Everything posted by PerfMad
Honda city 2001 idle rpm with ac
I have the same model with vtec, however mine idles around 700 without AC and with AC it idles around 850-900 (not more than that) and car doesn't have any vibrations around that idle speed so i believe its the exact value and haven't face any issue with AC. However, when its parked under hot sunlight for longer period in any vehicle, it does take sometime to cool things inside since the metal and all other components should be cooled as well.. The best thing is to open the shutters and drive for 5 mins or so and then slowly switch on the AC (even with full cold position). This is common to any car (except newer models are capable of cooling inner compartment via mobile software prior to entering your car).
Mitsubishi car
looks like you have so many related issues which affects your fuel figures and emission. First thing first, get your vehicle to a mechanic and get an engine tuneup done. During the tuneup pls make sure you check the condition of plug wires, spark plugs and fuel filter, air filter and replace if necessary. and end of this tuneup your engine should have all 4 cylinders working.. For carburetor tuneup, i suggest you go to Mr. Dhammika (at kotta road, rajagiriya) he is well known person for tuning carbs properly for best fuel consumption..
Hyundai Trajet
you're welcome !!
Hyundai Trajet
if that's the case your issue might be resolved simply by replacing the head gasket.. however if you want to pay a visit and get an opinion then here is my mechanic contact details: Vipula motors (located at nawala koswatta) contact no - 0722 196 030
Hyundai Trajet
just curious don't you see bubbles even when the gasket is damaged ?? @segu can recommend a place near Nawala if its convenient for u
Sudden Engine Knock When Engaging And Disengaging Ac While Driving In Slow Speeds (10-30Kmh)
Hey folks, i just recorded the behavior of the RPM meter for your reference. Please note that the sudden loss of RPM shown in the video is only when i press the clutch paddle on the move.. and at other time even with the knock rpm will reduce smoothly. **note: really sorry about the noise, i forgot to mute the radio prior. Please use below link to view the video, if there are any issues with the video viewing please do let me know. http://www.mediafire.com/file/h74dev1ur4hfih6/20171212_193332.mp4
@Rumesh88 How to diagnose whether IACV is faulty or not? in neutral if u accelerate upto 5000-6000 and release still it will slow down as normal without any hesitation. Last year when i did the engine tuneup i asked to clean the IACV value twice and second time i was there when it was performed and it was cleaner and i saw it was moving freely (when it was disassembled for cleaning).. This issue occurs only when moving.. Add to that after cleaning the injectors and its filters, car is more smoother again and powerful too.. Just curious could this be due to someother reason, my front shocks are also now in bad shape and i hear daga daga noise as well.. but i believe this has no relation.
Hi machan Looks like i need to rename the titile of the thread..the issue has nothing to do with the ac ..i get the knock even when the ac is on. This issue can be recreated anytime hence its comin always..only thing is if i keep the fas paddle bit steady n release it then rpm comes down slowly as expected..this happenes only if i release it suddenly.. However i will check this clutch thing u suggested n chek the rpm meter readings..
- Sudden Engine Knock When Engaging And Disengaging Ac While Driving In Slow Speeds (10-30Kmh)
Hey Folks, Its been awhile and im still having the issue as it is. Today I went to another mechanic, he did an engine tuneup and did a test drive, and issue remains same. He's suspecting its the KNOCK sensor and told me there is, no other way to check it whether its faulty or not, other than replacing.. Also he wanted to check prior by connecting it to the obd port but unfortunately mine has a port like the attached, and his connector wasn't supporting mine. What are the possible areas that i could check for? and is there anyway to diagnose the KNOCK sensor prior to replacing?
N16 Head Light
Better check with someone else who uses the same car to see what the original bulb socket is.. As far as i know it should be H4.
N16 Head Light
Best thing is, replace the bulb with left hand side bulb and see whether issue remains.. if issue resolves, then it could be due to some issue in your right side bulb connector.. Let us know your findings, then we can guide you to identify the exact root cause.
- Hybrid battery cell voltage drop Issue
- Car stereo not working
Ticking Sound when accelerating
Hi @asanka_rg Do identify the exact issue, you can do the following; - Turn the steering to right side fully and do a quick acceleration and listen to any kata kata noice - Turn the steering to Left side fully and do a quick acceleration and listen to any kata kata noice If you get the noise from either/both sides then your CV joints have worn out and need replacement.. My advice is to replace both at once, otherwise you will have to replace the other side after few KM's which will result u additional labor cost + trouble. Furthermore, i believe for ur model CV join can be replaced separately without replacing the whole axle ..(not quite sure, but over to experts) Cheers
Burning smell at high revs
is there any visible oil leaks ?? check under body ones as well.. if non, when was the last time you changed engine oil and how many km's have you done as of now?
Bent Chasis Straightening
Hi @offroad12 With regards to your concern there was a place in SL where they do accident repairs as per the manufacture spec.. without harming the strength of the metal.. Go to Youtube and search for Sukkanama.. If possible please watch last month episodes you will get the contact details there.. I can't remember the place or the name properly.. Hope this helps you.
Engine Check Light
However check whether there are any loose connection, if there isn't you may proceed with replacing the item
Engine Check Light
Hi @kanchana2504 There is no issue in running with the issue till it gets failed permanently. But my advice is to replace it as soon as possible since this will impact ur fuel efficiency. Because since there is a malfunction in TPS your gear shifting will not be smooth as before also will go for high revs to change gears.. As per my understanding a recon one should be not more than 6k. its a pretty straightforward thing (just plug and play)
- Nissan nawara
Petrol smell in the cabin before start the car
As far as i know there is a special sort of filter (if you look from the outside) in engine bay compartment, to absorb this petrol gas which will be built inside petrol tank (correct me if iam wrong), this smell could be due to malfunction in that system or if you are getting it from the back side, then probably some leakage in fuel line could be a possibility as well.. @Rumesh88 may be able to give you a better resolution on this matter i believe.
is it liquid name is "soltron" ? Could it be due to some leakage in fuel line ?
- gear problem
- gear problem
Honda Grace Transmission issue due to DCT.
Im not aware of this issue, however if that's the case then fit GP5 should have the same issue, since it also has the same gear box mechanism..
