What is the most suit ATF for N16? for stand over 50000 miles or around 25000-50000 miles
mate u have to check ur owners manual or the manual for ur autobox for the recommended standard of oil.. and whether to go for synthetic or non synthetic.. after that it is up to you to choose the brand.. again this is like buying medicine.. if the need is paracetamol.. u have panadol, panadine, etc...
acrroding to my knowledge it should be dextron III or higher... not sure though..
Edited by charitha19
hmm idea is right, but what ATF will make that no of mileage?
for that kind of mileage defa synthetic.. but again the cost is far more me thinks.. so u have to do a little math.. are u gonna put the normal stuff with normal intervals.. or put the synthetic stuff and delay the intervals.. personally i think changing regularly is a good this for autoboxes... i dont know whetehr this holds true as i dont have much experince with autoboxes..
yes the cost is too high comparing to other low mileage ATF, but ATF with less durable one get more heated and may cause other part damage like rubber parts. i found with long lasting ATF heating temperature less and cooling time and cooling temperature much good compare to a ATF with low mileage durability.
Do you get synthetic and non-synthetic (mineral) versions of the same standard spec (i.e. Dexron III etc.) when it comes to ATF?? I'm asking because I have not come across such an option when it comes to ATF. Thanks.
