The Stig
Everything posted by The Stig
  1. While you are at it fit a beat silencer and some underglow neons. B!t¢hes dig shiny and loud things yo!
  2. Why would you want a crushed tin can that the Japanese throw away? Can you import an r grade car? No, only as separate parts for example as half cuts. Can you assemble half cuts and register it as a car? No Should you register it and use it? defiantly no if you want yourself or whoever is driving it to be safe. Can you register it and sell it at a profit? Good luck with that, most valuation places will detect accident damage.
  3. Ofcourse not all cars from the manufacturers I stated comes with rear independent but almost all of their cars has independent rear from the compact sedan category up, Honda even used to have double wishbone in the front upto the es series. The Japanese exceptions are Toyota and Nissan. I think the last rear independent cars from Toyota was the 110 and Corona T210. Nissan droped it from the fb14. Your observation is correct and that is exactly why I said Toyota did the right thing by adopting the mass market mentality (from a business point of view). The average Joe doesn't really care what type suspension his car has, in fact if you ask majority of Sri Lankan car owners they wouldn't know the difference between torsion beam and multilink or double wishbone. For most people a car is an investment, they try to find the car that they can sell off with minimum loss. I know most people don't even take the cars for a good spin before purchasing. Sadly for most the car has become something simmilar to a microwave, you buy it use it and then continue with your life. As for the reliability question less moving parts = less things that can go wrong and less maintenance. But simplicity doesn't equal to better ride or handling.
  4. We are talking about allions and mass market grade cars here and you want to compare it to a 340hp car, lol have you finally lost it ? Thats like saying the Nissan sunny is a fun to drive car because Nissan also makes the R35 GTR. Also if you are really considering lexus you missed the most important one, which is the LFA. You know that most lexus cars have complete different suspension setups than the average toyotas right ? In fact i think none of the toyotas being brought to Sri Lanka below the crown range (with the exception of the rare camry) even has rear independent suspension. On a side note about the 86 can you consider a car that was "Jointly" developed with Subaru a Toyota ? And come on dude do you want me to name "Performance oriented" cars that Honda, Mitsubishi, Nissan, Subaru and Mazda have made while Toyota was busy making this one car ? Thats why i said " last time you heard that Toyotas are fun to drive ", name one front wheel drive sedan from this decade thats fun to drive. I can name plenty from Mazda, Honda and Mitsubishi.
  5. The wagon R has quite a comfy ride for its size due to the soft suspension, on the downside its under powered and that tall body along with its tiny tires + soft suspension are not helping it in the corners.
  6. Well to be fair when was the last time you heard that Toyotas are fun to drive ? Mass market mentality hit Toyota and they did the right thing because this is actually what the average joe want, AL is full of enthusiasts so of course we don't like these (myself included). The problem is when the average joe buys a Toyota for the wrong reasons.
  7. I completely forgot to post the images Here you go;
  8. Seems like a common problem in bjs, I had this too but didn't need to replace the sensor. The speed sensing ring on the hub had gotten loose in my case. You might want to check this before replacing a new sensor, maybe cleaning the rings will help.
  9. Most people don't bother looking underneath to check if the car is awd or not, in the heat of the moment they just buy it and only realise that the car is awd when a mechanic points it out to them. I know someone who did an awd to fwd conversion to a bj5w, he didn't know the car was awd until he had to change lower arm bushes and lifted the car up. There is no major conversion here, the only thing people do is remove the rear axle and propshaft. This does help cause it reduces weight and mechanical loss but this car won't be as efficient as a factory fwd car.
  10. Guys reviving an old thread since my service Is due. I use to do service at care point and but they screwed me with a interior cleaning job. Anyone else has done a service from slit autocare nugegoda? They seem to be a decent place.
  11. Yes but there are some genuine reasons why one would need to change the odo reading if it's stored locally, for an example if you replaced your guage cluster the new cluster would have a different reading. There are many tutorials online on how to do this based on specific car models, due to ethical reasons I will not post any links. But basically it's a matter of editing the nand IC with hex, some are read only so alternatively copying the old hex values from the old meter clusters nand chip into an empty nand memory works as well.
  12. Just a thought, aren't fuel system cleaners like 3m and ##### suppose to clean the o2 sensor and exhaust system as well?
  13. This car has the F-4EAT gearbox, same as the mazda bj5p. For Mazda bj5p (basically the same car underneath) you need to use Mazda mV (v as in Roman number 5). Generic Atf has different chemical composition and most importantly higher viscosity. Unfortunately unlike other Toyota branded Atf etc there are no substitute products in the market from generic brands that matches the chemical properties. Do not confuse this with mercon V Atf as that is different (discussed before on a thread by JDnet). Dextron iii is not suitable for this car as it's too thick, you have to use this specific oil or the performance will be sluggish. Asiri motors, rainbow motors and new rainbow in Panchi has this oil and so does mazna Lanka (3rd party garage specializing in mazda cars). A can is around 11-12k, mazna takes around 16k-18k for an Atf change including labour.
  14. Oh well as long as it's "doctor owned" it should be fine ?
  15. Most of the people you know actually no nothing of cars. Time to find new friends. "Better" options in this budget would be; Bj5p facelift Civic es series / late ek3 vi or virs Lancer cs face-lift models 110/111 is okay, boring and way overpriced but heaps better than the fb15.
  16. What is the battery 12v30a or 12v40a ?
  17. Before you repair the car you have to submit an estimate to the insurance. If they approve the estimate they will pay the full amount, if they don't agree to the cost they will communicate at the time. Do not get it repaired before the estimate is approved.
  18. Kal-el good to see you here too, I hope batman didn't do too much damage #teambatman On a series note i think it depends on your personality. What I mean is vehicle personality, Are you someone who enjoys driving? If so the E60 would be a better driver centric car. The 7 is more of a luxury cruiser, more or less intended to be a chauffeur driven car. You seemed like a guy who likes to cruze, chillaxing and all. That's why I recommend the 7. I on the other hand is a very aggressive driver, the kind of person who takes the longer route just so I can drive the car longer. I personally would get the e60 over the e38 anyway.
  19. On the point of ladies opinion don't bother with ones here, trust me they want to buy vezels and gp5s. In terms of the your actual selection I think the 7 would be the best bet out of the lot. Okay okay I am a bit biased towards Beemer but it makes sense even against the e39 and e60 given the bells and whistle and the pure size of the car itself. Also I think you wil have an easier time maintaining a Beemer here than a jag or an audi since there are multiple 3rd parties for services /repairs.
  20. I have the 140 bar (big) unit machan, I bought it for 19k. It doesn't have the detergent bottle on the gun, it's located behind the motor unit. I'll post some photos in the evening. The 100 bar was only 12k at that time. Note - I cant seem to quote the last reply properly on mobile in the new site. Madz please have a look.
  21. My Chinese unit doesn't spray detergent at full speed either. You need to reduce the pressure from the gun (i dont know if the INNOVEX one can do this) and then it forms up, then you wash it away at full blast.
  22. Isn't the goto response "Did you try turning it off and on again?"
  23. Since everyone else has asked about wheel alignment need to know something else as well. Does it happen in a particular gear or at a certain rpm?
