MV-5
Everything posted by MV-5
  1. yeah, that's my point, since this has two external power sources and measure a consumption of only one power source make no sense. I think there might be some definition (criteria ), ex: KMPL value with fully charged battery without having intermediate charging, or some conversion to KWH to L (i am not kidding :-) ).
  2. kmpl value for a Plugin hybrid? how to define?
  3. once you reproduced this problem, if you rev up the engine (say 2.5K RPM,but vehicle is standstill) , then AC works fine?. If the answer is YES, probably your technician is right. If the answer is NO, that means AC is working fine when the vehicle is moving only. that means AC condenser or it functionality (ex:Fan) doesn't work properly
  4. MV-5 replied to malinda7's topic in MAZDA
    http://www.mazdaspd.com/manual_files/09-22.pdf section 09-22-2 Note: i have never tried to remove this instrument cluster in my Mazda. just providing a link normally i refer (downloaded) when i need to do some DIY.
  5. if it is for power saving,turn signal bulb is the last thing that we need to replace with LEDs
  6. theoretically , this resister should be attached in parallel ( actually what happened is , now this system draws very low current comparing to previous ). , then this resistor + LED should draw the same current which was drawn by a normal bulb but the proper solution is, with these LED bulbs , there should be an LED flasher module.
  7. probably it is "solenoid" .each and every time you turn the key,if you can hear "click" "click" sound (or tick tick :-) )
  8. even in the cold start, RPM>2000 is not normal. do what VVTi said , it would probably solve this problem. you can do a addition test, in "P", throttle it and release, if the engine shows some noticeable lag (ex: once you release the throttle, RPM will start to decrease after 1 second ), then your car needs a TB cleanup.
  9. when your car has some sort of EFI related problem or misfire , never replace your plugs with iridium (if vehicle maker original plugs are copper). if your engine works fine, copper plugs are better than iridium (need to be cleaned for every 5000 km )
  10. yes, re do the wheel balance, when i faced the same problem first i did the wheel balance and it did not solve the problem, then after few weeks i re-checked the wheel balance (not the same place). while the wheel is spinning , the guy noticed that the wheel is buckled, but still it is balanced. i replaced it with new alloy set (JJ , dehiwala), problem solved.
  11. Thanks again, your input is very valuable. when you were about to make your decision about pantry top (3 years back), did u consider about Quartz, if yes , what are the features lead you to opt NueStone over Quartz or granite (other than the cost, i think now cost is somewhat very close)?
  12. Thanks, how about the scratch resistance, and heat resistance (ex: if drop some just boiled water...you know here i am talking about 100C not 250C :-) ) . I know this question is difficult to be answered without having a comparison. I except this kind of answer :-) , "after 3 years i can see only very minor scratches on top which is not noticeable, and we normally place hot dishes on the top and it makes no harm to top at all"
  13. for a single trip, KMPL value make no sense at all. Hybrids are designed to get the advantage of different combination of speed+ power demand . so hybrid fuel figures will be highly depend on how far this usage meets these combination. if a hybrid is going to be used only in heavy traffic then this usage does not meet a good combination to produce good fuel economy. so Hybrid fuel figures should be measured for at least for 5000KM.
  14. Mercantile Fortunes, right? could you please share more about your experience (or actually what you know about the quality of their job)
  15. Thanks MD, I think Titanium cement or tile is not an option for me (since my kitchen setup does not have concrete slab, correct me i am wrong, i am just exposed to this boring stuffs because of my wife :-) ). Laminated wood is also not an option due to low durability and some other disadvantages, Granite is not an option because i need to get very light color top because pantry color is "Honda metallic red". Quartz and Nuestone or any other artificial (engineered) stone would be alternative solutions. Thanks, then i might be wrong, its look and feel like stone (but comparatively "warm" to touch ). I will check the link you posted.
  16. @madmax please check the page number 31 in this pdf (this is not a local brochure ) http://www.romandinicabinets.com/pdf/KitchenChecklist.pdf
  17. it is an artificial stone, somewhat smiler to Corian, ELC**DO is the one who sell this product in LK,but i am not sure about the row material. 'Corian',comparatively less heat resistivity (against granite) is a sort of disadvantage. and in LK so far i was unable to find a place who sell and install 'Corian'. next Saturday i am going to visit few showrooms in Nawala, i know only one who sells this Quartz, if it fits my needs that would be the solution. @madmax, would light color Quartz work for me (does it eliminate the disadvantages of light color granite like off coloring and color patches after 1-2 years)? @Others, please name few more shops who sell and install quartz (i know only SGM) and Thanks all for valuable comments you provided so far, and i am waiting for more.....
  18. my basic requirement to get a good countertop(very close to white color), white color granite has their own drawbacks. so i am looking for an alternative. NueStone is one option, but i know nothing about that other than elcardo said. it is highly appreciated comments on NueStone or any other alternative, to get some idea, i posted a image of my under construction pantry (solid color countertop is the best match)
  19. if any forum member has used this product (for kitchen countertop) please share your experience.
  20. last ATF change? last IACV cleanup?
  21. http://insuranceombudsman.lk/
  22. I ordered this item , waiting to find out whether it is useful or not.
