fuses usually get power only when ignition is on). This way you don't have to run wires into the cabin of the car. If you want to go all pro, you can use a relay and wire the lights up so that only the relay trigger line is hooked up to the fuse. This will prevent unnecessary power draw from the circuit that you tap into and is the safest option, especially if your lights draw a good amount of power.
  24. You have a point, but take the WRX from the same era (or even the new one) for example. Also a rally car but it sits much better than an Evo in it's stock form IMO. I guess what I meant was the gap between the wheel and the fender, not the height. The stock tyre profile of the WRX for example (245/40R18) is better than the RalliArt tyres (225/45R18). This fills the wheel well nicely, leaving only a little gap. The gap on the Evo is actually much much better than the RalliArt. If you check my photos with Evo X wheels on, you can notice that the gap is a bit narrow. It appears this way due to the higher positive offset of the rim, making it sit closer to the lip of the fender.
