Davy
Top Contributors
  1. Davy commented on Komisiripala's blog entry in Project R
    It's going to be awesome (already is, just for the lack of a better word) after that ITR front end is slapped on. Also, +1 for the OEM spoiler!
  2. I know I know! I've already selected a set (this one) and been putting off buying them due to other priorities. This is the first thing I'm gonna do, I promise you! I am actually embarrassed of that huge wheel gap. I don't know what Mitsubishi was thinking when they signed off on the stock height of the RalliArt and the Evo. It's just hideous.
  3. The speed at which your car collided with the parked car may have been insufficient to trigger the airbag. From what I remember, it requires a shock similar to the car hitting a solid wall at speed of approximately 25 km/h. Since you hit a parked car, it would have absorbed a bit of the shock, so the even a speed of 30 km/h might not have been sufficient. If your car wasn't written off (knowing Sri Lanka, it would definitely be repaired), get the airbag system checked out once the repair is done. Get the diagnosis done at the agent.
  4. I can see all the Demio owners on the thread lowering their cars now.
  5. Every time I see this interior, it makes my heart leap. There should be a picture of this dashboard in the Sinhala dictionary under the phrase "Budu Ammo!".
  6. Most of these air fresheners are toxic you know. A couple of hours a day in such a confined space and inhaling all these toxins is just not good for your health. Keep the interior clean and tidy and you will not have to use air fresheners.
  7. Lightly wet a soft cloth with surgical spirit and wipe the affected areas. This is the cheapest way, but you will have to use some elbow grease to get the spots off. Or you can use a glass polish. AutoGlym and Mothers have good glass polish.
  8. I assume you're referring to the GDI pump. I haven't heard of GDI pumps being repaired. As a matter of fact, I don't think Mitsubishi offers a repair kit for it. The unit is meant to be replaced if faulty according to my knowledge. What is the issue with your Pajero? Have you ruled out other possibilities before determining that it's the GDI pump that's at fault? If you're sure the pump is faulty, you can take it apart and clean it, but I doubt this will make a difference. You should be able to find a recon pump through the famous "Mitsubishi Mahinda". He should actually be able to tell you if the pump can be repaired as well. His number has been shared numerous times on the forum. Search and you shall find it.
  9. Davy replied to Nauman's topic in TOYOTA
    Maybe it wants to be a Mazda and go Zoom-Zoom! But seriously, most Toyota hybrids have a certain amount of "whine" coming from the hybrid motor - especially during regenerative braking. This is heard quite well in the Camry. In fact, you can tell for sure that there is a Camry around by just the motor whine. This is not saying that this recent development is normal. So maybe you should take the car to a Hybrid expert and have it checked out. It could be something minor like a ground connection that is faulty. Welcome to the forum by the way and good luck. Hybrid owners might be able to give better explanations.
  10. Thanks! If you don't have an air compressor and painting equipment, you can paint it using aerosol paint cans like I did. I used about 4 cans - 1 per wheel. 3 coats. I used primer out of an aerosol can as well. You can source all of these locally. Try brands like TOA and Leyland. They're available in local paint shops. As for the putty, I'm afraid you will have to source it from eBay or somewhere. If the damage is very minor, you can even use body filler (cataloy paste). Just make sure it's a type of cataloy that is safe to be applied on Alloy. Good luck! You're welcome to post your DIY on this thread.
  11. For the vibration/wobbly engine, get the engine mounts checked out. It's difficult to diagnose noises without seeing and listening to it. It could be a worn out bearing in a pulley, to a failing water pump. Share a video if possible.
  12. Must be a cheap Chinese alloy wheel then. Since you have already ordered a set of new rims, may I suggest buying a regular steel rim temporarily instead of repairing the alloy wheel? This might be cheaper (and safer).
  13. Macro Auto Tech in Nawala used to do alloy wheel repairs. Google them up. Your damage seems to be a bit too severe though. The wheel is bent as well as cracked, so It might not be safe to repair it. Check with Macro and they will advise. Even if they say it's repairable, I suggest using the rim in the rear of the car. Just out of curiosity, how did it crack like that and what is the brand of the wheel?
  14. Although it looks like only a small area is damaged, the entire bonnet (along with the hinges) might be warped. If that's the case, I agree that replacing it would be the best option if you can afford it. Having said that, there should be plenty of tinkerers out there who can do a decent repair job on that.
  15. When did you last do a tune-up? When was the air filter changed? What's the current mileage of the car? Members can't delete topics. Only moderators and admins can. I have informed them and they will delete the duplicate thread.
  16. Already discussed. Please search the forum.
  17. Arpico Battaramulla used to have ArmourAll.
  18. Welcome to the forum! The shifter linkages/cabling needs to be inspected to check for damages. It's probably a broken bracket or a bush or something, so any garage should be able to easily fix it for you. Good luck!
  19. If it's a creaking sound, it could be that the springs and parking brake mechanism need to be cleaned, or the brake shoes are binding with the backing plate. Give it a thorough clean up using some brake cleaner and apply some brake grease/lubricant on the moving parts. Pay attention to the places where the brake shoes touch the backing plate.
  20. Thank you @MADZ! Wishing everyone on the forum all the very best for 2018! Drive safe and happy motoring!
  21. "Creativity level = Anuradhapura Police" Photo credit: Shaminda Thushara (Facebook)
  22. Spot on! Well said! Before wasting your time and money doing all of these things blindly, you should have just done a tune what involves a throttle body clean up, plus injector clean up, followed by a diagnosis. The scan would have revealed if anything is off. Excessive carbon in your exhaust is due to the engine running rich. Get a scan done and pay attention to ignition timing and O2 sensor values during cold start and observe the changes. It would be great if you could share a close photo of the exhaust tip to actually see if you are worried for nothing. Exhaust tips are black you know... they're not purple. Also, it was wrong to use injector cleaner on the throttle body. It should have been cleaned with carb/throttle body cleaner, and the sensors should have been cleaned with an electronic parts cleaner. Also, some throttle bodies are not to be cleaned by spraying carb cleaner directly at them. Instead a clean rag is to be dampened with the solvent and cleaned by hand.
