Ok guys,
So I think I just got majorly screwed. I spent the day removing the injectors on the rribute and had to take out the pcv valve The valve is located under the fuel rail and in a tight spot. Whats worse is that it's plastic and sockets will not fit on it. I was using a 21 mm open end wrench and got it turned almost the 1/4 needed to take it out and then disaster. The square plactic on the valve (see pic) broke. So now I'm pretty much left scratching my head. Anyone got any ideas on what to do?
I would really like to take this valve out intact because finding a replacement will be really tough. Just worried about getting it out ATM as I think I can use some JB weld and to glue a nut into it to make future removal and installation a bit easier.
Can you get a mini mole-wrench (aka locking pliers) in there? You'd have to be ever so gentle though or you'll end up even worse off than you are now.
Already tried and failed. For tht to work I need to get the pliers sideways which I can't do due to space restrictions. Thanks for the idea though.
