August 15, 201610 yr Hi guys, Is it possible to import a R grade vehicle from Japan without doing the repairs before import it ? Please let me know your thoughts and known facts for me.
August 15, 201610 yr Author Say somehow you import it, is it possible to register it in Sri lanka without an issue ?
August 15, 201610 yr Why would you want a crushed tin can that the Japanese throw away? ย Can you import an r grade car? ย No, only as separate parts for example as half cuts. Can you assemble half cuts and register it as a car? ย No Should you register it and use it? defiantly no if you want yourself or whoever is driving it to be safe.ย Can you register it and sell it at a profit? Good luck with that, most valuation places will detect accident damage.ย
August 15, 201610 yr Well IF you like to be in two places at once in an accident by all means you should somehow get it to SL...
August 15, 201610 yr Author Thank you guys for valuable comments. I thought it is possible to bring downย car with minor damages and register it for a lesser price of cause. However I didn't want to import a half cut vehicle parts and merge them and drive. Edited August 16, 201610 yr by dilini
August 15, 201610 yr If it is a R grade car that is unfixed you probably won't be getting the JAAI (or any other) certificate. Thus you can't import it to SL as a functioning car but only as parts...which means you won't be bringing a complete car.ย Then again...depending on the extent of the damage a R grade car fix-up might not cost that much but then for a bit more you probably could get a car without any accident history. Edited August 15, 201610 yr by iRage
August 15, 201610 yr Thought this might be useful for anyone who might later come across this thread n dont know what the grades are.... ย Grading Information S Superior to Grade 6 or higher 6 or higher is as good as new. Exterior and interior are in immaculate condition. Some cars in these grades have never been driven. 5 โ The car doesnโt need repair. The car has been repaired slightly, and the repair is in very good condition. No body parts have been changed. 4.5 โ The car has been repaired slightly, and the repair is in good condition. It becomes a grade-5 car with slight repair. There are a few slight scratches or dents. 4 โ The car is in good overall condition, but there are a few scratches or dents. 3.5 โ The car has some conspicuous scratches or dents. The cars head-light support panel or back panel may have been repaired. 3 โ The car has many conspicuous scratches or dents. The car has some paint blemishes. 2 โ The car is in very bad condition 1 โ Theย car which may have one of the following An aftermarket turbo An automatic transmission converted to manual transmission Flood damage RA The car has had accident damage which can be ranked MINOR, and has been repaired. Rย A car which has had accident damage, and been repaired. The auction definition โA car which has had accident damageโ is a car where some parts or panels have been repaired or replaced or need to be repaired or replaced (or has some visible marks from frame damage) : Lower Tie Bar or Frame Windshield Piller (A Piller Center Piller (B Piller) Rear Piller (C Piller) Strut Housing Roof Panel Trunk flooring Panel Floor Pan *** /0 โ The car has had accident damage, and has NOT been repaired. Or a car with ย major engine trouble.
