Driving license
You can always call 1919 and find out information. Check the link below. Half the links on the page are broken, so I'm not too sure about the accuracy of the information on the page. http://www.gic.gov.lk/gic/index.php?option=com_info&id=397&task=info&lang=en I also had to get the new license in 2008 because the original one faded away. So mine expires in 2018 as well. I hope there is a one day service or something.
- Driving license
Battery light
As TT mentioned, your charging system needs inspection. The symptoms you've described suggest a bad rectifier circuit (commonly referred to as the "regulator" or "diodes") in the alternator. The other possibility (and the less likely one) is a fault with the charging system wiring. You can check this yourself if you're keen by removing then connector and the ground wire from the alternator and switching the ignition to the ON position. The charging indicator should light up fully bright. At idle, the charging voltage should roughly be between 13.8V to 14.2V. Even with load (AC, headlights etc.), it shouldn't drop below this range.
Need help, regarding an Issue
Glad you got it sorted. On the way back home after the repair, did you go to the "ECU_break" guy's garage and tell him a thing or two?
Honda Vezel, LED low beam light indicator now showing in the dashboard
No. You should be able to remove just the gauge cluster. Tilt the steering down, look for screws, remove them and gently pry out the bezels and take the cluster out making sure you don't pull on the connectors. Disconnect them and locate the bulb on the reverse side of the cluster. Swap it with another working indicator bulb to check if it's actually the bulb that's faulty. If it is, replace.
The easiest explanation is that the indicator bulb is burnt. Take the gauge cluster out and check the bulb.
O2 sensor alarm
The check engine light on the dashboard should be on and a diagnostic scan should reveal an error code. So yes, those are the "alarms". Does your check engine light turn on when your ignition is at the ON position and go off in a few seconds or after the engine is started? If not, your check engine indicator bulb may be burnt.
Accelarator doesnt work
What exactly do you mean by "pedal doesn't work"? Can you describe the behaviour? A faulty throttle position sensor doesn't really cause the accelerator pedal to "not work". There can be idle fluctuation, stalling engine etc, but the pedal should function. Testing the TPS is pretty straightforward. It's just a variable resistor and a multimeter can be used to test the resistance through the range of the sensor. It should be a smooth change in resistance without any dead spots or spikes. If you replaced the TPS with a reconditioned one, it's possible that the replace sensor is faulty as well. The other possibility is that your TPS voltage line is supplying more voltage (than normal) to the sensor and thereby causing it to heat up and eventually fail. If the car has a dual sensor design (one sensor near pedal and the other near throttle body), get them both tested.
Side Skirts & A Spoiler For Lancer
Found one on Facebook. Check you're inbox.
- Gearbox - Lancer C12
Run far away from that guy and go to a reliable mechanic and get the car scanned again. The scan should reveal one or more error codes. You need to action each one of them depending on what they are. "break_ECU" REALLY? Who is this joker?
Do you have the scan report with you? Share a photo of it if possible. If not, mention what error codes were found.
Lifespan of Radiator Hose
Sounds like a bit of a nightmare. So the ATF line leaked on the newly replaced recon radiator? If the original radiator is lying around, use the cap from that instead of the one that came with the recon radiator. There are pressure testers for cooling systems and they consist of a simple pressure gauge, a hose an adaptor to fit onto the expansion tank cap or overflow line of the radiator. Using that, the system can be pressurised (some require the engine to be kept running while some kits come with a pump) and observe the pressure gauge. On a properly working system, the pressure should be stable at the value printed on the radiator cap. If it drops before that, then there is a leak somewhere, if it goes beyond the rating, then the cap is busted. I'm not exactly sure which garages are equipped to do this in SL though. Also, I hope ATF in the car was flushed out and changed after the leak. Coolant might have entered the ATF lines and made its way to the transmission. Not pretty.
When to change timing belt
The tensioner is essentially an adjustable pulley, so maybe that's what they're referring to. However, depending on the design of the engine, there can be one or more pulleys that are used to limit or narrow the gap between two adjacent sprockets. @tiv, I believe the agent has a timing belt repair kit that consists of the pulleys, oil seals and the belt itself. This is probably what is priced at 70K. It wouldn't hurt to use genuine parts and use a repair kit to do a proper repair for something like the timing belt. The oil seals and pulleys are there in the kit as preventive maintenance. If the old oil seals leak and lube up the sprockets enough to cause the belt to slip by just one tooth, then that could be the end of it. Similar story with the tensioner (+pulley). The weakest link in the chain is usually what gives way, and an old pulley just might be that. Have you considered ordering the kit from amayama or partsouq and then getting your mechanic to do the repair? Might be a lot more economical.
- Lifespan of Radiator Hose
- unprofessional work at Mr P*int
The First Evo X in Sri Lanka !!!
Converting Manual Doors To Power Shutters
A friend of mine who owned a CK1 swapped in a set of CK3 power doors, so the process is similar. I'm not exactly a 100% on the details though. If you already have the car, pry out the trim pieces near the door hinges and check if there is a connector that's folded up and non connected to anything. Also check your internal fuse box to make sure it has the power shutter and central locking fuse slot. If you have a workshop manual, you should be able to easily figure out where the wires go and what colour they are. This is a common conversion even on the CK Lancer, so maybe someone on the forum has done it and will share information.
How To Flush And Re-Fill Radiator Coolant
If there is excessive rust, you have the option of getting your radiator cleaned. This involves taking the radiator off the car, separating the top and bottom tanks from the core and thoroughly cleaning everything. This will remove most of the rust. After the repair, you can use water for a couple of days to rinse out the remaining rust in the system. You can then drain out the water and use coolant. If you think opening up the radiator and cleaning isn't necessary, use a flushing liquid and do a thorough flush. It's unlikely that leaks would develop after a flush.
How do people get E numbers
Already discussed. Search the forum!
Lancer EX vs Civic FD4
Already discussed. Search the forum! Also the BRATT thread if you want info about the EX Civic FD threads: Also:
Has Proton Gen 2 Production stopped
Not sure which wiki you're referring to, but Wikipedia clearly says the Gen 2 was replaced by the Suprima in 2013, although production for the Gen 2 continued (for certain markets) until 2015. Source: Wikipedia About your concern on spares - manufacturers continue to produce spares despite discontinuing production of the car. This is why you're still able to find a gasket overhaul kit or an ABS sensor for example a Corolla 121. Proton shouldn't be any different. Also, search the forum.
- Help With My New Cs3
