Nilantha
Everything posted by Nilantha
  1. Aruna, I also have bought complete engine for my Trad sunny for 20,000/= it was in 2003. Now days engine cost has been reached to 50,000/= because of custom taxes. So you may not be able to buy engine for 20,000/= (I can’t sure) also your sprinter model also old one. So it is very difficult to find complete engine. I think, its better you can find engine head. Engine heads available in panchikawaththa area. try this number and ask telling your engine model. This is one engine shop called SITHARA MOTORS near the Panchikawaththa Bridge. 5346612/0777709008 Anyway try US Spare parts- Deheiwala, japan lanka - Kalubovila, Jayasiri motors- mawanella, Kurunegala Yunikon, Ananda Auto Plaza – Kurunegala, Silwa motors Kuliyapitiya. They had OLD models. Good luck.
  2. call 112 or 119 and make a complain. they will take action.
  3. Nilantha replied to pradfred's topic in General
    i have Nissan E13 8 valve engine with 4 fowared gear box.
  4. Use wd40 to clean the engine???????? This is a real joke. How many wd40 cans need to clean the engine???
  5. Agreed
  6. see this also. http://www.sundaytimes.lk/070408/ST1/006_st1.html
  7. Using Diesel oil for flushing A question came up some time ago about using diesel-rated oils to flush out petrol engines. The idea was that because of the higher detergent levels in diesel engine oil, it might be a good cleaner / flusher for a non-diesel engine. Well most of the diesel oil specification oils can be used in old petrol engines for cleaning, but you want to use a low specification oil to ensure that you do not over clean your engine and lose compression for example. Generally speaking, an SAE 15W/40 diesel engine oil for about 500 miles might do the trick.
  8. see this. http://www.carbibles.com/engineoil_bible.html http://www.oilgelsettlement.com/ Toyota sludge problems For their part, Toyota have the dubious honour of having the most complaints about sludge buildup in their engines - 3,400 at the last count. At the time of writing there is a class action suit going on against them. Details can be found at www.oilgelsettlement.com
  9. u r lucky. but now corolla 121 engine only 55,000/= Visit fallowing web links and gain knowledge. http://www.carbibles.com/engineoil_bible.html http://www.oilgelsettlement.com/
  10. Mate. If you don’t know something just say “I don’t know.” Don’t tell lies and bull talks. Visit fallowing web links and gain knowledge. http://www.carbibles.com/engineoil_bible.html http://www.oilgelsettlement.com/
  11. Magnatic Fuel saver - Not work for me. Soltron - Not work for me ABRO fuel injector cleanner - works for me. 3M fuel injector cleanner - works for me 90 octain petrol better than 95 octain for me. i have 5AFE EFI one. http://www.epa.gov/otaq/consumer/reports.htm
  12. a) What car do you drive now? 110 In your opinion what is the best car around that will suit our wallets? i belive 121 c) Why do you hate Nissans' so much? i used AD, FB12, FB13 i spend soo much money to stop notice and corrosion. But i fail. if u make a new car you can't stop corotion on nissan when start to come.
  13. sorry dud. i don't like "NISSAN" word also. That one also gives same thing when drive few years on local roads.
  14. 121 (give me your one)
  15. Agreed. thats y i hate nissan
  16. send me an e-mail
  17. VVT-i From Wikipedia, the free encyclopedia Jump to: navigation, search VVT-i, or Variable Valve Timing with intelligence, is an automobile variable valve timing technology developed by Toyota, similar to the i-VTEC technology by Honda. The Toyota VVT-i system replaces the Toyota VVT offered starting in 1991 on the 4A-GE 20-Valve engine. The VVT system is a 2-stage hydraulically controlled cam phasing system. VVT-i, introduced in 1996, varies the timing of the intake valves by adjusting the relationship between the camshaft drive (belt, scissor-gear or chain) and intake camshaft. Engine oil pressure is applied to an actuator to adjust the camshaft position. In 1998, "Dual" VVT-i (adjusts both intake and exhaust camshafts) was first introduced in the RS200 Altezza's 3S-GE engine. Dual VVT-i is also found in Toyota's new generation V6 engine, the 3.5L 2GR-FE V6. This engine can be found in the Avalon, RAV4, and Camry in the US, the Aurion in Australia, and various models in Japan, including the Estima. Dual VVT-i is also used in the Toyota Corola (1,6 dual VVT-i 124bhp). Other Dual VVT-i engines include the upcoming 1.8L 2ZR-FE I4, which will see implementation in Toyota's next generation of compact vehicles. By adjusting the valve timing, engine start and stop occur virtually unnoticeable at minimum compression, and fast heating of the catalytic converter to its light-off temperature is possible, thereby reducing HC emissions considerably. Video animation of VVT-i (courtesy of PT. Toyota Astra Motor, Indonesia) can be found here [1]. [edit] VVTL-i In 1998, Toyota started offering a new technology, VVTL-i, which can alter valve lift (and duration) as well as valve timing. In the case of the 16 valve 2ZZ-GE, the engine has 2 camshafts, one operating intake valves and one operating exhaust valves. Each camshaft has two lobes per cylinder, one low rpm lobe and one high rpm, high lift, long duration lobe. Each cylinder has two intake valves and two exhaust valves. Each set of two valves are controlled by one rocker arm, which is operated by the camshaft. Each rocker arm has a slipper follower mounted to the rocker arm with a spring, allowing the slipper follower to move up and down with the high lobe with out affecting the rocker arm. When the engine is operating below 6000 rpm, the low lobe is operating the rocker arm and thus the valves. When the engine is operating above 6000 rpm, the ECU activates an oil pressure switch which pushes a sliding pin under the slipper follower on each rocker arm. This in effect, switches to the high lobe causing high lift and longer duration. Toyota has now ceased production of its VVTL-i engines for most markets, because the engine does not meet Euro IV specifications for emissions. As a result, some Toyota models have been discontinued, including the Corolla T-Sport (Europe), Corolla Sportivo (Australia), Celica, Corolla XRS, Toyota Matrix XRS, and the Pontiac Vibe GT, all of which had the 2ZZ-GE engine fitted. [edit] See also Variable valve timing Lexus VVT-iE http://en.wikipedia.org/wiki/VVT-i
  18. send me an e-mail. i will tel u
  19. basic door :- 4500/= power door - 5000/= to 7000/= double power mirror 2000/= if u r going to buy complete door set u can buy around 15,000 - 20,000
  20. I Usually wash my engine. but nothing happen yet. May be your engine miss from spark plug. Try to clean the engine (remove water from plug sockets blowing pressure air also u have to check plug cable conditions)
  21. CE- Diesel model, AE- Petrol model write to my e-mail.
  22. price bit more b'cos this is a basic car and also not crystal light model.
  23. Be careful when you buy anything from panchikawaththa. Because they are selling local used things also. Mainly when you buy Gearbox and engines.
  24. Its very difficult to find gear box for this model. Not delkanda or wijerama. Only place to find the gear box is EURO NIPON Wadduwa or Dambulla. Unfortunately I don’t have the phone number.
  25. yes he is correct. Colour match is very difficult. Now your car paint is burned from sunlight. if you paint your car matching old colour it will deferent when it burn.
