Price Of Nissan Fb 15 Super Saloon 2002
Machang, he says new shell with amber rear lights with K plates and for me, 2.2 mill is well worth. Guess what, these so called "new shell" cars being quoted as high as 2.8 mil when I checked last week. Yes, there was a time FB15s were selling at mere 1.5mil mark and B15 (1.3ltr) was selling at 1.4mills, not anymore, absurd prices hit and now it's anyway higher than 1.6mil mark. Having said that even before price hike, new shell has been selling at around 2.0 mill or slightly lesser than that. All in all if Jude had found a good example of a new shell FB15 with K plates, in this market he doesn't have any reason to regret.
Flood Victims (automotive) - Learning Points
May be one of previous owners has done it already. There were dozens of 406's got busted when floods hit Colombo last time. Lesson learnt and my mechanic did this modification to all the cars came for repairs.
Yup, I don't see any reason to set the air intake that low, it's right at the left wheel arch, under the front bumper sort of. Same goes to Toyota Townace CR26/27. It's right at the front bumper.
managed to "sail" through flooded roads during last week without going through any hard times except for the water gone inside sills creates a splosh sound when hard braking. However, this may not be the case for all of us. Saw few of such victim vehicles being tawed, pushed during last couple of days. Guys, let's share the experience as a learning point for others. Simply because I've seen some vans being driven through very low water levels and water sucked inside to the engine. May be due to negligence, may be due to lack of knowledge where the air intake is located. More importantly, high ground clearence doesn't necessarily mean you're safe from water being sucked in. I've disconnected the air intake duct from the original mounting position which is very very low and not more than 10 inches from ground and I'm sure most of vans too got this done as air intake opening is located at the bumper level explains some of townace and liteace I've seen pushing and towing around.
Engine Stops While Gear Shifting
Bugger. Try advancing the idle restrainer bolt a bit, if you're familiar with the system. If this solves the issue and engine RPM is not so high in cold running you'll be better off.
Convert Engine
2C turbo? with or without gearbox? yeah price tag of those have shooted up. However check around before settling down for 2C turbo coz spares specially turbo related stuff are rare to find it seems. Also one important advise, if you're converting from petrol to diesel, make sure to change the differential to a one removed from a CR41. Otherwise you will have to run the engine close to rpm limiter on outstation driving. Reason is petrol diff is degined to achive higher speeds at higher RPM of an average petrol engine say 7500 ~ 8000. RPM limit of an average diesel engine is much lesser say 5500 ~ 6000. Diesel diff is designed to go at higher speeds at lesser RPM due to this reason and diesel engine is capable of handling more torque on lower end than a petrol. Therefore all in all, change the diff to a known one removed from a CR41.
Corolla Vibration Issue
why don't you just ring up M* Or*ani*ation (112 441 563) or T*yo*a *anka* (112 939 000) and check it out, easy bet rather than waiting for someone to reply.
there are two circuits in carb, simple terms, cold and hot let's say. Ask your mechanic to tune the car when it's in working temperature. Usually engine runs on high RPM when the cold circuit is activated that explains your statement, RPM is correct as soon as you started the engine. RPM drops when the vehicle is in working temperature and your mechanic should tune the engine in this condition. I assume this is a CK1 with electro carb. If so things would be pretty easy as hot circuit is activated electronically in this model. If things don’t get sorted out, take it to a conversant carburettor guy.
Using Car Ac And Saving Fuel ?
5 liters means roughly around 500 rupees as per current prices of petrol. Not much comparing the comfort of A/C specially on long trips you'll be fresh untill reaching the destination. You'll hardly feel tired. about CO2 build up, it's a myth. Even if you set recirc at closed position little amount of air will be taken from outside, unless otherwise some maka bass fellow has completely closed those ventilation ducts. I know some A/C fellows who welds the original fresh air intakes to maximize the cooling effect!!. And NO, never felt drowsy though I always run with recirc on simply because I don't want all dust and dirt to block the pollen filter.
Second-hand Car Market: Myth And Manipulation????
in contrary, there are people out there who has bought, and will continue to buy. If there weren't any buyers would the sellers quote high prices? Remember, market equilibrium is where demand meets the supply.
car market is now filled with absurdly priced wrecks. Saw a '96 110 L grade with non english plates asking price was 1.99 mil!! saw a FB15 Super Saloon, a wreck, accidents all around the body, paint patches like as if hand painted, GY plates and white color, asking 1.79 mil. This was for a friend of my brother and I told the bugger to wait till market settles down. I seriously don't see any rationale behind this sudden shoot up, unless otherwise someone (car sales??) trying to artificially manipulated the market, so once import tax lifted, it'll settle down at where it was rather than going down from where it was.
correct, actually coolant circulates through the heater matrix all the time (if not removed/blocked due to leaky heater matrix). This was there in cars of 40's or 50's for that matter Only a flap will open and makes the air flows through the said heater matrix. Amount of hot air mixed is depends on the position of the temp setting knob or in climate control versions how system controls the said flap. In most of systems including sophisticated climate control setting up temp low doesn't necessarily mean that compressor will cut off. Having said that, in climate control systems, if you set the temp above certain degrees (depending on the outside temperature again) will make the compressor to cut off frequently.
Idle Rpm
it all depends on the vehicle, make, engine type, what technology manufacturer used all that. It's marked on the RPM meter on some of models but again it's a question whether you can set the engine speed at ideal/best. Specially on carbeurator engines it's a nightmare to set at best and often is a hassle when set at lowest because engine tends to die suddenly in cold running. Also if the engine mounts are weak, you cannot set at best lowest RPM due to excessive shrudder. All in all this is something very hard to generalize and have to sort out case basis.
Convert Engine
if the vehicle has english number plates, then they'll issue new plates with D upon the hyphen/dash between letters and the number. I heard now RMV issuing a different type of plate without giving 325 - for non-english plate conversions. That is if the petrol number is let's say 18 - XXXX and new plate will be WP 18 D XXXX. This is something I heard from a person who checked from RMV about couple of weeks ago. charge will depend on the date of registration. If it's within 4 years charge will be around 250,000 (not exact amount) and for others it's 35,000.
High Speed
did i hear explode? amen to that What's the new engine you replaced the old one with? for this vibration issue, check both drive/prophellor shafts universal joints and also check is there any uneveness on the shafts, specially the one drives rear axle.
High Speed
had a J44 long wheel base for a while. Not the best vehicle to drive at 80. Max I did was 90 on Colombo - Negombo road. I felt as if pistons or some inner parts of engine would come out. Reason is differential and gear ratios are optimized for hard terrain driving not freeway cruising of this model. However they have improved the speeding ability upto 120kmph in the last release of J44 in 1980's with the redesigned 4DR5 engine (51A?) with butterfly pistons. This improvement focused on the highway cruising of this model and the negative feedback it recieved on speed. All in all J44 aint a speeding vehicle and no where stable in highspeeds above 70.
- Post Whoring - Part 2
Happy Birthday Pradfred
many happy returns of the day..
Tinted Glasses
photochrome lenses? Bloody expensive a pair of glasses for a spec. So a side glass would be nearly impossible to afford and i don't know how they will keep the photochrome ability together with safety measures such as braking into small pieces in an accident.
Tinted Glasses
Agree with you on that taking a chance with them. Also if the tint guy is smart enough not to leave a single millimeter of a strip without the tint on (when the shutter put down half way of course) hardly they notice there's a tint on. Still waiting to see what's the plight (if at all) of factory tint glasses.
Mp3 Fm Modulator
Euro cars are more strict in this matter. Not only cig lighter, but some of the courtesy lights/reading lights, glove box light and even brake lights goes off as soon as you switch off ignition. only horn, parking/head lights, door lights and the stereo will work till economy mode activates.. at least on 406 that is
Tinted Glasses
driving a beemer with black tints might make you another wanna be VIPs and cops might not take a chance
3 English Letters
I see another discrimination on the way.. so far it's only english numbers and non english numbers, obviously there's a price difference between those two vehicles of the same make,model,year,options. This gonna worse the situ.
Should I Get Replaced My Piston Ring Set
I would suggest to take a look at valve sheets before suspecting rings or any possible oil leak through crank and cam oil seals?
Driving With High Beam On- So Irritating
This was a decipline I had since early days of driving and still I do, but sadly most of other drivers tend not to do specially those who has driving position so high, bus/lorry drivers. Used to do the first trick MRM mentioned but one day I did it and what I last saw in the mirror was that vehicle taking a sharp left turn and going to the curb. Don't know what has happened to that vehicle and don't do it around much.
