Auto Gear Shift Problem - Nissan Bluebird Sylphy G10 (2003 Model )
Hi All,
I have a Nissan Bluebird Sylphy G10. ( 2003 model )
Recently i noticed that there was a problem with Automatic Transmission (AT) system.
Gear shifting was not soo smooth as earlier... This problem was observed only in lower gears ( e.g: when shifting from 1st --> 2nd.. there is a observable jerk.... ) .
O/D light was blinking only at startup. ( mostly this was observed during morning )
But after 10~15min drive this will get disappear.... ( i.e. gears shifts soooo smoothly & O/D light is normal )
( PS: I have changed ATF 6 months back from agents. )
Have anyone came across with similar issue ? Any clue ?
Thanks.
4 answers to this question
Hi All,
Thanks.
SAME problem i ve got, it not change low to next.............
Hi Jami,
i didnt get you..
you also encounted same problem ? ( BTW do you have bluebird sylphy too ? )
So what you did to rectify it ?
regards,
Hi Jami,
i didnt get you..
regards,
i ve got n16 1.6l/
problem is gear changing from low to next not in a smooth way, i have to accelerate over 3000rpm from low to change the gear.
