Bj5P Engine Number?
mazda zoom
Check the lower right hand side of the exhaust manifold engraved on a flat area on the block facing forward or upwards.You might not see it properly if covered with sludge/dirt and oil.So clean the upper layer of the block and check.
MINIACE.
  On 1/13/2011 at 5:34 AM, miniace said:
here the case is ,Mazda Zoom is trying to cross check the actual engine number init ..
MINIACE
Thanks guys.
Miniace is correct. i just wanted to cross check the number. Unfortunately I Can't find engine number in the plate attached to the bulkhead. It shows the chassis number only. I'm new to Mazda.
Edited by mazda zoom
