Turbo Timer FAQ
The primary purpose of an aftermarket turbo timer is to allow your engine to idle unattended for a user specified amount of time. This will allow your engine, specifically the turbo, to return from elevated temperature levels to normal temperature levels prior to the engine being turned off. This can prevent oil coking in turbochargers that are cooling by engine oil.
Are these necessary with Subaru Turbos? No.
June 2001 TechTIPS published by Subaru for Subaru Technicians states:
"2002MY WRX TURBO COOL DOWN PROCEDURE
FHI's position regarding this is that it is not necessary to perform a "cool down/idling" procedure, as was recommended with past turbo models. Our current 2.0L turbo engine has a far greater cooling capacity and, coupled with technology advances, makes this practice no longer necessary. This explains why information about cool down is not included in the 2002MY Impreza Owner's Manual.
The heat contained in the turbo charger will begin to vaporize the coolant at the turbo charger after the engine is stopped. This hot vapor will then enter the coolant reservoir tank which is the highest point of the coolant system. At the same time the vapor exits the turbo charger, coolant supplied from the right bank cylinder head flows into the turbo. This action cools the turbo charger down. This process will continue until the vaporizing action in the turbo charger has stopped or cooled down."
http://www.subaruwest.com/PDF_files/Tech_P...01_techtips.pdf
