Suresh Sadamal Posted January 15, 2011 Share Posted January 15, 2011 Hi All. I am new to this subject. I am planning to buy a FB 15 in the range of arround 1.7M to 19M. Could you kindly please give me some hints to check the vehicle condition ?. What should I need to check when I inspect the vehicle ? Quote Link to comment Share on other sites More sharing options...
jdnet Posted January 15, 2011 Share Posted January 15, 2011 http://forum.autolanka.com/Index.php?/topic/3430-how-to-buy-a-used-car-in-sri-lanka/ Quote Link to comment Share on other sites More sharing options...
Isuru Udana Posted January 15, 2011 Share Posted January 15, 2011 For electronic units following are basic tests from indicator lights. Air bag When you put ignition key to ON position, air bag warning light illuminates for about 7 seconds and then turns off. It indicates the unit is operational. Following indicates a fault in the unit The light remain on after proximately 7 seconds Light flashes very quickly Light doesn't come on at all Light turns on when driving ABS When you put ignition key to ON position, ABS warning light illuminates for about 1 seconds and then turns off. It indicates the unit is operational. If the light doesn't come on at all or if it flashes during driving means a fault. Automatic Transmission When you put ignition key to ON position, OD-OFF warning light should illuminates for about 2 seconds and then turns off. If the light doesn't come on at all or if it flashes during driving means a fault. Please note that we can't guarantee that the units are 100% operational by those lights. But if the above tests fails, it indicates a fault in units. Quote Link to comment Share on other sites More sharing options...
Isuru Udana Posted January 15, 2011 Share Posted January 15, 2011 Almost all the Super Saloons and Ex Saloons comes with a Remote Key. If the car which you inspect doesn't have a one, surely previous owners has lost it. Quote Link to comment Share on other sites More sharing options...
Suresh Sadamal Posted January 15, 2011 Author Share Posted January 15, 2011 Thanks for all the valuble advices here Quote Link to comment Share on other sites More sharing options...
