Everything posted by wolseley
- Quick Trivia 3
Buying The 1St Car Around 2-3M
Axia is a newly introduced perodua model. However earlier Viva has won some reputation here and has reasonable resale value. As what hrm said above is very correct. BTW I personally dont prefer underpowered 660 kei cars.
Quick Trivia 3
Someone else please take the turn
Quick Trivia 3
Nissan Bluebird SSS U12
- Quick Trivia 3
What about Perodua Axia ? 2.6 mil Auto
Changing The Stock Horn Of Subaru
I suggest Fiamm AM 80 or Mitsuba Alpha
- W123 Restoration
Excessive Road Noise
Maxxis is a good tyre of course and is not very expensive. In the past I have had many brands of tyres on my vehicles. But finally its Dunlop for me.
Seam Sealant
Call wurth Lanka . They might have the stuff.
- Hyundai Accent Ecu Repair
My Experience When Importing Car From Japan
Freight JPY 60,000 Ins JPY 5,000
Tyre Prices
Sumitomo HTR200 175x 65 R 14 8,500 with discount (March 2015) from VR Vadivetkarasan
Ac Gas Refilling - Please Help
If necessary you have to replace the expansion valve also
A/c Not Working At Idle
If the clutch and idle-up switch working properly,the reason may be that your compressor is unable to give enough compression at low RPM. If so no remedy other than replacing.
- 15 replies
- cool
- a/c
- ac
- air condition
Suzuki Celerio Vxi Amt
The gearbox is a "Magnetti Marelli". A kind of one on the Fiat Punto. But coupled with a Maruti only the god knows what will happen.
My First Car Nissan B211 1976
Congrats on your first car.. If you like to use it as a daily runner get done a complete brake overhaul. Remember you have to drive among the vehicles with much more powerful brakes. If it is not fitted with a booster get it modified with a matching booster. That is what I did to my EP 71.
Car Park Out Of Shade At Night
Exactly .. Once I was compelled to park under a Neem tree overnight. The result was horrible. Had to do a 'cut & polish' to get rid of 'leaf patterns'. Anyway I'm not sure It because of the leaves alone or combined with the spray from the sea nearby.
- Two Door Cars Around 5Lakh O.o
Johnway
One of my friends use a Jonway UFO. Though it looks like a Rav4, It is a machine from China fitted with a mitsubishi engine.
- Gear Box Needed
Windscreen Cracking
There is a substance called cerium oxide. I got a sample from 3M and tried it on a scratched side glass. In fact it works, but you have to polish for hours to get a reasonable result.
Great Places To Eat When Driving Outstation
Yes I have tasted it in Akkraipattu. It is available in the East.
Difficult In Gear Shifting - Tight
Had similar problem once. It was due to the tightness of pivot on the outer linkage fixed to the gearbox. After cleaning and applying little grease it was over.
Used Vs. New
some cars have kind of inherited problems major or minor. Allion 260 got that bad commpressor.
