Everything posted by TurboSeavy
Notes On Upgrading Tyre/rim Size
Thanks Devinda, I gotta check it out. If it's half the price for a same spec tire that's one hellwa' attractive deal. Well... In the late hours, on my way home I pass the Narahenpita Junction, and there is a little redlight pass towards the Nawala road (under the Bow Tree). I usually don't apply break there, and just take the turn around 45~55 kmph. Doing it just for fun. Never had a problem with it even after the tire swap. Anyway... gotta do a swap and see.
Whats The Best Plug?
Had NGKs before and Replaced with the same. Iridium plugs are expensive. Agents said it would do about 100K kms with Iridium plugs. Anybody using Iridiums? and do you get any performance difference other than the longivity?
Coolant Levels And Topping Up
Forgive me if I'm wrong, but the way I have heard, if you are using coolant, then there should be no coolant level dropping in the short term. If coolant topups are required so often then there could be a coolant leak somewhere in the coolant system. Again, this is what I have heard... not sure. I think the main reason for using coolant instead of water is to avoid corrosion in your cooling system. Coolant is non water based, so you can avoid cooling system blocks, etc. And the colour of coolant helps detecting any coolant leaks if there are any.
True. With the increased balloon size the manifestation of the rim size is less... Then again I guess Nissans are a bit bumpier than Toyotas and Hondas.. what to do bro... I did not feel any understeer, got to swap the tires one last time and see Why would I run different sizes like that ??? Well... bro, haven't got the bucks to buy all four at once man. The Damn Jap tires cost about 8k+ each. Hopefully if I get some 'Avurudu Bonus', I will be able to swap the rear tires with the same spec.
This is one interesting discussion, Thanks to Hola for starting this thread. I got the car with 15" alloys and 185/55 falcon tire set. The low profiles had really hard side wall and the ride was a little bumpy. In the last tire change I swapped the front tires to 205/60/15R s. And I immediately noticed the difference in ride smoothness. One other thing I noticed is that the 60s have softer side wall so they are much more vulnerable to damage (well… I have abused the low profiles many times but they withstood all that punishment). I guess, not only the balloon size of the tire, but also the width of the tire is very important to the smoothness of the ride, as SL highways are much like off-road death pits. Fat tires increase the drag a little bit and burn a few rupees worth of gasoline more, but they give better traction, better handling/breaking and better comfort. I still have the old 55s in the rear and hoping to change them to 60s soon.
Suzuki Grand Vitara 3door???
Has anybody seen this thing? http://www.MyOnlineImages.com/serveFile.aspx?af=8126 http://www.MyOnlineImages.com/serveFile.aspx?af=8125
Front Suspension Noises
Hey nira, you will only have to replace the entire lower arm only if you are chasing after genuine parts. Even the genuine Japanese bush will tare off in a matter of months thanks to the SL road system. What I do is get the lower arm bushes replaced. You can't get the genuine bush but there are many Thai, and even SL made ones that will do the job for about 6 months, and its back to the replacements again.
Scientific Body Styling
Just what I had in mind machung. Can you recon any good place for me bro? The car colour is metallic silver.
Fixed A Mesh Grill!!!
Now this is what I call a sensible modification. Decent and simple, but awsome looks. Hola, congrats on creativity man. I have seen some cars with massive grills that spoil the looks. This is a fine example for anyone thinking of a front grill to improve the looks without even a bit of hurting to bodylines. One word: AWSOME!!!
Yeah machung, I gave up the idea of going back to that place for a bodykit to be done. He did not had the designs I had in mind anyway. Gotta search for an alternative place. According to them, the only way to fix the side-skits (they call it side balancers), is to drill the undercarriage. I'm not sure about it. Come on man, post us some pics of U R ride please.
Motoring Magazine Test Reports
I'm afraid I think I have to agree with Duncan and others who feel that most of the reviews are not worth reading... I was going through some SUV reviews and the complaints were, Nissan X-Trail - The meter panel is in the middle, and it looks cheap Honda HRV - Interior is spacious, more like a van (Hello???) Most of the time you don't even feel like reading the rest of the review, because you feel that there is no gain in knowledge in them. What a pity!
2008 Mitsubishi Lancer
Impressive, how they market it... http://www.lancerproject.com/lancer/
Electric Voltage When Car Is Idle
Quite correct, experienced this phenomena last week, when a colleague of mine had to jumpstart his car.
K&n Filters
I went to M'cade with the intention of buying a K&N filter (corn type), but they were out of stock Anyway, they had one variety which goes into the standard Air Filter Box. When I queried about the difference the they said that both are same, but only the corn type will give the smooth beat Anyway, didn't buy it, yet. I guess there should be a difference in the two. Do you guys have any idea?
I paid a visit to some bodykit maker and they said they need to drill the buffer and the floor board to install the bodykit. Is that the standard procedure in installing a bodykit? Drilling the buffers are ok, but the idea of drilling the metal feels quite disturbing. Hola, I think the car looks nice with the grill. My personal feeling is that only the huge, overgrown grills look odd. like this one--v
Does Turbonator Really Work?
While U R busy upgrading U R ride with the above mentioned stuff, don't forget to buy one of these for you too... http://kalecoauto.com/index.php?main_page=...;products_id=40
Rx8 In Plenty
"Devinda_Z - this story about the SIngapore cars having high milage i can't quite understand.... i've noted by looking at many odo's that Singapore cars avarage 35,000km's in unregistered form" I asked this from a Singapoorian and the guy said that some of them travel to Malasya. Few of those trips pops-up the milage. "fuzzo - have you guys noticed all the rx8's being imported to SL. i've seen atleast 4 of them for sale at various sales." RX8's go as 1300 CC (on the record). Maybe the car sales guys waveoff the tax and bag the whole profit
Survey:do U Do Interior Cleaning/detailing
Every service I get a full interior cleaning and leather treatment done. The Pit Stop guys use AutoGlym. hey mini, you are kidding right?
Intro...
Thanks to all of you. Of cause Kim, I will definitely be there in the meet. AL forum Rocks!!!
Favourite Car Chase?!?
1974 Gone in 60 Seconds car chase Directed by H.B. Halicki The movie runs for about 2 1/2 hrs while the car chase is almost 50 minutes! The chase was on for a boosted mustang And the 2000, Gone in Sixty Seconds Directed by Dominic Sena Again a boosted Shilby
Does anyone have this turbonator thing installed in the car? One of my friends recommended it for improving hp + fuel consumption. He ad used it in his Diesel van and says there is a significant improvement in pickup and the fuel usage. The figures on their website (http://www.turbonator.com/) seems attractive but, I feel that they are quite overwhelming for a piece of metal.
Intro...
Hi All, Thought its better I introduce myself to the forum. I'm Sampath, a vehicle enthusiast just like all of you. Only recently I got to know of the AL forum and I have the utmost respect for all the cool people here. Respect to all the Auto Gurus, Admins.
Accident In Seeduwa
The three gentlemen we lost are Dialog Customer Service Officers; Dilan Wendel Grero Sandeep Kaushal Jayasinghe Warapitiya Antony Oldrin Laiton Fernando Deeply sorrowful moment for everyone. Anthony was a good musician. He was expecting to release his own album soon. Too bad he never got the chance to complete it.
