Hello friends,
I have fixed a new radio to my 4DR5 J44 Jeep. The radio is 12V and the vehicle is on 24V. So first I used a 24V - 12V Converter (10Amp) and after fixing it the batteries were getting weak such as if I keep the vehicle idle for 4-5days its hard even to start also. So I throw away the converter (which I bough it from Petta market - 2nd cross street) and connect the radio directly to a one battery (+ wire) and got the (-) from the body. But the problem did not end. I checked and found that when I disconnect the 24 supply by removing the (-) terminal which connects to the body still the current is passing because parking and ceiling lights are working (however the light is very weak). Is this because of a malfunction of the radio? Because everything goes off when I disconnect the radio (+) wire which comes directly from a single battery. If you have any idea please add a reply. Thanks in advance.
14 answers to this question
Hello friends,
Is the body of the radio connected to the frame of your car in anyway other than through wires ? if the body of the radio touching the body of your car current could pass through.to verify this take the radio out of the din or mounts and see what happens, make sure the frame of the radio isnt touching the vehicles body.
Hello friends,
Bro as said by Stig try removing the Radio from the din mounts and try it. As your dash board is made of made metal,if the body of the radio touches it a negative ground is created. Hence current must be flowing through it.
To stig and Kelum,
Thanks a lot for your advices and I did it which I take the radio out from so that it does not touch any metal or body in anyway. But still the problem exists and the only way to disconnect the current is to disconnect the positive wire (which comes from one battery at the moment). Still I can't imagine what is happening. Thanks.
To stig and Kelum,
Just to be clear how old is your battery ?
Id say there is something wrong with your wiring then.
also take a look at this and read post 13 and 14 http://forum.autolanka.com/Index.php?/topic/10326-fixing-car-audio/page__p__147322__fromsearch__1#entry147322
The battery is not older than 15 months. Thanks for the link and I think I have to go through it with a multimeter and all. Thanks again.
As Stig stated i too think it's something to do with wiring then. Did you fix it by yourself?
There should be a constant power line for the clock.I guess something must be wrong with it :)
Hi Nishan,
I think there is as open circuit somewhere in your vehicle and the stereo is a red herring. You will need to get your wiring checked by a company like Pala auto electrical.
Hi Nishan,
Don,
Where is pala auto electrical .....i need some electrical stuff sorted out as well.
Hi Nishan,
Thanks Don.
Don,
Pala Auto is in between orugodawatta junk (after the flyover) and kandy bridge (in the beaseline road),
Personally, I'm not happy with teir charges. To fix my horn they have carged 500 Ruppes (labour charges) (just to replace the Old horn with new once - i bought the new pair of horns outside) I would have fixed it by my self at home, but it happen onmy way to negombo so i had to find a fix somehow.
just get a quotation or show them and ask how much they need before commit.
This can be so true. Its always good to ask a quotation before handover the vehicle. Thanks for the info.
so any updates ?
Is your problem solved now ?
Hi Stig,
Still I couldn't bring the vehicle to see an electrician & will post what was the reason once I get it fixed. Thanks Stig.
