TG10E24
TG10E24 last won the day on February 27 2019
TG10E24 had the most liked content!
3 Followers
  • Location
    Kandy
  • Interests
    Computer Programming, Automobile, Electrical & Electronic Engineering
My Vehicle Details
  • Vehicle Make
    HONDA
  • Vehicle Model
    Civic FD1-S
  • Engine Type
    1.8L - 4 Cylinder Inline
2,249 profile views
TG10E24's Achievements
  • First Post Rare
  • Collaborator Rare
  • Week One Done
  • One Month Later
  • One Year In Rare
Recent Badges
12
  1. From above 2, I would go with Nankang. My previous experience with CE#T is not good. They were too hard and casued many suspension issues. Finally I had to keep the tyre pressure below 28psi and finally I had to throw them away due to broken belts
  2. Hydraulic steering racks with oil leaks are possible to get fixed by replacing oil seals.
  3. Thanks so much for the valuable information. Thanks so much
  4. Hi Autolankans 😀, I'm happy to get to know about Toyota Harrier 300g YOM 2003 (180000Km). Hope some one can help me 1. What are the common issues of this vehicle? 2. How is the maintainance cost? 3. How easy to find spare parts? is it like other Toyotas? 4. What is the best market price these days? 5. What is the fuel consumption of this? (Previous owner syays that it does 15Km/L 😁) Thanks in advance
  5. Octane 93? IOC Xtra premium is 92 octane with some detergents etc.. as I know
  6. Honda - Solution for chattering noise under the dash. If you are hearing some kind of a chattering noise from under the dashboard, this might be for you (Video 1 - after 11 seconds). There are multiple actuators in the air conditioning system; however in my case, it was the actuator used to mix cold and hot air. As you can see, the actuator is having hard time to recognize its position (Video 2). Solution is to clean all the brushes with alcohol and carefully bend them up (slightly) to make a good contact with the carbon trace (resistor). Note: Grease you see here is dielectric grease. Don't clean them if you don't have dielectric grease with you. Hope this saves you time and money. (PS: If it's still giving troubles, most probably your carbon traces are out of the shape and need a replacement )
  7. How is the joint now? Any updates? I'm asking this because, I got the same CV grease for my CIVIC's inner CV joint. For inner CV joints we need a special grease (kind of cream, more to liquid side rather than normal sticky grease). It's hard to find a good grease from here now. All they have are Sri Lankan made greases which are sticky; I used this last time and CV joint got damage within few KM's. Found a reconditioned CV joint even without a worn mark lol. All these because of the quality of grease.
  8. 2007/11
  9. Sorry. Fixed
  10. Honda Civic FD1 - R18A Throttle Body cleaning after ~ 50,000Km. Symptoms: Vibration when the A/C is cycling ON What happened: There was a very little amount of carbon build up on the throttle body and the RPM was dropped by ~200 due to the reduced gap between the throttle body and the plate. It was enough to make the vibration when the A/C compressor is adding some load to the engine. It got recovered within a second; however I felt that so badly LOL * Need to remove the air box completely ** Don't force open the throttle plate (It will damage the throttle body, strip gears and mess your idling) *** To open the throttle plate for cleaning, turn the ignition ON and ask some one to press the accelerator or use a weight. **** Use throttle body cleaner, contact cleaner or carb cleaner. ***** Don't forget to hook the MAF sensor before turn on the ignition otherwise it will log 2 errors (you can clear them if you have a scanner). ****** This method is without disconnecting the battery. No need to re learn the idle after cleaning. Before: After: Cleaned everything and also cleaned the engine + transmission because it's hard to reach this area after assembling the air box Vibration during A/C cycling ON has disappeared and the RPM is stable at ~800 P, N + A/C ON D, R + A/C ON
  11. Unfortunetly. btw, it's not neccessary to change the filter this time
  12. You still pumping 95 ?
  13. Same for me; first time they said the same thing to me. But I got another 3 phones lately without any issues. Never happened any issues with vehicle parts and electronics. Most of them reached my home. @alpha17 be genuine tell the truth they won't like if you lie. Keep in mind most of parcels marking as gifts no problem with that. But they open stuffs in front of you sometimes sellers including visiting cards, some notes ...etc. inside the package. Hope that you won't face a situation like that. That is why I asked to be honest ?.
  14. H7 should be the head lamp. Most of other lamps will be standards. Eg: 21W for turn, 21/5W for stop/parking, 5W for parking, 10W/8W T20 for dome/interior/cluster I don't have a Premio so hard to tell exact sizes without checking. Edit: as @Twin Turbo wrote, turn lights will hyperflash if you don't use a LED compatible flasher. In that case, you will have to upgrade or use a dummy load in parallel to the lamp.
  15. According to my experience, DHL charged me about Rs2800 for clearing my injectors in 2017 (as you know ). All 4 injectors were $87 at that time and DHL charged me $36 to bring it to Kandy from UAE (3 days as I remember). Delcalred value was $60 and Total weight was 1Kg. If the calculation is right, I have paid ~24% as tax. But, when I try to release other items (not vehicle parts) the tax was about 14% or something. And intersting thing is I ordered same injectors last year from China (Genuine, Reconditioned) for another car with China post and they reached my home. Same thing for USPS; some stuffs will be stucked in customs and some will not. I don't know how they do that may be the weight of the package or the size of the package or the custom declaration or may be the carrier or may be the luck? Same thing for electronics too including mobile phones. You don't have to be a girl, if you can talk and behave good you can get them released. If you try to cheat, it will be more problems
