Davy
Top Contributors
  1. Hi Guys, Posting a DYI again after quite some time. After I got new wheels for my car, the stock rims have been lying around and I thought of repairing them. Two of the wheels had nasty kerb damage thanks to the previous owner who was careless when parallel parking (wheels with the most damage were the ones on the left). When I was looking for a set of used BBS rims for my car, 90% of the rims I found had kerb damage. So the problem is pretty common and getting these professionally repaired and resprayed can cost a lot. If you are keen on doing this on your own, you might find this post useful. Things you need: Alloy wheel repair putty (eBay Link? This is a specially formulated putty to work with alloy wheels and I found it to be very effective. Sandpaper (200, 400, 800 wet, 1200 wet) Masking tape, scissors, old newspapers to mask Clean rags Water for wet sanding Wax and grease remover/Degreaser Old toothbrush Rubber gloves For illustration purposes, I have selected one area of a rim where you can see kerb damage. This is what I’ll be working with. Step 1: Prepare the surface for repair Using degreaser, toothbrush and a rag, scrub and clean the area and get the grime out of the damaged area. As you can see from the above photo, there’s a lot of grime in there. Next, use the coarse dry sandpaper to remove any material that maybe protruding out of the surface of the wheel. We need a smooth surface and the alloy wheel putty needs to fill in the scratches. The following photo is after sanding and washing the area. Step 2: Apply the repair Putty The putty is a stick and has the texture of crafting clay. It’s a two-part putty and you need to knead it between your fingers for the two parts to mix up (wear gloves for protection). Then roll it on a flat surface to form a very thin bead. Place the bead on the damaged area and press firmly. As the two parts start to react, you can feel the putty heat up. It hardens up rock solid within about 15 minutes. You can start sanding in about an hour. Remember not to apply excessive amounts of putty, because a lot of effort will be needed to sand it down if you do. The stuff is a bit harder to sand than regular body filler. This was the first spot I applied the putty to, I applied a little too much and had to spend a lot of time sanding it down. So once again, VERY little. This photo is probably a bad example of how to apply it, but you get what I mean. Step 3: Sanding Start with 200 grit dry sandpaper and work your way to a smooth surface. Use masking tape to prevent damage to the tyre. If you plan to do only a touch-up and not paint the entire wheel, you might need to mask the wheel as well, to avoid scratching it up. Run your bare fingers on the edge of the rim from time to time and feel the smoothness, you should be able to tell if there are imperfections. When the surface is smooth, move to wet sanding (first 800 grit and then 1200 grit to remove the fine scratches). If you plan to paint the entire wheel, water sand the wheel with these two papers so that the surface has a “blunt” texture. The new paint will stick better this way. After the sanding is done, the surface will look nice and smooth, no more kerb damage! It’s important to sand the putty down so that there is no excessive putty between the tyre and the wheel, you can insert the sandpaper into the gap and sand away, the original curve of the wheel needs to be maintained. As you can see from the above photos, I have sanded the putty all the way down to the rim so that the only bit remaining is the putty that fills the scratches. This is exactly what we need. If you feel like you need one more pass, go ahead and repeat step 2 and 3 again. This is it for the repair. All that is left now is to paint the area. I will cover that in a separate post. Let me know what you guys think and if you know of other ways of DIY methods to repair wheels. Thanks for reading! Cheers!
  2. Already discussed in detail. Search the forum.
  3. Vacuum usually goes away immediately after the engine is turned off. Anyway, to determine if there is actually no problem with the booster, before you take things apart, perform the following test explained by Rumesh88:
  4. Davy replied to MADZ's topic in The Lounge
    Holy sh!t!
  5. Davy replied to MADZ's topic in The Lounge
    Is it just me or does the side body sculpting on the Caravan look like two massive dents?
  6. The booster is a sealed unit and replacement is the recommended option if it's faulty. Apart from the noise you hear, is there a lack of power assistance or issue in the brakes?
  7. Davy replied to Le Sabre's topic in NISSAN
    Quite normal after the rack has been machined. It might loosen up a bit with time, but not to how it was originally. The only thing you could do to restore it is to install a new rack IMO.
  8. My opinion is that drivers in Sri Lanka who consider them to be obedient drivers sometimes don't even know that they are actually not that different from the rest of the herd. So I think @Kavvz's "Category A" needs to be split into two: A1: Drivers who are REALLY saints A2: Drivers who THINK they are saints Every time you didn't give way to the vehicles approaching a roundabout from the right, you were wrong. Every time you let half of your car sit on a junction box, you were wrong. Every time you let a portion of your car cross the "give way" line at a junction or traffic light, you were wrong. Every time you ignored the pedestrian waiting at a crossing, you were wrong. Every time you thought you could follow that ambulance to get to your destination quicker, you were wrong. Every time you went through an amber when you could have safely stopped, you were wrong. Every time you didn't indicate (or indicated too late) when you are turning or switching lanes, you were wrong. One can obey every single road sign, speed limit and traffic light and sure, that will get you out of trouble with the cops, but they can still be a retard if they're are not courteous. Honestly, I think only a handful of drivers are courteous. I was actually stunned when I came to Sri Lanka in March and drove my father's car for the first time after 2 years of driving abroad. I realised that you require a certain style of driving in Sri Lanka and I've lost it after 2 years of being away. Within just 10 minutes of driving, I had to stop by the side of the road at Athurugiriya junction and catch a breath because I had to remind my self that I was back in Sri Lanka, driving among retards (not all, but the majority). People don't realise they are not courteous - it just comes naturally to them. For example, if you need to cross an un-monitored junction (no cop, no traffic lights), you just need to slowly creep forward until you are through, otherwise you will not get anywhere and the drivers behind you will just drive you mad stomping on their horns. In theory, that is wrong, but that is just how it is because no one else will give you way! My point is, we can have all highway codes and rules written on paper. But abiding by them doesn't make you obedient. It is that, plus courteous driving that makes you a good, obedient driver. So I think the real question is, how many of us are really courteous?
  9. Glad it's working again. This is why the order of bleeding is very important. There might have been some air trapped in the RL line that caused that wheel to lock up.
  10. I can't believe the fairy tales mechanics tell these days. Did you see the mechanic take the pistons out? That damage on the piston could have not been causeb by excessive brake oil pressure. While your mechanic was trying to take the pistons out of the valve body, he must have inserted some sort or metal rod through the top 4 holes push the pistons back. That's the only logical explanation I see for the damage IMO. As Rumesh said, these vales rarely become defective. What exactly was the "imbalance issue" you had? Left-right or front-rear?
  11. That actually looks to me like the gap between the aluminium core and the side tank of the radiator. The blue circular thing is the drain plug. So it might not be a leak in the expansion tank, but the radiator itself. In any case, you need to get it checked out as others have mentioned. A good radiator shop with the ability to perform a pressure test should easily be able to locate the leak.
  12. Not the same wheels. The ones on the Mitsi are 10 spoke 18 inch 7J. The Allion ones are 8 spoke, probably smaller in size too.
  13. Glad you managed to sort it out. Thanks for reporting back.
  14. First you need to get the exhaust inspected to find out where exactly the leak is. If it's a leak in one of the pipes, you can simply get it repaired. If it's a resonator or muffler that has gone bad, then you're looking at a bit more expensive repair because you might have to replace them.
  15. In my case, I had some deep scratches which had to be touched up using a touch up pen. Then I used wet sandpaper (1200 grit) and lightly sanded the area followed by a polish using Armour All cut and polish. If yours is just clear coat scratches, a simple cut and polish would do.
  16. Please plz search the forum.
  17. After a cold start, does the RPM go above say 1500 and slowly stabilise to a normal level (700) when the engine becomes warm? Does the RPM drop happen even when the AC is switched off? When did you last get a tune-up done (throttle body clean-up etc.)?
  18. Thanks mate. Yes, the RalliArt does have stiffer suspension than the Lancer. Yes, as I've mentioned above, I just hate that gap. I'm weighing my options between coilovers + grey stock wheels vs the Evo wheels + stock shocks. Theere is very little clearance at the front on full steering lock, so I'm not sure I'd be able to go for coilovers with these wheels without having to do a major suspension change.
  19. A productive weekend. Installed the wheels and the heated seat wiring! This is just after coming back from the tyre shop. The centre caps have not been put on yet. I only got the wheels balanced, but not aligned. The front needs camber adjustment by the looks. That gap at the back is a bit scary too although the wheels didn't rub when I did a bit of heavy driving on humps and stuff. They will definitely rub when the car is fully loaded, so lowering is now off the table. The car is more steady when cornering now due to the wider tyres. I'm not 100% about the colour. I might just dip all the wheel faces in Anthracite Grey. But she looks pretty badass now IMO. Spent a good 4 hours or so installing the heated seats. What seemed a simple job turned out to be a bit more complex due to the fact that almost half the dashboard and the entire centre console needed to be taken off to do a proper wiring job. Mid-job. Butchered interior. The centre console and the new wiring. In operation. Passenger seat on high and driver's seat on low. The heat takes a couple of minutes to kick in. Also, the heaters don't work if no weight is detected on the seats.
  20. Thank you! I'm doing great machan. Yourself and the B4? Yes, the drive on snow was a different experience for me, but the car seemed very comfortable on the different surfaces I put her through during the few hours.
  21. Yeah I don't think you should worry about it. Let's see if other Lancer EX owners see this thread and respond. @E L N I N O is one person I can think of. Also, the CS3 does make a sound when the ignition is switched on. It comes from the IACV. You need to stand very close to the throttle body area (with your ear buried in there really) and you will hear a faint clicking sound.
  22. Finally! Evolution X MR BBS wheels, powder coated in charcoal grey. Arrived today and loving them! Another update: I took apart the entire interior of the car to clean it up and found that there is a connector on both font seat that is not connected to anything. Lifted up the carpet and found that the other end of the connector, coming out of a wire harness in the car has also been taped to the harness. I assumed they were for heated seats. From memory, heated seats was an option only on the Evo. Anyway, after a bit of research on some local (Australian) forums, I found out that they can be hooked up relatively easily. Here's the thread if anyone is interested. So I got the switch and the wiring harness from eBay. I need a relay and a fuse to complete the job, so that's up next as well. Here's the switch and the wiring harness: Stay tuned!
  23. Guess what @Jor-el, the buzzing sound is there on mine as well (being different engines also). It comes from the throttle body for sure and I'm pretty sure it is from the electronic throttle (the part is probably same on all engines), because applying pressure on the electronic throttle causes the frequency of the sound to change. Some other findings are: - Sound is emitted regardless of whether it's before a cold start or when the engine is at working temperature. - It seems to stop as soon as the engine starts - It lasts for a brief moment after the ignition is switched off I'm going to assume it's normal for now. Have to do a bit more digging, failing which I will ask the mech at my next service, because I get it done at the agent. EDIT: Adding a video to demonstrate mine I switch the ignition ON at 0:06 and crank the engine at 0:11. During this period, you can hear the buzz (listen on full volume). The ticking sound can be heard very well at 0:06 for about a second.
  24. Agree with Crosswind. Don't blindly replace the ECU and expect everything to work. There are things that you should rule out before even considering ECU replacement. For example, does each spark plug get a consistent spark when this issue occurs? If not, it could be due to a faulty ignition coil. They are known to fail with age when the engine heats up. The Wira has a 4G Mitsubishi engine and you should be able to find many compatible spares around.
  25. The ticking sound is normal. I have the same ticking noise and I've heard this on pretty much every 2008+ Lancer. According to what I've read, it's the ABS and EBD systems powering up and performing a self-check. Strange, I haven't heard this buzzing sound though. I'll check my car and let you know tomorrow. Almost midnight here now.
