From Where I Can Check For External Noise Of A Honda Civic?
I hear an external noise when I drive the car on a rough road. I recently removed the vent visor (rain guard) by myself due to cracks on it. I suspect this noise started after that or it is coming from the number plate (license plate). Also I can hear a little noise when the car is on start and not driving (sitting on a rough surface). I want to check whether this noise actually comes from number plate or from the side windows. Is there a place to fix this type of things? Car is a Honda civic 2002.
Thanks In advance
2 answers to this question
visibly examine the front of your car and shake the bumpers, grill and number plate and see if its loose or whether you hear a similar noise. start the car and check. if no sound, then pull handbrake and shift to D and get out and check. thats the time wen the car will have more vibrations.
Well obviously the best way is to start the car and get out and see if there are any vibrations in the numberplate and the vent visor.if the noise stops when you touch them the best thing to do is to fit a small piece of rubber (cut it in the shape of a washer) with the bolt so that it will absorb the vibration.
