Magnum
Everything posted by Magnum
  1. Its ruined
  2. I'm starting to like this car
  3. Magnum replied to jdnet's topic in NISSAN
    Is it the Sentra or the Altima thats sold as Teanna in Japan?
  4. I typed SR20 and changed it to SR16, you must have seen it before i edited it Are you talking about Bluebird? Post the pic you saw
  5. Yep its SR16VE as i said above, but there could be conversions
  6. I checked again, its SR16VE The 1.6 L (1596 cc) SR16VE has Nissan's Neo VVL variable valve timing with lift control. It produces 175 hp (130 kW) @7800 rpm and 119 lb·ft (161 Nm) @7200 rpm. Redline is at 8300 rpm. Bore is 86 mm and the stroke is 68.7 mm It is used in the following vehicles: N15 Nissan Pulsar VZ-R B14 Nissan Lucino VZ-R B15 Nissan Sunny VZ-R
  7. You got a point, i guess once you get used to a vehicle it becomes very easy to handle it. Our car is quite big,has dark tints all around, it has no rear camera, no sensors, still my dad can reverse it in a tight area without a problem but others find it difficult.
  8. Just realized that it has tinted windshield
  9. Got a SR20VE under the hood
  10. i experienced the same problem when i tried downloading 360P MP4 videos through Chrome using IDM, just switch to another browser like Firefox the downloads will work fine, or download the 360P in FLV format
  11. Did you internet download manager to download? and was the browser google chrome?
  12. Ever wondered how to move to the rear seat in 3 seconds?
  13. Sorento isnt a all new thing either, it has been in the market for 10 years now. INMO its very successful
  14. It seems to be a thing with Toyota these days, not just Corolla even some other cars have a similar looking dash
  15. Epic Couple
  16. I thought i was the only one who thought the front looks like an Allion
  17. 2014 Toyota Corolla S
  18. Following a string of teasers, Toyota has officially revealed the 2014 Corolla in the U.S. specification. On numerous occasions Toyota said the new Corolla is going to take styling cues from the surprisingly attractive Furia concept, but the end result isn't nearly as impressive as the concept shown earlier this year at NAIAS. However, it's significantly more appealing than the outgoing generation which should boost sales even further. Sending a bit of a Honda vibe, the new Corolla comes as standard with LED low-beam headlamps and adopts a five-point lower front grille. The interior cabin is more evolved than what the predecessor has to offer and is more spacious thanks to a longer wheelbase which has increased by 3.93 inches (100 mm) to 106.3 inches (2700 mm). As a result of the elongated wheelbase, the 2014 Toyota provides an extra 2.95 inches of rear seat room. Exterior dimensions stand at 182.6 inches (4639mm) length, 69.9 inches (1776 mm) width and 57.3 inches (1455 mm) height, meaning the new Corolla is 3.90 inches (99 mm) longer, 0.63 inches (16 mm) wider and 0.39 inches (10 mm) lower than before. Front overhangs have increased by 0.90 inches (23 mm) to 37.7 inches (958 mm), while rear overhangs have been shortened by 0.94 inches (24 mm) to 38.6 inches (981 mm). The 2014 Toyota Corolla L, LE and S trim levels come with a 4-cylinder, 1.8-liter engine producing 132 bhp (98 kW), while the new LE Eco grade is powered by a 1.8-liter mill rated at 140 bhp (104 kW). Various gearboxes are available depending on trim level, with a six-speed manual for the L and S models, a seven-speed CVTi-S (continuously variable transmission intelligent-shift) for LE, LE Eco and S and an obsolete four-speed automatic for the entry-level L model. The Eco-badged model brings improved aerodynamics and rides on low-rolling resistance tires which enable a highway fuel economy of more than 40 mpg US (48 mpg UK or 5.8 liters / 100 km). This figure was possible by making extensive use of lightweight, high-strength steel which has kept the Corolla's curb weight at less than 2,900 lbs (1,315 kg). Standard equipment includes eight airbags, Bluetooth hand-free phone and audio-streaming connectivity, along with other equipment (depending on trim) such as back-up monitor, power moonroof, touchscreen radio, smart key / push-button start, SofTex seats and apps accessible via the audio head unit.
  19. I know a couple of people who had/have the Townace, its a good vehicle with a 3C-T under the hood
  20. Why not a DA52 Suzuki Every? Its Japanese, not so old, fuel efficient and very easy to drive
