harshansenadhir
  1. agreed, what most of operations does is bring down CKD kits and reassemble. There were few initiatives like Araliya seats were benefitted. However, this used vehicle assembling project can help saving forex as they bring down parts at a penny and a half though safety can be questioned. For L board's economies of scale, we got to start operating in order to think about scales, rather improving and refining processes.
  2. many happy returns of the day mate..
  3. harshansenadhir replied to Uditha88's topic in General
    they have a point, if you use the fan with air recirculation off ( takes outside air into the system) if you don't use the system there's no way the cooler matrix (core) collects dust, in fact cold/wet cooler collects dust when in operation than when it's switched off. Having said that, A/C has to be switched on for a while at least once a week or so to help A/C compressor and to circulate lubricant (added to the refregirant). This is not an issue for us, simply we do switch on the A/C before we change into 1st gear or D for that matter. . But in countries where A/C is only used during summer, they turn it on for a while once a week or so.
  4. manufacturers nowadays will hardly put anything into a car that'll last a lifetime unlike good old days T belt was introduced to reduce engine noise and there were many T belt failures in high speed cruising and mileage based T belt change too had issues coz idling time of the engine doesn't take in to consideration. T chain emits noise if worn out, means it'll stretched a fraction over time and become loose causing the said sound. What i don't know is whether this can be adjusted. Not quite sure whether we can derive anything about service intervals based on this sound.
  5. timing chains too subjected to wear and tear. It starts emitting a sound when worn out, at least thats what happened with the timing chain of my 79, 504 GR. However, these cars aren't old enough to worry about timing chain. @milindu - great summing up of everything.
  6. people like you will drag this country back by decades. At least be happy of what initiatives we have here in terms of assembling automobiles. I wouldn't say that by discussing it here will do magic. but we got to have right attitude towards it. Used vehicle assembling was a good news for some people whom couldn't afford an unreg vehicle, but then again vehicle importers filed a case against it and a boi approved venture and its customers going through hell to register those. There's something wrong in the equation, shouldn't we more focus on saving foreign exchang and promote local value addition? And as original poster says, why not landy if rexton, kyron are being assembled. Back on the original topic, any news on the tentative LR and Jag assembling projects?
  7. ditto that.. and Mr. Sylvi, not everyone posts against your ideas/posts are idiotic or trying to antagonize you, I'm sure they have better things to do in their lives than spending 6 hrs on internet or trying to antagonize you, if you say so. Further, if you cannot bear the generation difference, writing styles, blunt criticism by all means you can stay pulled. This aint a bow down community only at someone’s age but the level of intellectual
  8. harshansenadhir replied to Uditha88's topic in General
    this quote says it all. The moment you start any electronic component, it draws current from the battery, and that has to be filled by the alternator/dynamo which runs by the engine. As per newton's theory, of every action has a reaction or in simple terms, energy is not created but converted, this drawing current from alternator means energy in fuel has to be converted to electricity. Which means, some amount (may be a fraction may be as much as 10 bhp) of energy is used in generating electricity and not running the vehicle. Which means fuel consumption increases at least by a fraction. to test this, start the car, let it warm up to operating temperature where idle speed stabilizes, switch of all components. Switch on head lights and high beams. You'll feel a sudden load up on the engine. That's due to the additional load created by the current drawing by the head lights.
  9. depends on the damage and condition of the tire, whether using them on a heavy vehicle or not all matters. Got the same done to the side wall damage of a J44, they used a special thread to sew the damaged area and vulcanized from both inside and out. Solution lasted well.
  10. there's a small issue I rather we faced and the reason seemed to be fair enough. Back in '91 my father installed new tubeless tires to then our family vehicle and he wasn't confident of the idea of not having a tube inside the tire and installed new tubes too to make it better at least he thought it would make things better. Alas, we experienced hell lot of tire punctures at a row and once there was a puncture without an alien object poked in but tube itself got punctured. Went to a famous tire joint and they said it's due to the fact that inside of the tubeless tire is designed with some ruggedness and that surface is not ready to hold a tube. Due to this ruggedness, the tube tend to give up from some places where it rub excessively against the innter wall of the tire. So lesson learnt that tubeless tires and tubes don't go together. But in your case as a temporary fix it's not dangerous but keep the spare wheel, wheel bracer and jack ready all the time
  11. not necessary to clean injectors every year and removing them and cleaning them frequently is again asking for trouble imho. Cleaning them every 50k or 40k interval makes more sense. If your car tuned to optimum then there's no necessity to clean spark plugs coz there won't be carbon deposits. However removing them and inspect and ensure the required clearance is maintained would be better. Personally i don't go after such ads and do injector cleaning very carefully especially removing them and fixing. Last time my mechanic gave it to a place where they carry out ultra sound injector cleaning and as i told you, we carefully removed without damaging any of rubber washers around and after cleaning they gave them back on a sealed pack. Charge was 3500 or something close. Also i'm against the idea of running the engine using injector cleaning adhesive as it sends all deposits into the cylinder and no need to say about the potential damage/clogging of the catalytic converter.
  12. Qualis ? Or Smart cab?
  13. so it's a toyota diesel? Van or a car?
  14. lol, not again please don't wanna see this becoming an entertaining forum than what it was. But then again, seems load of fun on the way on a boring sunday. Keeping fingers crossed.
  15. toyota lucida perhaps?
  16. space gear or a vannet largo?
  17. welcome on board mate. I feel that there's nothing wrong in your car as you're getting 9-10 in city. Comparing with your friend's car isn't the best bet to judge your car's fuel efficiency. Coz two figures can be different 1. if your friend drives a manual where yours could be auto 2. Engine capacity may differ. 3. Driving patterns traffic patterns may differ. There are more reasons for having different figures on different cars of the same model. However, if u really really want to give it a try to increase fuel efficiency, start by cleaning or changing the air cleaner element, failing which you can think of cleaning injectors and plugs and drives the car with eco light on (available on FB15 super saloon) as much as possible. But think twice whether its worth the hassle.
  18. don't think any chemical will help this scenario as plastic is melted. Best try would be to remove the panel and level the damaged area using a sand paper and prime using some good plastic prime smooth it and spray with gold blend. Approach a good painter, that would solve the matter. However make sure to be extra cautious when removing the panel as plastic may have become brittle over a period of time. Good luck mate.
  19. harshansenadhir replied to Flanker_07's topic in NISSAN
    going down steep down hills should be either on 2 or L/1 depending on the level of steep.
  20. true, that shows respecting forum rules. You got to respect others to earn respect what we lack here is some commonsense and education together with not accepting mistakes. I was wondering how some of the MPs got elected in this general election. Now i do have answers.
  21. and i'm sure its not peri who has problems but those who try to go against majority and forum rules. Mind you this is a community which represents a cross section of real life society where majority decides and controlled by rules. Look, how many says peri is correct and how many says you and dkg correct? You got to accept what majority says in a community, Let alone forum rules.
  22. harshansenadhir replied to Flanker_07's topic in NISSAN
    different standards mate, that's why i said L and 1. Some manufacturers use 1,2 where as some use L, 2 and so on. Yours od is not there coz it has seperate 3re position where gears will change up to 3 similar to D with OD off and D will change into 4th gear similar to OD on of other cars.
  23. beg to differ mate, we're discussing about vehicles in this forum, so other commodities not mantufactured in Sri Lanka will not be applicable. However there are very few initiatives in SL for vehicle assembling, let alone there's no manufacturing and with crazy import duties and being an island we're compelled to ship vehicles which incurs a shipping value and it all end up buying a good brand new or truely reconditioned vehicle as silvy mentioned is almost impossible for most of common man. Therefore the assembling subject tempting all who wants to get a good brand with near original build quality and is done everywhere globally. India started with assembling vehicles under license and look at where are they in terms of manufacturing of vehicles? in fact Sri lanka first started assembling back in 70's, famous Upali Mazda and Upali Fiat by Upali Motors and Isuzu TXD by Sathosa Motors. Every state owned bus, be it a TATA, ISUZU or LEYLAND was built here using the chassis as only import. Where are those initiatives now? this is something as a country we should re-start, we got all the skills and know how and we're nation reputed for creativity.
  24. harshansenadhir replied to Flanker_07's topic in NISSAN
    recommended gear on downhills is either 2 or 1 or L on autoboxes.. not D with OD off AFAIK
  25. [OT] S_N, sent a detailed reply. [/OT]
