European Vehicle Between 4.0 - 5.0 Mil
will do , but stay away from ill treated UK used ones, coz most of executives here are brought down from UK and UK suspension system can't cope up with hard terrains here not to mention low ground clearence and lacking of a sump guard in UK model.
Power Shutters
what's the make model of the car? it's very unlikey that all four shutters stop working due to a failure of power shutter mechanism. as many pointed out this should be electrical. You need to check the fuses,relays, main control pannel on drivers side door and if all fine the wiring harness. If you search around forums you'll get contact detail of a guy call Ruwan whom had recommended by Miniace. he'll be in a better position to solve this out, however if this car is european, PM me, I'll provide a good contact.
Lancer Box 1979-1982
it's rear wheel drive and there are two versions 4 and 5 foward. The red beeding model is the top of the range with RPM meter. but beware, there are converted red beedings also in the market. Options as far as I know, are only air conditionning and AM/FM radio cassette player. by considering the price ranges, I think it's better to go for C11 or C12 simply because there's an overlap on the market pricess but features and technology wise you get better cars.
Xenon Hid Kits
Try to stick to 55/60W original bulbs and ensure proper voltage (12 ~ 13.2 V) at the bulbs will sort most of light related issues. Don't ever ever go for blue coated bulbs as it drops all colors of the spectrum except blue color, which explains poor lighting in long distance travelling. Also clean the reflectors and inside of the glass/lense cover which will improve the power of the light beam drastically. As the website I reffered suggested try out additional wiring/relays to avoid lengthy wiring from switches and increase voltage as wires build up resistance when aging. I did this for almost all vehicles except the 406 which I will do shortly and obtained better or rather excellent results without going for higher watt bulbs or expensive niche brands. With the lancer did a small modification in addition to two relays for high and low beams positioned close to head lamps with extra thick wiring, that is to operate both the fillaments for high beam which impressed my mechanic and he ended up asking me to do the same for his car (just to illustrate the improvement of lighting ) After about almost one year since the conversion nothing went wrong and still i'm using the same bulbs. If possible do this conversion as you can control whether low beam also should lit up with high beam (only additional toggle switch requierd). Planning to do this soon on lancer as 406 anyway operates all 4 beams with high on.
Fuel Saver
true that you didn't start the windshield repairing thread, but you did advertise your services there including your contact numbers. It was pointed out by many members and some went to the extend of asking is personal advertising allowed in the forums. And now you're saying by publishing contact numbers here, repetitively, multiple posts one after the other, you didn't intend any of members to contact you? you must be kidding. You got yourself wrong at the very same thread and accused me for posting about your high charges in this forum where as it was done by a different member, I asked to withdraw that comment but you were not so generous to accept your mistake. now in this fuel saver thread, you're indirectly advertising (or bragging) about the services and the qualifications of your mechanics, at the benefit of SL automobile community? or you're doing a community service here? again, you must be kidding. it's you who pointed finger at me confusing yourself and it's up to you to bow down or argue with me or fly a kite, I don't give a damn and I posses enough intelligence to deal with fellow members in this forum, but one person. So I'll let others to decide who's the culprit. Admins, I leave it at you all to decide whether this is advertising or not, to be frank, I've never seen this level of misuse of AL forums for personal benefit.
Fuel Saver
Mr. Wijesinghe, it's by all means not allowed to advertise here in this forum, with each and every post what you're doing is advertising your services indirectly, which is against forum rules. You'll earn a bad reputation among members by going against forum rules rather than a good reputation by being recommended by fellow members which didn't happen to the date. Let automobile community praise you rather than you blowing your own trumpet. If you search around this forum you'll see there are some technical guys, garages being praised by forum members and hence they earn a good reputation without them posting on this forum. Simillarly there are some garages and guys being bashed for being charging high and for poor delivery. Let your reputation to be earned or if you believe you already have a reputation, let it flow into this forum by all means but, not through your own trumpet again.
Fuel Saver
did all i could do including reporting, it's upto admins now
Steering Weal Tight
good that you've reused a thread. something to do with oil level and the thickness of pas oil.
Ae110 Fuel Meter Problem....or Is It Normal Reading
now where's the original poster? we're waiting for you to fill her up again and post the numbers here...
could be, but this is deisel hybrids, checkout the links. Now I wonder CRISCO Nihal driven a hybrid allion around http://green.autoblog.com/2008/05/22/hyper...lia-at-75-6mpg/ http://www.peugeot.co.nz/News/MediaDetails...x?ArticleID=142 http://www.peugeot.co.nz/News/MediaDetails...x?ArticleID=139 http://www.peugeot.com.au/oct-08-dec-08/pe...-economy-drive/ http://www.peugeot.com.au/fuel-economy-world-records/ Fuel Economy World Records Peugeot is the proud holder of two Guinness World Records for fuel economy, both set using HDi diesel technology in the tough Australian conditions. Our first world record was achieved in 2002 for the furthest distance travelled on a single tank - 2,348km (Melbourne to Rockhampton) from a single 70 litre tank of fuel. The record was set in a Peugeot 406 HDi. Our second record, originally set in 2004 and then broken again in 2008, was for the overall round Australia fuel economy. The 2004 trip, in a 307 Touring 1.6 HDi travelled a distance of 14,634 at an average of 3.49 l/100km. Bettering that effort was a trip 4 years later, this time in a 308 1.6 HDi. The figures are even more amazing, with a distance of 14,580km travelled at an average of just 3.13 l/100km. The cars used in each trip were completely unmodified from what you would find on the showroom floor. Making the 308's world record even more remarkable was that the car was carrying the additional weight of two people plus luggage needed for the 25 day trip.
well time to look around, check which brand holds the guiness record for longest mileage per tank with 90+ mpg (disclaimer : i personaly don't intend to start a brand war, just highlightin facts as part of community education)
wow this is great, so you figured out that he only burnt 8.2 liters for this trip?
Whats The Lifespan Of Shock Absorbers
in my experience with vehicles there's no such life of shock absorbers or any spare part for that matter. There were times shocks last for many years and failed within 3 months after the replace. It's not time you should be looking at but the condition of the shocks. Get it checked by an expert to see a replacement is needed
Pamper Your Tires With N And Pump Xtra Premium
if you followed the thread closely you would know that yes, ran 28 and 33 on all four corners with normal air
you cant judge the amount of fuel used by simply looking at the portion of the gauge needle. Usually full tank stays without showing a movement on the gauge needle not because entire full tank is unused but because floater hasn't moved down until fuel level goes down below the thickness of the floater(plastic box sorta thing) also first half of the tank goes down slowly and second half goes fast. This i noted in my car as well as my boss's carina. So it should be same for you. Best thing to check out fuel consumption is to refill tank full and find out how much of fuel it burnt for the trip.
- Toyota In More Problems
lol, agent i almost gave it away me thinks, so does the make. What about the model
Ecu Problem???
if this car equipped with variable power steering controlled by an ECU, yes then it's a possibility. Best is to check with a fault code reader and troubleshoot accordingly.
Xenon Hid Kits
http://www.danielsternlighting.com/ check this link, it's got very useful tips for you to improve auto lighting.
rofl , that's a good one. But Alions are aggressive? very hardly i've encountered with Alions, may be the body parts are tad bit expensive to risk in day to day traffic?
Successor Of Peugeot 407 Is Not 408 But 508
, rather we discussed something interesting than day dreaming. Even the old 407 is beyond reach in this country with scary tax schemes. (white vans, no pls) some 407s are now sent to scrap yards in UK, not to mention the sad state of HDI Executives priced close to 3.0 mil here. Pampered ones goes for 2k GBP or 3k max. Older models sent to the scrap yards for merely 90 GBP, where as we spend millions to acquire one. So let's talk about 508
Mitsubishi Jeep J20 4dr5 Door Locks, Where Can I Buy Them?
shortest wheel base is the J54 AKA SAFARI model in SL.
coincidently you pointed out something which we were dicussing in detail, that's loading junk into countries like us where consumer protection is not even heard of. there's a high chance some of those recalls safely lands here may be at a discounted price. I know of a simillar story heard from an insider of a reputed agent supplied vehicles to most of govt. institutions in 70's and 80's. Particular agent had been contacted by principles and informed of a ship load of rejected cars of a particular model and ship was sailing close proximity to SL. Then chairman had agreed to sell all 300+ vehicles and ended up SLPD giving this model of cars to then ASPs. Now guess the make/model and agent . I was thinking, if this happened in SL would we be able to send or demand toyota to recall a single vehicle, not to mention the inferior quality of the production aiming countries like us even of the same brand, Toyota.
Windscreen Repairs
Dear Mr. Wijesinghe, I beleive all you've mentionned here could be true, however if you're claiming yourlself a white collar professional in Automobile arena, I assume you got enough skills to read and understand to a greater extend. If so please go back and read who pointed out about your sky high prices. It wasn't me, hence no need to address me and explain sun and the moon as I am not interested.
Windscreen Repairs
to my best knowledge by being a member here it's not allowed. However there are incidences where fellow members provide references based on their experience for the betterment of others. Having said that, we moslty exchange such information through pm s as this forum is very very particular about advertising which is really good.
