harshansenadhir
  1. Having the active topic list issue as well as flood control message issue. I thought it's only me until MasterDon confirmed. Was unable to open up a topic for this issue though i tried.
  2. ok found the contact details, do a search to find out before and after pictures of the accident.
  3. Sorry to hear that.. I remember Miniace recommended a good place, search through forums you should be able to get it or wait till mini sheds some light. agents would be a better bet if insurance bears the entire amount which is obviously exorbitantly higher than a normal place.
  4. This makes more sense but still Merc got lower ranks .. something to do with sampling error or in reality mercs aint reliable ?
  5. "modified" one with 60th anniversary, if not for a re-bodied or engraved original brought down from UK. There are many companies and individuals bring down spares and vehicles from UK as of lately. had any chance to peep into interior ? which will be a big give away.
  6. me too lost trust in this by seeing Citroen and Ford somewhere in the list. Citroen got and presented good innovative stuff but when it comes to reliability PSA and Ford should rank vee low.
  7. i know everyone will say Toyota. But what about Mitsubishi? Innovative than Toyota and certain models are well reputed in long safari ralleys and ralleys in general where reliability matters more than performance.
  8. deep rims means higher offset and therefore weight/force applied on the hub will be higher ( force * length from the pivoting position). However I don't see an impact on the CV joints but the hub bearings and other suspension parts takes the weight or rather increased force.
  9. I got done some work from the MasterDon recommended place in Wattala and now me too can recommend the guy and they do chroming on plastics too. I got done chroming of two foot boards of a J44 and cost me around 3000/- and superb results. Checked the price for a bumper of a valkswagen with a fence sort of ( aka wata model) and quoted 7500/- . For you to get an idea about the prices, better call and check straight from the place (contact numbers are given by Mini in another post in this thread) rather than asking for the prices in the forum.
  10. couldn't have replied any better, better flush the tank as well because petrol evaporate slowly over time and what is left in the tank might not be combustible..
  11. my boss has had bad experience with A###ns and they broke the teak dash trying to pull it out. He's still looking for a teak dash panels. I got two jobs done from Pet#o and one on classic 504 and the other on 406, both they've done a good rather impressive and neat job. I was next to the guy who did fixing in both the jobs, fearing that he might break some dash board component or might mess up interior which will be a costly affair for me to rectify. When I was too worried he simply made this comment, "don't worry sir, you're getting this job done at Pet#o" and they kept their word at least in my experience.
  12. have you tried browns? they're sole agents for Makita
  13. harshansenadhir replied to sira's topic in NISSAN
    I got it done from a place between Boralesgamuwa and Piliyandala alongside 120 bus route call Harsha Wheel Alignment. But I think most of the alignment places do this. There's another place in highlevel road but I can't recall the name of the place. It's located towards right hand side passing Malapalla junction and before Kandos factory.
  14. harshansenadhir replied to sira's topic in NISSAN
    if it's including recon nuts and bolts (recon stuff bought from used spare parts joints are better than low quality Taiwan nut's and bolts available for buying brand new) and everything it's worthy, go for it.
  15. try out the guy whom Mini has given reference couple of times. He's in Darley Rd and Ruwan is the name of the guy. A decent and capable bugger. This is his number. 777918291
  16. many happy returns of the day mate..
  17. as Ripper pointed out handling and keep up on a straight line or on a highway is different. Handling is well applicable for SL road conditions where there are pot holes everywhere and ripples and uneven, un predictable humps and bumps here and there and you end up with painful eyes as a result of keep an eye on those. So a sedan which can keep up to 140 or 160 in highways might struggle in this terrain. I've maxed out the 406 on Colombo - Piliyandala road that is only 130 or 135 (couldn't properly look at the speedo as car was that shaky) and beyond 120, handling wasn't of satisfactory, i'm sure if a corolla runs at 120 on the same road it might end up air borning on one of nasty bumps you encounter, leaving corners aside.
  18. harshansenadhir replied to sira's topic in NISSAN
    camber adjustment is not posible with some setups and yes of course same applies for FB13. When the original height (distance X in the diagram) reduces (due to reduction of the coil tention) camber position goes negative. Some vehicles, this can be adjusted either through lower arm or at the hub fixing point (two red pivoting positions). Ideally you're suppose to change the coil springs or re-tention the springs (haven't heard of a place in SL does this) and replace ball joints, lower arm bushes and original camber position can be achieved if lower arm and Mcperson struts are straight (not damaged due to any reason) there's a modification carry out by most garages and some wheel alignment places to adress the camber issue without changing coil, shock absober or any other suspension parts. This is the modification i got done to the lancer C12 when the same happened. given two red pivoting positions in the diagram has fixed nut and bolt arrangement. What they do is sourcing a bolt and a washer of a different type and a small welding job where they fix a "L" shape metal onto the bolting hole there in the hub and extending the hole which is originally there for fixing the bolt. Washer too will be welded fixed to the bolt and now when the bolt turns it changes the distance to the guide in the "L" shape metal. With this arrangement, you can change camber in/out regardless of how healthy of other suspension parts. entire job costs me 2500/- about an year ago.
  19. that's way too much if the facts are correct, door pannel in the sense the bare metal door or the door card which is a part of upholstry?
  20. I take your point mate, but if this can be enhanced further by giving out one figure, things will be better than a rough estimation which is of no use.
  21. what dilesh pointed out was this RANGE can differ based on the fuel consumption and at which point you decide to fill her up. Better if the figures are like, number of Km's driven from the point of topup and number of liters pumped to make it a full tank again, which will give out the exact or most accurate km/l figure.
  22. so you're not an expert eh? driven EPS vehicles and I for one don't get the response and the driving pleasure of a hydraulic PAS, it's too toy and babish in my thinking. I may be wrong here, me no expert.
  23. RMV stopped assigning the running number series for converted ones after sometime and instead started given 325-. That applies only if the vehicle bearing non english plate number. For english plates, it's a change from P to D. Again this is due to inconsistancies of their actions, initially they gave running series for army auctionned vehicles too. There's a GW- Peugeot 504 that I know of which bought from Air Force auction and the mentioned J44 with english plates. That is again those days forces did not register vehicles with RMV and hence vehicle doesn't bear/allocated a number from RMV and after the auction buyer suppose to register it as a new registration and that's why initially they gave the running series. It was only highlighted when english numbers came into play and pretty old vehicles were running around with english plates. But now forces has to register and obtain/allocate a number which they don't use but will be used only after the auction. Simultaneously they changed the policy that auctionned vehicles which were not initially registered with RMV also given famous 325-. I don't know whether they created 325- initially for converted ones or auctioned (re-register after some time) ones but 325 is given for both for sure.
  24. not entirely army registered ones, petrol to diesel converted ones also given 325-
  25. may be he's referring to brand new prices from Agents and if so, this is a possibility
