Davy
Top Contributors
  1. it should be within 2 feet of the steering column (under the dashboard) because that is the standard for OBD II.
  2. That oil looks brand new. The oil lines go to the bottom tank of the radiator, you should even be able to see from the top of the engine if you stick your head in a little. Since you have no cooling issues and since the oil looks pretty good, I doubt it's an overheating issue. But checking for a block is pretty easy. Remove fluid return line from transmission end and place the end of the line into a clean container. We use the return line to eliminate the probability of blocks in the cooler lines as well. Start engine and idle for about 10 to 15 seconds Observe fluid flow and check if the amount of fluid pumped out is within specs (you need a workshop manual to get the correct flow rate, but an experienced person should be able to tell just by looking) Re-connect all hoses and re-fill transmission fluid The next thing you should probably do is get a fluid pressure test done. You can get the fluid line pressure checked without opening up the transmission. The transmission has one or more test ports onto which you can plug in a pressure gauge and check if the pressure (at idle and full throttle). The readings should be within the manufacturer's specifications. The procedure is pretty straightforward, but I'm not sure if local workshops even do this. Maybe another member reading this can confirm. Again, what's your current mileage?
  3. Do you have any visible ATF oil leaks under your transmission? Slippage usually occurs when the ATF level is low or if fluid pressure inside the transmission is low. I don't remember if the BJ5P has an ATF dipstick, but if it does, can you check the level and condition of the oil if possible and report back? Was the transmission oil pan removed and cleaned during the oil change? Another reason maybe because the fluid is overheating. I think the ATF cooler lines go through the radiator on your car and if so, you may want to check if the lines are blocked. How's the general operating temperature of the engine during your aggressive drive? Still mid point and fans kicking in normally? Just trying to eliminate other causes here before opening up the transmission. What's the mileage of the car BTW?
  4. This article will answer most of your questions: http://www.bbc.com/news/blogs-ouch-23061676 To quote the article, "The government didn't see these as cars... they saw them as a prosthetic". This maybe the reason to name them "Invalid Carriage". Just speculating here. There was a company named Invalidka ("Invalidka" apparently means "motorised wheelchair" in Russian). This might be another source of origin, This is when we need @Sylvi to explain the history a bit for us. But anyway, to me it looks like Ceylon adopted this from the British.
  5. The Internet is full of idiots trying out things on their cars, but that doesn't mean they're recommended nor safe. Flushing with kerosene is simply a way to destroy your engine IMO. Even engine flushing solvents should only be used as a last resort. If you must flush, just flush using engine oil. Simply perform oil + filter changes in shorter intervals than usual. Search the forum for more info. This has been discussed in detail.
  6. My opinion is that you should then tap into one of the fuses in the interior fuse box and get power from there for now. Make sure the fuse you're tapping into is one that gets power only when the ignition is switched on. This way your equipment is protected.
  7. Take your car to a good electrician. There is a short circuit somewhere.
  8. Have you tried replacing the fuse and not using your USB adaptor for the phone for a while? It maybe an issue with the USB adaptor as well, although highly unlikely. You're better off addressing the problem than thinking of avoiding it by pulling wires from other circuits.
  9. Obviously there is a leak somewhere. From the photos, it looks like your rims are in pretty bad shape (not just the oxidisation, but it looks like you have some damage as well). My guess is that you have oxidisation build up in the edge of the rim. Assuming this is where the leak is, It needs to be cleaned up and a good sealer needs to be applied.
  10. Usually accessories like your audio system, interior lights, 12V sockets (cigarette lighter) are all in the same circuit protected by the same fuse. Could be an issue in any one of them or a wire that has been crimped somewhere.
  11. You're welcome. Good luck and keep us posted.
  12. Known issue on this model. There was a recall too. http://www.consumerreports.org/cro/news/2010/12/recall-2007-2008-honda-fit-headlight-problem/index.htm EDIT: Source: http://recalls.owners.honda.com/service-maintenance/recalls?id=
  13. It's called Gudgeon pin or wrist pin. It's what holds the piston head and the rod together. Anyway, my first question is, there is a clear difference between tappet noise and wrist pin noise. So why did your mechanic advise tappet adjustment? Also, why was the valve body taken off the car to adjust it? It could have been done with just the engine cover taken off. I suggest you go for a second opinion before dismantling the engine. What's the mileage of the car? Has the engine been overhauled at any point? Also, do you hear the noise when as soon as you start the car or when you rev up the engine/under load?
  14. What sort of advice are you looking for? Isn't the answer obvious?
  15. OP had already done a diagnostic scan. This is the preliminary investigation and that had already been done and it was identified that the error is a P0500. So the next obvious step is to carry out further investigation - test the sensor or wire harness or both. All of this require some level of "dismantling". Taking off a VSS out of the transmission and testing it is not really rocket science, and doing so will reveal more unknown information which can be used to determine the correct course of action. @dilan_randika, I highly doubt any of your actions (repairing the puncture and releasing fuel tank pressure) lead to the issue not appearing again. I still think your VSS was intermittently sending a faulty signal (most probably due to dirt, now that it magically fixed itself). Hope it stays that way.
  16. Davy replied to sira's topic in General Automotive
    That particular thread is about the DE series (2007 - 2014). OP is talking about one of the two series before DE.
  17. Ironically, he talks about decency and "bad rear design" in his post. The times we live in I tell you.
  18. There's a chance that the coil packs were not properly installed after the repair. You can check this yourself and ensure they are properly secured and the connectors are also plugged in properly.
  19. Davy replied to Iced-T's topic in General
    Damn. It has blown a hole right through the sidewall by the looks. I wouldn't use this tyre again if I were you, due to the extent of the damage.
  20. Cleaning it is a step carried out to prevent the chances of replacing a working sensor. It's standard procedure for any sensor. This is why I said 1.Clean 2.Check wiring 3.Test sensor. Also, we really can't conclude why the problem happens exactly two times. That isn't really relevant to the diagnosis in this case. However, the VSS generates electrical pulses which is measured by the gauge cluster and the ECU. A faulty unit can result in one or two pulses to be dropped intermittently. The ECU waits for a certain amount of time/occurrences before raising the Check Engine light. This is because a problem can be a one off issue that may never occur again. When the ECU reaches a threshold, the indicator is illuminated. That's how it works for pretty much all errors. So there's a good chance for the issue to happen the exact number of times during a trip. Also, the VSS signal is what's used to move the speedometer and tick up the odometer. There is a good chance for there to be a relationship between the distance and the Check Engine indicator. I had an issue with a camshaft position sensor once where the car would stall evey 15 minutes or so. And it would not start until the engine was cool again. We really can't explain the relationship between time, but in my case it was heat causing the sensor to fail. If you have a look at a workshop manual, based on what the error code is, evey error has a list of possible causes and a list of steps to diagnose it. None of them say "if the issue happens x amount of times, check this", "if the issue happens in the morning, check this" etc. OP simply has to follow the steps suggested regardless of the frequency, distance or time of day. Hope this answers your question.
  21. OP, follow Rumesh88's advice. P0500 is pretty common on the Yaris and Belta. As a matter of fact, my brother in law used a 2008 Belta and got a P0500 and cleaning the VSS solved the issue. I did it myself and the sensor was exactly as Rumesh88 described. The VSS on the Yaris and Belta has a hard plastic gear at the tip of the sensor and this can get dirty. Clean the sensor and inspect wiring close to the transmission. If you can get hold of a workshop manual, you'll even be able to find the proper VSS test procedure.
  22. You shouldn't have replaced the thermostat verifying the simple things first. Did you buy the correct replacement thermostat? Remember that thermostats have a temperature rating. If you put in one that is rated higher than your original one, it will not open at the right time and the engine will run a bit warmer. Anyway, since you have already done it, that's that. 1. If you have dual speed fans, make sure they work at the high speed as well as low speed. You should feel a strong flow of air when the fan operates at high speed. 2. It could be due to a clogged radiator. Especially if you use water instead of coolant. Any radiator shop should be able to clean the radiator for you. The process involves taking the radiator out of the car, disassembling the top and bottom tanks and cleaning each water line in the core to make sure that none of them have any blockages. You should have done this while replacing the thermostat IMO. 3. While the engine is cold, carefully remove the radiator cap, start the engine and let it reach operating temperature. While gently revving the engine, observe the flow of coolant through the radiator filler neck. You should see coolant flowing in one direction and the flow rate change based on the RPM of the engine. If the coolant look stagnated, then it could be that your water pump is busted. This is a bit of a complex repair, so be absolutely sure that all other possibilities are eliminated. 4. Air trapped inside the cooling system can cause the temp gauge to go up when going uphill. Since you replaced the thermostat, there is the likelihood of air being trapped in the system. The air needs to be bled out of the system. The procedure is pretty straight forward, and you can do this at home. Watch the video below and you will understand:
  23. Can you please open one thread and ask all your questions in that instead of opening one for each issue about your car? Call it "Help with my Carina AT192". The number of redundant threads you've opened is just ridiculous. Also, search the forum.
  24. The 10th generation Lancer did not undergo any major changes during it's lifetime from 2008 to date. At least not in the models offered in Sri Lanka. So you are really not comparing different cars. I assume it's the same with the Axio. So the discussion in that thread can be continued to match the current day situation. Imagine the situation if 100 members want to compare these two cars. There will be 100 redundant threads on the forum. We like to keep things organised here, so members are always encouraged to find existing threads and post in them if they are comparing identical vehicles or if the information they're seeking is the same. This particular thread I've shared is not the only thread discussing the Lancer EX or the Axio. There are several other threads that discuss each car on their own, so read up. As a matter of fact, the two of the issues you have highlighted are already discussed in their individual threads: As an owner of the 10th generation Lancer that has 126,000 km on the clock right now, I can say that if the car has been maintained properly, none of these issues will bother you. The rattling issue in the first thread above is because the owner drove the car in really bad roads and ignored the rattling sound when the issue initially popped up. I'm not sure about the EPS issue, but most Lancer EXs came with hydraulic power steering according to my knowledge and I haven't heard of any of them giving trouble since they are pretty straightforward systems. None of these issues are running repairs, they are totally based on how the car was used and maintained. The ABS issue was there on the initial versions of the car, but was later rectified and even the agent repaired it FOC on the ones that had it. Please read up! I didn't bother searching for Axio threads, but I'm pretty sure you will find more than enough information on that as well.
