Peugeot Parts
3 hours ago, mazdaspeed said:
Not too sure if this will helpย  but there is a guy on highevel road - When coming form Colombo towards maharagama, passing the overhead bridge - Apx 200 m, there is a guys who does remotes. - Its on the left hand side / opposite the apartment complex .
Good luck
Thank you very much
3 hours ago, kush said:
Try Ali express if your requirement is only the casing
Programming need to be done carefully as you may have to reprogram all the keys again (depending on the vehicle) key you're using too
Isn't it possible to programme a new key using the details in the old key?
No each unique key will have a code which you need to programed to controller unit in the car depending on the car this could be 2-8 or more keys.
Once you go in to the programming mode it get initialized so you need to program all the keys.
This is the common system there could be other variation, do not know how the Pugs work.
